@dragonsun252 you can download it from here tinyurl.com / y4h79tcm
@dragonsun252 I am using stock X99-II BIOS v2101
Thanks for your great support!!
@dragonsun252 , I have this BIOS and nvram does not work for me, help me please
Here is the patched bios for Asus X99-S Motherboard, version 3801, with microcode and lan driver updated
http://s000.tinyupload.com/index.php?fil…851768625553316
Can you latzease make patched bios for asus x99 deluxe ii v2101?
Would really appreciate it
@latzease Is it Asus X99-A mod bios is similar for X99-A II? Any chance to get the X99-A II modded bios?
@@latzease you are a truly Savor for us Asus Motherboard owners
Thank you so much
I will try, then I will give you feedback
really appreciate It man
@Lost_N_BIOS , I believe @dragonsun252 is busy. Do you have any hints how I can make our the X99-A II mod bios? But, I am afraid my skill is capable to do it
Thanks,
Can this be re-uploaded somewhere else, because tinyupload is down. I am at the same situation that the installation of big sur is always restarting.
I would be grateful for any help with the Asus X99-AII on how to make NVRAM work. Like many others I am stuck with Big Sur installation on this MB
Hi guys,
TL; DR @dragonsun252 is there any way to repost the patched BIOS .cap file 4001 for x99e-ws? I can’t seem to download it.
I also have an x99e-ws board and I’m trying to setup opencore. I have a 5960x and a Radeon VII card in there, the rest is standard. I have the MSR unlock on my current bios but don’t have the NVRAM whitelist.
I’m coming from Mojave 10.14.6 on Clover - this is my first opencore install. I couldn’t get Catalina on clover.
Does anyone have an EFI for my setup or similar I can use? I’m downloading the latest kexts but it would be nice to have a reference to look at, especially for any CPU patches - I don’t even know what I need this time.
Thanks, I appreciate any help, I can post elsewhere if this is beyond the scope of this thread.
bump
Hi friend,
here is the Patch , if you can do , otherwise i will do for you :
https://www.tonymacx86.com/attachments/e…her-zip.502882/
Let me lnow Regards
Thanks so much for this. I did the patch to x99e-ws.cap to add Nvram unlock to my previous custom 4001 build bios. I was able to load the bios fine with flashback (I updated the .cap header as well, though in the GUI it said it was invalid).
I’ll try the install tonight- hope it goes well! I find the 5960x kernel patches to be hit or miss, so I’ll let you guys know what works.
Thanks for sharing the patch.txt, that was really helpful.
Can someone please share the latest 4001 BIOS for Asus X99-E WS (not USB3.1) patched for MSR and NVRAM ? None of the tinyupload links work. Thanks.
