ok then means we cant do anything ?you have another solution?
I am trying to figure out how to change Always Low to Always High, but so far with blind changes (Guessing) Iβve not had any luck. I need BIOS from this company or at least an Insyde BIOS, that does include Always High as option, maybe you can find via Google (Dynamic Always High + Toshiba or Insyde)
Then once you are sure someone said itβs in their BIOS, give me the model and I will look. I looked around earlier but wasnβt able to find good assurance by anyone it was there, will keep looking though
That one is same, only Dynamic switch or Always low
yes ,but this bios has some options that we are looking for a long time like powerxpress for intel gpu and muxing and something about turbo custom I will send you the dump and some fotos ,I installed this bios with programmer but wont but https://www.sendspace.com/file/9wgztv
Ohh! Sorry, I didnβt even look about anything else, only Dynamic weβve been looking at this week You already have SG Graphics setting in stock BIOS, but you donβt have the one above that βSpecial Featuresβ = enable switchable graphics (Redundant, both of those settings literally mean SG?!?!)
PowerXpress weβve been missing, good catch! All that configurable TDP stuff may help you too. So what happened, you programmed this BIOS, but it doesnβt boot or what? Is board itβs from similar layout to yours? If it is, we could try swapping in the setup module.
the board its not the same but I tried the bios I I disabled some things to make it the same like the 3.60 BIOS BUT NOT WORKING ,its posibile its not compatibile with ec firmware the l850 bios has a ec firmware with 2.1mb and the 360 bios has 512 kb EC firmware and I tried with two formware but doesnβt work ,only if you lokkk in bios to see what we can modify on 3.60 to had these options
Sorry to ask again, but do you have flash programmer? If yes, we can try module swap (Setup), and see if that works OK for you. Dynamic CPU will still be same.
yes i have flash programmer ok
@juanete - thanks, I will try to remember and not ask again
here, try both of these and see if you can boot and access BIOS settings - http://s000.tinyupload.com/index.php?filβ¦227659683531328
I test the two bios ,the first is boot in windows but wont let me in bios setup when I press F2 to enter in setup gets bloked,and the second is power the laptop but nothing appears on the screen and the cooler is working high then low thank you
The one that boot in windows, which was it? Did you test switchable graphics to see if it was enabled?
I tested the two bios with disable switching graphics and the bios that boot in windows but gets blocked when I press f2 to enter setup bios is BIOS 3.60-194-L850Setup-EZH20Edited
You wanted to enable SG not disable, but yes, in order for that to work we may need to change the default PowerExpress setting I canβt remember what it needed to be set to. But yes, itβs a problem if you canβt even enter BIOS, so thatβs a no go anyway.
Main thing we need to find right now though is BIOS with Dynamic setting >> Always High. No point in working on trying to find a way to make this work, SG graphics is secondary in your concerns behind getting higher CPU multiplier correct?
yes ,the cpu multipler is most important because the turbo boost wont working at maxim speed
Can you find Any Toshiba someone says Turbo is working properly, that BIOS might have Dynamic - Always high
What is the latest microcode for Sandy Bridge?
this latest version - cpu206A7_plat12_ver0000002E_2018-04-10_PRD_576F65DE.bin?
Laptop lenovo G770
β Intel β
βββ¬ββββββ¬ββββββββββββ¬βββββββββ¬βββββββββββ¬βββββ¬βββββββ¬βββββββββ¬βββββ’
β#βCPUIDβPlatform IDβRevisionβ Date βTypeβ Size β Offset βLastβ
βββΌββββββΌββββββββββββΌβββββββββΌβββββββββββΌβββββΌβββββββΌβββββββββΌβββββ’
β1β206A7β 12 (1,4) β 25 β2011-10-11βPRD β0x2400β0x351000β No β
β2β206A6β 12 (1,4) β 28 β2010-09-15βPRD β0x2400β0x353400βYes β
β3β206A5β 12 (1,4) β 7 β2010-07-22βPRD β0x1C00β0x355800βYes β
β4β206A3β 12 (1,4) β 8 β2010-05-26βPRD β0x2400β0x357400β No β
β5β206A2β 12 (1,4) β 26 β2010-02-17βPRD β0x2400β0x359800β No β
@fender - that may depend on your CPU/CPUID - latest are all here in the repo - https://github.com/platomav/CPUMicrocodes
The one you mentioned is latest for 206A7 CPUID
lost where did you see that? what bios have dynamic always high?
