Don’t you see the "IRST TRIM-in-RAID Addon" option? It should look like shown here:
If not, I recommend to open the UBU\Modules\IRST\12_9 subfolder and to replace the file named SataOROM.bin by the file named SataOrom.bin, which you can find within the TRIM6\12_9 subfolder.
@ SoniX: Users with an Intel X79 Chipset system and an Intel RAID0 array may not really need a TRIM modded Intel RAID ROM or EFI RaidDriver module, but the insertion of a TRIM modded module does not harm the system at all. According to Intel only Intel Chipsets from the 7-Series up natively do support TRIM in RAID0. The X79 Chipsets belong to the C600 Series Chipsets, which are at least 6-Series ones. On the other hand do the Intel RST RAID ROM modules v11 and up contain the TRIM in RAID0 flag, which indicates, that they do support this feature (look >here<).
I’m quoting you to clarify something related to this. Let’s say i update those RAID modules to version 13.1.0.2126 as you mentioned. Do they support TRIM? Are they TRIM ready?
My question comes after i’ve read some posts of yours and your members here yesterday, i got confused. I wanna make sure that if i update them i won’t get in trouble if someday i want to change to RAID mode.
It depends on the Chipset of the user’s mainboard and on the RAID configuration:
TRIM in RAID for SSDs, which are not a member of a RAID array, is natively supported for everyone, provided that an Intel RST or RST(e) driver is running.
The extra feature "TRIM in RAID0" is natively only supported by modern Intel Chipsets from 7-Series up. Older Intel RAID systems from ICH8R up to 6-Series Chipsets need a TRIM in RAID0 modified Intel RAID module within the BIOS. Otherwise TRIM will not pass through the Intel SATA RAID Controller into the RAID0 array.
So the TRIM in RAID0 support of the original Intel RAID modules depends on the special Intel Chipset of the system. If you are unsure, whether your chipset supports TRIM in RAID0 or not, you can insert the modded variant of the Intel RAID module(s). It doesn’t harm its functionality.
This picture is all manufacturers. On my Asus Z87-Plus (i217-V) DavID in OROM 1503, in OS Win7 - 15b3. But it is not critical and is not a problem. In UBU setting OROM taken from data CSMCORE.
Edit: If we look the rules of filling DevID, the manufacturers are wrong. In any case, everything works without problems.
…works without Problems, yes ~99%, when i set Settings default, no Problem, when set secure boot, Default Bios or modbios with ubu, Bios can not connect to asrock Server (search to new Bios), have here (Forum) a modbios P2.30 with ID15A1 and have no Problem btw. this Error notification, had already want to ask you earlier to this Erratum, but forgotten.
Edit: If you enable Secure Boot, then you use UEFI mode. In the UEFI mode, the OROM are not used. Then your problem is in the file EFI LAN. What is your version of EFI LAN? Which version UBU you used for modifying?
@lordkag I have a question. Necessarily it is necessary to update module HiiDataBase from AMD RAID? It rarely is, in BIOS and I think that it is better to leave as is.
I know this problem. The problem will be fixed in the next release. But there is a serious problem. We can not understand the work EFI LAN driver version 0.0.07 on chips 82579/i217/i218. If the version 0.0.07 is not working, it is necessary to return the version 6.6.04. But so far no one checked. On my motherboard Asus Z87-Plus it looks like this:
In short, my suggestion is to keep it and update it when it is found. But here is the long story. As you can read here or here or EDK2 implementation, the file has nothing to do with AMD or RAID. If AMD needs to add a RAID menu to the UEFI setup screen, if should probably use handlers like EFI_HII_DATABASE_NOTIFY_ADD_PACK and EFI_HII_DATABASE_NEW_PACK. Why it doesn’t do that, I don’t know. Maybe the implementation of UEFI at that time was too buggy or the results were not predictable on all platforms. You can see that they also added SCSIBus and SCSIDisk, which normally should be compiled by OEMs. So keep all the files that AMD provided and update them when found. As you have observed, HiiDatabase is rarely found and it is even marked as optional by AMD.
The trick part is that Intel platforms also have Hiidatabase, SCSIBus, SCSIDisk - so you must be careful when you update them. I have added the known GUIDs to Extractor, but I can’t say for sure which are the good ones. The safest bet is to search for AMD RAIDx64, it always has the same GUID C468B382-4550-4909-AD57-2496141B3F4A, so only in this situation you can update the other 3 EFI drivers. This is what I did in Extractor to remove the false positive for both AMD and Intel, as I noticed that Hiidatabase, SCSIBus, SCSIDisk have little to do with Intel or AMD.
In the next version UBU will be able to choose the version EFI Intel LAN
Edit: Files EFI Intel PRO/1000 LAN UNDI v6.7.xx and 6.8.xx support only i210/i211, and not support 82579/i217/i218 network chips New file EFI Intel Gigabit LAN UNDI v0.0.07 support 82579/i217/i218, but why that not support i210/i211 chips Version EFI Intel PRO/1000 LAN UNDI v6.6.04 - It supports all the chips.
I have been using the UBU tool for quite a while now and I have WDS and use PXE to install my OS’s on my Desktop machines.
Recently have done a lot of testing into why my Gigabyte boards, some of them installed in UEFI mode and some in Legacy mode. I seemed that the Z97 modded ones with Atheros would boot from UEFI fine but the Z87 modded ones with Intel would not, only Legacy would work.
Your very latest UBU v1.29 Beta1 fix (Beta Version) however fixed all that by not updating the EFI part of the Intel code, going back over some of the previous versions, yes both the v0.0.07 and v6.8 definitely did not work for i210/i217 board, did not think to try any earlier, just the built in EFI Intel PRO/1000 UNDI - 5.1.00 worked the best so far.
Anyway, sounds like all the above reflects the same as what you have noted, keep up the great work
