Yes, that is my only guess why this can’t work, not all boards are able to use unlocked ME/Bclk overclock etc.
This had nothing to do with CPU multipliers though. We may need to find correct microcode version and maybe newer ME for that CPU, I am not sure, you will need to research and see what others did to add full compatibility
I see more duplicated mc?
thank you lst n bios for all support, but I have an idea if we took a bios from a another laptop with the same processor i72860qm and extract the bios to view what me has and microcode ? because a see an laptop Lenovo with i72860qm but it go at 2.9ghz here http://valid.x86.fr/7mi54j but a lokk an alien model we could do something?for example to extract from that model me and microcode and use it on this bios
Hi. Someone is looking here?
I need microcodes modification to overclock Haswell ES QDE4 on Gigabyte B85 D3H Rev1.0/1.1
More here
[Help] Bios for z97 extreme6 can run QDE4 es cpu (2)
Please help
with this microcode for xeon lga771 mod: cpu1067A_plat44_ver00000A0E_2015-07-29_PRD_A3107D75.bin
I received this message at boot bios post
@pipes80 If you are using BIOS from post #302, that is a problem, should not be duplicated so many CPU microcodes (Should be zero duplicates). This means usually incorrect cbrom used
For the Xeon microcode and image, did you insert all the other 1067A platforms? For current 2015 1067A I insert 44 which you mentioned (Covering 2,6) and B1 which covers (0,4,5,7)
only insert platforma 44 for 1067a, but i have remake the bios and work fine
I see you mentioned that at overclock.net, glad you figured it out.
Hello Fernando, I have the Asus P5KC v1.03 card. At this board I installed xeon 5470. My bios is without AHCI support but after I searched google I found some bios that gives me this ahci support but they still get type errors
’’ Unknown cpu is detected. updating BIOS is required to unleash its full power, cpu over temperture error ‘‘
I use bios [1203 ahci] or [1303 ahci with support for SLIC v2.0]. Please look a little over these files can find the error and fix it. check if microcodes are the last ones added. I need ahci support because I use …OSX’’ hackintosh. P.S. I have an ASMedia 106x card but I still can not support ahci for hackintosh even if I installed a ssd in it. thank you. Other cpu woks fine like Q6600.
I had take same problem, have reflash the bios with different microcode and had solved
@EDECAT :
Since your request has nothing to do with the topic “Modded Intel AHCI drivers”, I have moved it into this better matching Sub-Forum and thread.
Hopefully you will get support by a CPU microcode expert.
@pipes80 :
Just for your information.
@EDECAT - which BIOS do you want updated microcodes in, 1203 or 1303?
1203 and 1303, thanks
@EDECAT - Please pick one, this is time consuming J/K both included
http://s000.tinyupload.com/index.php?fil…959354949455248
https://www.sendspace.com/file/q5orjm
Fernando, whats?
hi lost n bios can you extract the microcode from a bios and put in the Toshiba bios 3.60 because I I found a bios from another laptop Toshiba but with diferent microcode can you do this? will send you the bios Toshiba 3.60 and the bios I wiil rename code extracted bios THANK YOU https://www.sendspace.com/file/wd8il6
@juanete - Yes, this can be done, but what microcode exactly do you need changed over, or updated? I do not need donor BIOS, only what BIOS you want edited, and tell me which microcode CPUID you want updated/changed to what version (or latest version)
the cpu id MICROCODE I want to update is 206A7 but UPDATED TO REV 14 BECAUSE NOW HAS 28 I think ,NOW I HAVE INSTALED I7 2860QM WITH THIS CPUID 206A7 AND I WANT TO CHANGE THE microcode version because the processor is wont go up than 2.7ghz when all core are on full speed at maxim and at maxim should be 3.3ghz all core I will ssend you the bios dump up with CH341A_130 program https://www.sendspace.com/file/cvt5c4 an if you can make another version with cupid 206a7 with Rev. 0x29 finily two bios with two diferent rev. one with rev 14 and another one with rev ox29 all two with cupid 206A7 THANK YOU
Will do tonight @juanete - you may need to do other mod (unlock MSR 194), you may also need updated ME FW, are you already using latest ME FW?
yes i remember that i use the latest me firmware and you did the modify with the me firmware to unlock the overcloking but with that firmware unlocked with overcloking wont boot the laptop on the page 20 we towlk about me frimware but with this unlock MSR 194 i dont remember if you make it what is that?thank you
