I tested the latest version of UBU (with the last UBU file from Gregory_Tumanyan) no problem
Thanks so much for your great work
3 small questions with the new UBU
1) At first, there is the message for mmtool, not to be used as version 1.7 or another option
I used it in version 1.7 (well it was by default I believe)
What is the best?
Knowing that I did not install Python, just the mce.py files, etc…
2) In the Network part, why is there a recommendation not to update (It is not recommended) ?
3) In the Microcode part, why is there “Press to exit” every time ?
This window shows mCodes currently present in your bios file. MCE.py outputs into its own window, I have to find a way to pass it into the main cmd window. Until then you have to press enter to close this window.
Ok, I have the same window (no other ones that open) but I have “Press enter to exit” that appears with each choice I make
Which is not present with 1.7x
