this is a very good tool, it worked perfectly with my ASUS Sabertooth x79 motherboard (BIOS v.4302), highly recommended.
I’ve updated the Intel RST, Marvell Controller and the NIC to the latest version
Nice Job !!
By the way I understood a little bit in the header of the microcode for the CPU. Now it will be possible to add support for the microcode CPU update for the X79 boards. But I need to know exactly what are the CPUID topical at the moment.
@ RavenXE:
Welcome at Win-RAID Forum and thanks for your feedback!
Regards
Fernando
Hello everyone, I need your help guys. I have got from Asrock a beta version of bios for my H67M-GE ver. L2.17A, I see that some parts of the bios are not up to date, so I used “UEFI BIOS Updater”. But I have a problem: I have scrupulously fallowed the procedure, but there is no selection number “1”: Intel RST (s) and EFI OROM SataDriver missed, while all the others choices are selectable. This problem doesn’t happen with the official version of bios 2.10, but the official bios doesn’t support the Secure Boot and Ultra Fast Boot. Please Help Me. I attach the bioses. Thanks to all.
Best Regards, Davide
H67MGE2.10.rar (3.88 MB)
H67MGE2.17A.rar (3.61 MB)
@ d4v1d3
Hello.
H67M-GE ver. L2.17A - in this version of BIOS, there are no modules IRST OROM or EFI. So the update will not be offered.
Best Regards.
Sonix thanks for your reply. But it is possible that it lacks the module IRST? I tried to add it manually with the MMTool CSMCORE but without success, I have this error: "file size Exceeds the volume size", why?
Unfortunately, you cannot do anything. Free space is really not.
 Bytes Free       : 00FE90 ( 63 KB)    Bytes Used       : 070170 (448 KB)    |
 @ SoniX:
The interesting fact is, that the ASRocks board H67M-GE obviously supports RAID0, RAID1, RAID10 and RAID5 (look >here<), but its BIOS doesn’t contain any RAID ROM module.
Do you know, how and by which BIOS module the Intel SATA RAID Controller of the maiboard is managed?
That’s right. In standard BIOS version 2.10 is present "OROM IRST", so there is support for the RAID. And in the BIOS 2.17a-beta no modules OROM and EFI. And possibly RAID will not work.
ok, so i can’t use the RAID function. But I bought a SSD 840 EVO, I need to update anything to work well the SSD in AHCI mode with TRIM active?
Thanks to all
Here’s an observation I’ve mad with an Asrock Z68Extr3Gen3:
Using included RtkUndiDxeX64_xx.ffs - v 2.023 - GUID EB53FCAD-(compressed) breaks onboard LAN.
Onboard LAN is shown in diagnosis as version 0.00A (original version included in bios) -> Better make replacing this an optional task.
@ d4v1d3
I think that the TRIM command should work. AHCI in the BIOS function is present.
@ mictlan
You use network booting an operating system in UEFI mode?
ASRock Z68 Extreme3 Gen3 - But in the original versions of BIOS (2.10/2.20/2.30) don’t have EFI LAN Realtek module. You’ll integrate it manually?
Sorry, forgot to mention that I use bios L2.31A (in Beta section). This one has an EFI LAN module.
@Sonix: why not 1038 Marvell Sata firmware, and 2.57 Realtek LAN insthead of 2.58?
@ mictlan
My apologies. Now comes the test of a new utility to display the version of OROM and EFI. For the patient: ![]()
1) Correct in UBU.bat string
set rlo=OROM 2.57 -> set rlo=OROM 2.58
 2) Extract the attached file to a folder UBU the replacement of all files.
OROM.rar (116 KB)
No
SoniX’s UBU Tool only updates OROM and EFI modules, no Firmware.
If you want to update the Marvell 91xx Firmware, it is better to do it by using the installer of the Marvell 91xx Firmware package.
No
Ok.
Please explain more what is the problem?
Yes, my fault, I meant OROM… Is there a module for firmware/bios, like old E6/E7 of non UEFI bioses?
AFAIK UEFI BIOSes don’t need the separate bootloader, but I am not sure about that, because I never had a system with an on-board Marvell SATA Controller.
