I have a Dell OptiPlex XE2 with latest bios A26 and ME disabled “3”.
I want to enable ME and I am able to flash ME region and unlock FD *service jumper on the board).
I need a .bin file like in this thread Optiplex 7010 and VPro/AMT/ME (9)
Can anyone help me to unlock ME/AMT on Dell XE2?
Thank you in advance
@se88as - Put on jumper, then boot to windows, shut down and reboot back to windows, then do as outlined below and send me your entire BIOS dump (it’s easier to edit this way, vs ME FW only which I mentioned to dump in PM
Check BIOS main page and see if ME FW version is shown, if not then download HWINFO64
Then on the large window on left side, expand motherboard and find ME area, inside that get the ME Firmware version.
Once you have that, go to this thread and in the section “C.2” download the matching ME System Tools Package
(ie if ME FW version = 10.x get V10 package, if 9.0-9.1 get V9.1 package, if 9.5 or above get V9.5 package etc)
Intel Management Engine: Drivers, Firmware & System Tools
Once downloaded, inside you will find Flash Programming Tool folder, and inside that a Windows or Win/Win32 folder.
Select that Win folder, hold shift and press right click, choose open command window here (Not power shell).
At the command prompt type the following command and send me the created file to modify >> FPTw.exe -d SPIBackup.bin
If you are stuck on Win10 and cannot easily get command prompt, and method I mentioned above does not work for you, here is some links that should help
Or, copy all contents from the Flash Programming Tool \ DOS folder to the root of a USB Bootable disk and do the dump from DOS (FPT.exe -bios -d biosreg.bin)
https://www.windowscentral.com/how-add-c…creators-update
https://www.windowscentral.com/add-open-…menu-windows-10
https://www.laptopmag.com/articles/open-…ator-privileges
Or here is simply registry edit that adds “Open command window here as Administrator” to the right click menu
Double-click to install, reboot after install may be required
http://s000.tinyupload.com/index.php?fil…134606820377175
Check PM.
Thank you for your support
Yes, replied, hopefully that sorts it out for you. If so, please go ahead and re-upload that ME FW only part and attach here, for the next guy with this system that searches and find this thread
ME FIRMWARE UNLOCK AMT (from state “3” ME DISABLED to state “1” AMT_DASH_VPRO: DEFAULT).
ME FW OPTIPLEX XE2 UNLOCK
hello every one i need this bin file this link is lost
https://www12.zippyshare.com/v/SEkavTj8/file.html
