[ARCHIVE] Outdated UBU Tool related Questions, Reports and Suggestions
I have the same issue as coromonadalix (post #4349).
My motherboard is an asus x79 deluxe with core i7 4930K
Huuummm… where is the download/attachment? Am I missing something?
EDIT: Sorry, found it by searching “MMTool Aptio 5.02.0024 Mod” on Google.
The patched MMTool 5.2.0.24 worked fine in the last v 1.6 versions, not in the latest 1.7 rc xx … i checked the patch offsets of the mmtools i have, and they are fine ???
GeminiLake v13.0.1011
Edit:
DrvVer v0.23.9
Hi I use ubu 1.70-rc8 but update intel microcode update 42C to 42D, The PC doesn’t start I have Flash with an origin bios 4805 to restart the PC .
My motherboard is an asus x79 deluxe with core i7 4930K =306E4. someone Has this issue with this processor and this motherboard ?
I have the Asus Z170 Pro Gaming and download >"pure" Intel RST(e) EFI "RaidDriver" v15.9.2.3365 (without header)< but dont understand how flash this and how can i see which version i have it? I have download UBU_v1.70.rc8_without-MMTool and MMTool 5.2.0.24 Patched and now?
@Scoty :
I have moved your post into this better matching thread.
As written within the start post of this thread, you have to put the desired “pure” Intel RaidDriver version into the UBU subfolder Files\Intel\RST and to rename the file to “RaidDriver.efi”, before you run the UBU.bat.
After having updated the EFI RaidDriver, the UBU tool will show you the new (= your demanded) version.
@greb if no one can help let me know, I can mod BIOS for you.
I would like to report a bug.
UBU 1.70 rc8 does not work with Asrock EP2C602 BIOS (http://asrock.pc.cdn.bitgravity.com/BIOS…02(1.90)ROM.zip) as it reports CSMCORE not found.
However, UBU 1.69.17.2 works on the exact same BIOS image flawlessly.
@Lost_N_BIOS Hi, yes I’m interesting that you can mod bios for me. I could mod bios with ubu 1.7 rc8 with network efi sata and rom and marvell but without last microcode update in 42D. If I mod microcode processor update too my pc doesn’t start.
here my bios mod without micro code update.
thanks advance
X79DLX-most recent with all new bios.zip (5.04 MB)
Here is updated BIOS @greb I only updated 306E4 microcode, done manually with UEFITool 0.25 + hex (Extract one ucode module, edit, replace at x4 locations - not 5) - Should be OK
https://www.sendspace.com/file/1asctb
@Lost_N_BIOS thank you very much , All is ok the pc start correctly.
Great, thanks for quick report back!
Its not work by me.
Hi there again,
just got my new ASRock Z370 Professional Gaming i7 today and tried to update latest BIOS v3.10 with latest UBU (as i always did with my ASRock Z270 Super Carrier w/o any problems, evan when flashing).
But when i try to flash it through “Instant flash” i allways get the message “Secure flash check fail!”. What am i missing? Or is it possible, that ASRock has changed their Capsule-Method once again and we need to patch this with a newer fix?
I read the whole thread but could not find any post mention this behaviour.
PS: tried it with older UBU1.69.xx and with latest UBU1.70.rc8 - also tried the method mentioned here.
EDIT:
This is what i tried so far:
opened the attached original ASRock Z370 Pro Gaming i7 BIOS v3.10 with UBU BIOS Updater v1.69.17 - and this is the log file:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
UEFI BIOS Updater v1.69.17 - Z37PG73.10 Logfile:
Scanning BIOS... Please wait...
Define BIOS platform - AMI Aptio V
Brand ASRock
Remove ASRock Protection
Remove ASRock new protection...
Found Option ROM VBIOS in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0 C5A4306E-E247-4ECD-A9D8-5B1985D3DCDA
Found Option ROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0 50339D20-C90A-4BB2-9AFF-D8A11B23BC15
Found Option ROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0 0FDD6564-FF41-4C31-8BC4-376130E5939A
Found Option ROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0 D46346CA-82A1-4CDE-9546-77C86F893888
Found EFI Intel GOP Driver GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0 380B6B4F-1454-41F2-A6D3-61D1333E8CB4
Found EFI Intel Raid Controller GUID 7B17F47D-DA3E-48F3-8EFE-ABC82CB77F2C
Found EFI AMI NVMe Driver GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Found EFI Intel LAN PRO/1000 Undi GUID 48392194-D155-4567-9AAF-FA805BAEEC6C
Found EFI Intel LAN Gigabit Undi GUID 9006872D-3A86-4BAE-A2F0-E527B9D7119E
This BIOS on Aptio V platform, known issues:
- There may be problems with updating the CPU microcode
Drücken Sie eine beliebige Taste . . .
Enter number:0
1 - Rename to mod_Z37PG73.10
0 - As Is BIOS.BIN
Rename? :1
bios.bin ===> mod_Z37PG73.10
So you see, nothing was changed by myself - just opened and saved as modified BIOS file for "instant flash". But this gives error message "Secure flash check fail!":
So i tried same original, unmodified BIOS with latest UBU v1.70.rc8 - and this is the Logfile:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
UEFI BIOS Update v1.70.rc8 - Z37PG73.10 Logfile:
Scanning BIOS. Please wait...
Manufacturer - ASRock
Model - Z370 Professional Gaming i7
[EFI Drivers - Find and Extract]
Intel GOP SubGUID 380B6B4F-1454-41F2-A6D3-61D1333E8CB4
Intel RST GUID 7B17F47D-DA3E-48F3-8EFE-ABC82CB77F2C
AMI NVMe GUID 634E8DB5-C432-43BE-A653-9CA2922CC458
Intel 1Gb GUID 48392194-D155-4567-9AAF-FA805BAEEC6C
Intel 1Gb GUID 9006872D-3A86-4BAE-A2F0-E527B9D7119E
[OROM - Find and Extract]
OROM in GUID A0327FE0-1FDA-4E5B-905D-B510C45A61D0
Enter number:0
0 - As Is BIOS.BIN
Rename? :1
* Many thanks for the use of the project. *
* See Information if You want to support this project. *
Also tried to "instant flash" this modified BIOS - but still the same message: "Secure flash check failed!"
The modfication seems to be ok, cause capsule is still in the same position in this BIOS:
But the UBUmodification still seems not to work on ASRock Z370 BIOS files and maybe some of the pros (@CodeRush @ket @SoniX @lordkag ) could take a look on it again to fix the “Secure flash check fail!”-message again.
P L E A S E . . .
As i already mentioned above: always used UBU (v1.69.17 and v1.70.rc8) to bring my ASRock Z270 Super Carrier BIOS to the latest SATA-, VBIOS-, Network-EFI and Microcode and it never was a problem to “instant flash” those modified BIOS files before.
So any help with this is greatly appreciated. Thanx in advise…
EDIT by Fernando: Codes put into spoilers and pictures resized and directly attached by using the Forum software (to save space, the pics can be enlarged by clicking onto them)
Asus P9D-I 1801 or 2101- can’t update IRSTe Orom from 3.7 to 4.7 with 1.70rc9. Put the correct files in RSTe folder, UBU does recognize them but doesn’t update OROM. Same result with mmtool 5.0 and 5.2. UBU 1.69 can do both and the system is working fine with this version. Where is my fault? Thanks in advance!
Fixed - 1.70 rc9 fix
I have found a bug in UBU v1.70.rc9-fixed when updating Asus Z9PE-D8 WS mainboard.
At main menu →
4 - Other SATA Controller [Current version] OROM Marvell 88SE9230 - 1.0.0.1008 → [Available version] - 1.0.0.1024
After choosing 1 - Update Marvell, UBU says:
The system cannot find the file \Mrvl92xx.txt. → Press any key to continue . . .
This needs fixing!
Tested the new 1.7 rc10, downloaded the patched mmtool 5.2.0.24, and the Intel-RST files
In UBU the 4 - other sata controller is updating ok, (was crashing in the previous 1.7 x versions)
NOW the 1 - Disk controller is updating, but stall after the "file is replaced" and the OMROM IRST DevID 2822 message, nothing happens and doesnt exit ???
the cursor just blink ???
EDIT : just saw the other windows who says : Error in opening the input module file ???
Dang I badly renamed one of the IRST files, there was an hidden space
Sorry ALL is working fine thks for the work
OROM Intel iSCSI Boot 3.0.57
WS-C621E-SAGE-ASUS-3002.zip (3.33 MB)
WS-C621E-SAGE-ASUS-3002_2.zip (3.33 MB)
