[ARCHIVE] Outdated UBU Tool related Questions, Reports and Suggestions
Broadwell Microcode 0671 Version 12
Date 19-06-2015
0671-12.zip (11.1 KB)
@SoniX
Hi my dear friend. Just to tell you I’ve upgraded my previous hw config to X99 (Rampage V Extreme).
I tried UBU but the Intel Lan UEFI Rom, which is updated well, doesn’t make the menu appear on uefi bios.
It’s the same issue I found on old Maximus VI Extreme (Z87) when updating Intel LAN.
The Realtek uefi/undi is working fine, but the Intel doesn’t.
Could you please fix this ? Thanks in advance. :slight_smile:
@SoniX
This is a collection of Skylake vBIOS (9.0.1009 - 9.0.1028) & GOP (9.0.1019 - 9.0.1034) modules.
Note: 9.0.1015_nr2 is slightly different. Generally, there are no duplicates. If something has _nr* after the name, it’s slightly different.
SKL vBIOS.rar (185 KB)
Are you sure about this microcode version? I was integrate it to Asus Z170-A v0901 with modified UBU v1.37 (UEFITool 0.21.0.1 + microcode batch) and diagnostic tools shows 39h only. Default microcode was 33h.
Edit:
Btw,
Asus Z170-A BIOS v0901…Microcode is rev.34
Skylake microcode will be reported version -1 because of a bug.
Look at the link in this post by lordkag.
Can be more? Since my motherboard Asus Z87-Plus OROM v0.1.04 and EFI v0.0.07 Intel LAN works without problems.
[Discussions] UBU Tool related Questions, Reports and Suggestions (130)
EDIT: HA-HA, someone needs to take a picture of this. Pacman, SoniX and I replied at the exact same time with the exact same link. I was beaten by milliseconds, not fair…
Why this "-1" offset is not implemented in GenSKL batch file?
Because I show the real version microcode and not misleading.
Thanks for reply,
so anyway UBU 1.37 show real version (revision) of Intel Skylake microcode?
Hi SoniX,
bug on update orom intel boot agent ge. Not update possible to 1.5.72
Thx.
Yes, you’re right. My mistake.
[Discussion] UBU Tool related Questions, Reports and Suggestions (130)[/quote]
At first time, I was update EFI OROM IRST, EFI GOP and LAN UNDI and save as CAP module, but EZ flash 3 returns: "Selected file is not a proper BIOS!". It seems, that UBU v1.37 isn’t fully compatible with latest Asus EFI implementation or Asus not follow all EFI specification.
Finally, I was copy UEFITool 0.21.0.1 to working folder, update GenSKL.bat and try it again and save as BIN.
1
if /I %ec%==3A (set mc=skl\cpu000506E3_plat36_ver0000003A_date#23-08-2015.bin) && goto start
Therefore, I use to flash my EEPROM programmer, because EZ Flash 3 reports same error. Maybe my modification is not safe. I'm not expert...
Fore BIOS details, see attachment.
//edit: Sorry, I don’t read this guide.
2015-09-04 v0901 Dell SLIC v2.3 uCPU.zip (7.9 MB)
The problem, I have a Rampage V Extreme (X99) AMI APTIO V bios. On UBU it doesn’t allow me to use OROM 0.1.0.4 and/or EFI 0.0.07.
It uses a different rom which doesn’t properly work as I can’t see the "Intel Ethernet" menu under UEFI BIOS, while if I leave the original
bios rom, it works.
Could you help me please ?
@SoniX
Hi again. I’ve solved my problem manually adding the 0.0.0.7 UEFI/UNDI LAN driver with Coderush’s UefiTool.
Now everything is working like a charm.
Hi SoniX.
In UBU 1.37 there is a copy of drvver.exe at \Modules\Lan\EFI. Not sure whether it should be there.
@ SoniX:
At the Skylake vBIOS collection I sent you, check the GOP 9.0.1019. It has a different version header. Drvver detects it as v9.0.9 which is wrong. It should be 9.0.1019. Since everything after it works as expected, you may need to add special support for that version in some way.
@Sylar76
I understood what the problem is. Instead, version 0.0.07 installed version 6.9.cc. I’ll have to think about how to fix it.
@ SoniX:
cpu000406C3_plat01_ver00000357_date#27-08-2015
Also attached is a Haswell GOP which cannot be identified properly.
cpu000406C3_plat01_ver00000357_date#27-08-2015.rar (67.3 KB)
Intel unknown GOP unknown.rar (22 KB)
@Sonix,
ASUS has just released today BIOS v1901 for Sabertoothx99.
I have replaced v1801 via flash back procedure (button + Renamed BIOS file on USB 2.0) without any problem.
This new BIOS v1901 works fine.
For testing, I have modded v1901 with UBU 1.37, and tried to flash it.
Seems Flashback procedure does not recognize the file structure: when the procedure starts the blue led flashes intermittently as it does, but only after one or 2 seconds later the blue led remains permanently lighted.
Do you think it is normal ?
