What would the latest ver CPU Microcode ver 1E give over the ver 19 code.
Intel at least partially describes the changes in their Specification updates.
I will link one for the current Haswell CPUs.
http://www.intel.de/content/dam/www/publ…tion-update.pdf
@ Nik1, @ f3bandit and @ Horstfuchs:
Please remember, that >this< thread is reserved for the UBU tool guide and the announcements of a new/updated UBU version by the author SoniX.
That is why I have moved your recent posts into this UBU Discussion thread.
Hoping for your understanding
Dieter
@ SoniX:
I checked the microcodes I have and found some that are not in UBU. You may want to add them at UBU.
SKL
cpu000506E3_plat36_ver00000032_date#04-08-2015
IVBSNB
cpu000206A7_plat12_ver00000005_date#08-09-2010
cpu000206A7_plat12_ver00000006_date#15-09-2010
cpu000206A7_plat12_ver00000009_date#28-10-2010
cpu000206A7_plat12_ver0000000C_date#17-11-2010
cpu000206A7_plat12_ver0000000D_date#18-11-2010
cpu000206A7_plat12_ver00000012_date#28-12-2010
cpu000206A7_plat12_ver00000014_date#06-01-2011
cpu000206A7_plat12_ver00000017_date#07-04-2011
cpu000206A7_plat12_ver00000018_date#18-05-2011
cpu000206A7_plat12_ver0000001A_date#21-06-2011
cpu000206A7_plat12_ver0000001B_date#14-07-2011
cpu000206A7_plat12_ver00000023_date#28-08-2011
cpu000206A7_plat12_ver00000025_date#11-10-2011
cpu000206A7_plat12_ver00000026_date#25-01-2012
cpu000306A9_plat12_ver00000007_date#21-11-2011
cpu000306A9_plat12_ver00000008_date#07-12-2011
cpu000306A9_plat12_ver0000000A_date#06-01-2012
cpu000306A9_plat12_ver0000000C_date#13-01-2012
cpu000306A9_plat12_ver0000000D_date#06-02-2012
cpu000306A9_plat12_ver00000010_date#20-02-2012
cpu000306A9_plat12_ver00000012_date#12-04-2012
cpu000306A9_plat12_ver00000013_date#16-07-2012
cpu000306A9_plat12_ver00000015_date#07-08-2012
cpu000306A9_plat12_ver00000016_date#30-10-2012
cpu000306A9_plat12_ver00000017_date#09-01-2013
HSWe
cpu000306F2_plat6F_ver00000035_date#17-07-2015
HSW
cpu000306C3_plat32_ver00000004_date#08-12-2012cpu000306C3_plat32_ver00000099_date#21-01-2013
BDW
cpu00040671_plat22_verFFFF0001_date#27-06-2014
cpu00040671_plat22_verFFFF0003_date#03-11-2014
Other_Microcodes.rar (382 KB)
@ plutomaniac
Hello.
Can add, but I think that it makes no sense.
This version 07.
Yes I saw that but wasn’t certain why the version is 99. I also have 07 so I did a side-by-side comparison. Only the top version says 99 for some reason. Maybe some OEM messed up something.
This is done deliberately to deceive Microsoft Windows, for example. For the system to think that already installed a newer microcode.
@ SoniX:
cpu000506E3_plat36_ver00000056_date#24-10-2015
cpu000506E3_plat36_ver00000056_date#24-10-2015.rar (91.3 KB)
Thank you for your efforts and the "CPU Microcode ver 1C for CPU IvyBridge (LGA1155)" of the version UBU 1.42 that i have successfully updated on my machine.
Any changelog for that Microcode?
Regards.
Hey guys I have an ASRock Fata1ity Killer
and I ran the newest UBU. Version 1.42 and I see something new!?! any ideas???
Select option for update
1 Intel RST(e) OROM and EFI SataDriver
OROM IRST RAID for SATA - 14.7.0.2341
EFI IRST RAID for SATA - 14.7.0.2341
2 Intel OROM VBIOS and EFI GOP Driver
OROM VBIOS Haswell - 1039
EFI GOP Driver Broadwell - 5.5.1033
3 LAN OROM PXE and EFI UNDI - Intel, Realtek, BCM, QCA
OROM Intel Boot Agent CL - 0.1.05
OROM QCM-Atheros PXE - 2.1.1.5
7 Update Intel CPU MicroCode Haswell/Broadwell
CPU Microcode 0306C3 HSW - 1E
8 Other Option ROM in FFS
9 Look the Info.txt
0 Exit
Press ENTER - Re-Scanning ALL EFI modules.
Enter number:
Then if I select option #8
- OROM_GUID_878AC2CC-5343-46F2-B563-51F89DAF56BA
Press any key to continue . . .
attached is a copy of my bios so you can fiddle with it and figure out what it’s talking about!?! maybe the Intel ME firmware!?!? idk
Z97XKil_1E_2341_SLIC_2.rar (5.41 MB)
I googled GUID and it returned me back to win-raid post for the intel vbios. So it’s detecting it twice?
@ f3bandit
Never mind, it’s VBT for GOP Driver. I will correct later.
Edit:It looks like a bug in the UEFIFind.
Edit2:
Checked, the problem lies elsewhere.
@f3bandit
You incorrectly assembled FFS-file VBT for GOP. In the file there is a double header.
File Modules\VGA\vbthsw.bin should be clean, free of the FFS and the title begin with "$VBT".
@ SoniX:
cpu000306a9_plat00000012_ver0000001c_date20150226
cpu000306a9_plat00000012_ver0000001c_date20150226.rar (12.1 KB)
Already have included UBU v1.42.
@SoniX
Intel Ivy GOP 3.0.1030
8086-0102 Intel Sandy-Ivy VBIOS 2171
Finally…
IVB GOP 3.0.1030 & OROM 2171.rar (58.6 KB)
O-o!
Can you provide download link for this new Intel Ivy GOP 3.0.1030 driver
and Intel Sandy\Ivy VBIOS 2171?
File is already attached,so you can download.
