Hello all , nice to meet you !
i have read many post about modding for upgrade bios . I have actually ASUS MAXIMUS GENE VIII Z170 bios version 3201 original . My processor is 6700K but i want to modding for CLK 8700K ou 8086K.
I have downloaded bios 3401 . i have read the tutorial of modded bios but i have problem. My new 3401.CAP is ok with VBIOS 1054 . In the original file , it’s 1046.
When i check 3401MODED.CAP with MMTOOL last version patched , i see correctly Vbios 1054 but in UBU , before change Microcode CPU, i see 1046 …
For information intel ME is okay
If you have the same problem or solution , i need it because i dont understand why ubu don"t see the upgrade of vbios.
best regards . Thanks you for all.
Kelia
@iambearyc
At the moment, another user is engaged in the project. The text file shows the changes for me, so that later I will not forget it when I publish it.
A later, the next release will be published, where all changes will be indicated.
Zitat von SoniX im Beitrag [Tool Guide+News] "UEFI BIOS Updater" (UBU)In my Device Manager my LAN Hardware ID is 'PCI\VEN_8086&DEV_15B8&SUBSYS_86721043&REV_00' How would I set the Device ID on the latest Intel LAN ROM Boot Agent GE. I'm confused.
UEFI BIOS Updater v1.69.6Updated:
- UEFIFind v0.10.10, UEFIExtract v0.13.5, UEFITool v0.22.1
Removed:
- ME Analyzer
Replacement:
- romhdr.exe -> SetDevID v0.1
SetDevID v0.1 Final
To work with OROM:
- checks support DevID
- setting DevID
- correct CS8
Support OROM:
- LAN Intel, Broadcom, Atheros/Qualcomm
- SATA Marvell 91xx/92xx
Command lime:
1
SetDevID <devid> <inFile> <outFile>
Example for Intel:
1
SetDevID 1502 IntlOromCL.LOM IntlOromCL_1502.LOM
Edit: I know the command of course, just don't know the devid to use.
DevID 15B8 Intel Boot Agent CL
Hello,
during CPU microcode update with my Z97 bios 2203, UBU V1.70rc7 reported this error:
Choice:u
[Preparing for replacement]
BIOS file backup
Empty GUID: File replaced
mCode GUID: File replaced
"3echo" non è riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
mCode FFS: File replaced
Empty FFS: File replaced
Is it normal or there is a fault?
Thanks in advance
EDIT by Fernando: This post has been moved into the correct UBU Discussion thread. The other one is reserved for SoniX and his update announcements.
Not critical. Fixed.
@AL
Update CPU Microcodes
For Asrock 6-9 series, Asus x299 and MSI x299 use only MMTool.
The latest bios of my Z97 motherboard according to UBU has outdated Intel RST OROM, EFI SataDriver, EFI GOP Driver, OROM VBIOS HSW-BDW, OROM LAN QCM-Atheros, EFI Lx Network Killer UNDI and Intel CPU MicroCode modules. Can anyone advice which of these drivers/roms to update if running windows in acpi or ide mode, besides Intel CPU MicroCode modules?
Can u tell me why in the ubu tool sonix don’t put the EFI GOP Driver HSW-BDW - 5.5.1044 and he has left the EFI GOP Driver HSW-BDW - 5.5.1034 ?
@boombastik
As far as i know 5.5.1034 is the latest HSW-BDW GOP, 1044 would be the VBIOS version.
@SoniX
Have you seen this Intel CannonLake GOP 11.0.1014? i looked around the forum, but didn’t see it posted.
Intel CannonLake GOP 11.0.1014.zip (43.9 KB)
@Pacman
Thank you, put in a piggy bank. :))
Interestingly, I looked through the archives and noticed that we had never encountered GOP versions 4 and 12.
It seems a beta UNDI driver but thanks anyway.
Yes, this is beta, the final version on the official website.
http://218.210.127.131/downloads/downloa…GetDown=false#3
with this version and mmt 5.2.0.24 or 5.0.0.7
Option 4 - Other sata controller
I have 10 errors instance of ‘exfind’ is not recognized as an internal or external command, operable program or batch file.
Never happened before ??
Asus (Aptio4) z87ws
EDIT
With admin rights
Same errors with all v1.7 versions in my case 1.7 rc3 and rc7, no probs with 1.69.16 and 1.69.17.4 (mmtool 5.2.0.24 patched)
I Have the same issue
Zitat von JanCerny im Beitrag #4306@Sylar76 What's next? I want to learn how do it.
@Lost_N_BIOS Thank you!
edit:
I just update VBIOS and EFI GOP. 'vbioshsw.dat' and 'vbthsw.ffs files are extracted from ASRock H97 Anniversary. This guide from @SoniX was helpfull (ASRock motherboard owners, please read note "OROM VBIOS 2166").1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
Scanning BIOS. Please wait...
Define BIOS platform - AMI Aptio 4
Manufacturer - ASRock
Model - H81 Pro BTC R2.0
[EFI Drivers - Find and Extract]
Intel GOP GUID 5BBA83E6-F027-4CA7-BFD0-16358CC9E123
AMI NVMe GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Realtek Undi GUID EB53FCAD-3071-4BAB-980C-6E4A379255F3
[OROM - Find and Extract]
VBIOS in GUID A062CF1F-8473-4AA3-8793-600BC4FFE9A8
OROM in GUID A062CF1F-8473-4AA3-8793-600BC4FFE9A8
Press any key to continue . . .
Main Menu
[Current version in BIOS file]
1 - Disk Controller
EFI AMI NVMe Driver present
2 - Video OnBoard
EFI GOP Driver Haswell - 5.0.1023
OROM VBIOS Haswell - 2166
3 - Network
EFI Realtek UNDI - 2.021
OROM Realtek Boot Agent GE - 2.58
4 - Other SATA Controller
5 - CPU MicroCode
View/Extract/Search/Update
Video OnBoard
[Current version]
[Available version]
OROM VBIOS HSW-BDW - 1038
1 - Update GOP Driver
2 - Update OROM VBIOS
0 - Exit to Main Menu
Choice:1
EFI GOP Driver GUID 5BBA83E6-F027-4CA7-BFD0-16358CC9E123
File replaced
Choice:2
OROM VBIOS DevID 402
File replaced
Main Menu
1 - Disk Controller
2 - Video OnBoard
3 - Network
5 - CPU MicroCode
MC Extractor v1.20.0 r77
# CPUID Platform ID Revision Date Type Size Offset Last
1 306C1 32 (1,4,5) FFFF0014 2012-07-25 PRE 0x6000 0x385020 Yes
2 306C2 32 (1,4,5) FFFF0006 2012-10-17 PRE 0x5800 0x38B020 Yes
3 306C3 32 (1,4,5) 25 2018-04-02 PRD 0x5C00 0x390820 Yes
4 40671 22 (1,5) 1E 2018-04-03 PRD 0x3400 0x396420 Yes
Microcodes GUID 17088572-377F-44EF-8F4E-B09FFF46A070
Modified BIOS doesn't work - tested with Celeron G1840 (onbord and extrernal GPU).
Any suggestions?
2018-05-21 v1.40 beta + Broadwell microcode + VBIOS UEFI GOP.zip (2.95 MB)
That’s too far back into a long strung out discussion. You need your own thread for this maybe, then we can start over.
As for now, I am not sure what you are asking, what you have done, what you have linked, etc none of it is in any context for me even if going back to that post.
Sounds like your mod didn’t work though, try again and use different method (ie update yourself, properly from vBIOS repo, without pulling vBIOS from another board like that guide mentions)
If you need it done for you please specify what all you need, this is why I said probably best to have your own thread, so anyone helping can keep track of what’s going on.
