on my ubu (latest with the modded ubu.cmd) the bios list screen (the one you posted) appears for a split second and then disappears and shows only this one.
imho its better to see the list also
Could you post your Python version
py --version
and list of packages
pip list
Full removal of Python with Revo Uninstaller 2.5.0.0
Reboot and clean reinstall of Python 3.12.6
Add to PATH etc.
Upgrade pip
pip3 install pltable
pip3 install colorama
Latest UBU.zip (Post 2144)
Working as expected. Seems it is not a trusty upgrade path from 3.10/3.11/3.12 etc. Lots of cruft. Was reporting as iakoboss7 but…
just to clarify, in my case its the first time i installed python, just a few days ago.
I don’t have python installed and it works fine (don’t want to install it just for UBU that I rarely use)
What’s the difference?
Sorry. I have corrected my post, it was iakoboss7 that had the same Python reporting as mine (until it was in fact fixed).
Fixed
UBU.zip (18.2 KB)
For those getting no MCE output:
Clean up Python and install it with
winget install python3
pip install colorama pltable
Tested, and there are even more “Press enter to exit” than before
1 (see 2) each time
Otherwise I have this message after the listing of EFI and OROM, what is it exactly ?
UEFIReplace v0.25.0 will be used.
Thanks for your great work
EDIT : @Gregory_Tumanyan You “mod” the UBU file because @SoniX’s is not up to date ?
I tested the SoniX one (1.80) and I have this error
R - Start replacement
0 - Cancel
Choice:r
[Preparing for replacement]
BIOS file backup
Dummy GUID: GUID replaced
mCode GUID: GUID replaced
[Replacement]
'`for' n’est pas reconnu en tant que commande interne
ou externe, un programme exécutable ou un fichier de commandes.
mCode FFS:
No problem with the one from 1.79
UBU 290924.zip (18.2 KB)
All is goof for “Press enter to exit”
Thanks so much
A post was split to a new topic: [Request] HP EliteDesk 705 G4 sff - AMD cpu mcode mod
I have a problem to download UBU on website mega
Same error for microcode, if it’s the same thing as you (with the SoniX file)
Already reported but no response
since yesterday I’m trying to extract the ami setup with UBU but it continues in the extraction operation creating a text file of over 2 GB
How important is it that microcode follows the same ordering scheme as the original BIOS? The GenUSRmC.bat files seems to order them from highest to lowest, however after manually editing the generation file I get the proper order of the original BIOS.
Gregory_Tumanyan posted while comrade @SoniX is missing
At the end of August, SoniX told me that he had business to take care of in September that would go into October. I’m as sure as I can be that he’ll be back.
Got a problem with UBU_v1_80_a17.
It used to work before, now it’s giving errors. (multiple cmd windows opening then auto closing). The bios file is amd, not intel.
