@BlackArchon
Recovery in case you get a brick.
Try modd https://cloud.mail.ru/public/3wLX/2F5sCXAvM
Edit:
File removed. Solution found.
Oh you mean if I have a programmer tool? Yes, I do have a CH341A-based one - it has already saved me from several accidents.
Thank you for the BIOS, I will flash it tomorrow.
Can you elaborate what the the cause of the problem was? Did mmtool have an issue with Asrock’s BIOS file?
@BlackArchon
Ok. After flashing the modd BIOS, be sure to report the result - positive or not.
I don’t know yet, but I will look at this situation.
Add:
@BlackArchon
In your case, there is an excessive search for the file with microcodes…
Change your search pattern here:
Before
2
3
4
5
6
7
:cpua
echo;
echo [Replacement]
>> rem set patt_acpu=2455434F44455653
>> set patt_acpu=20............0.80.00............0.......0............0.
After
2
3
4
5
6
7
:cpua
echo;
echo [Replacement]
>> rem set patt_acpu=20............0.80.00............0.......0............0.
And everything will be OK.
PS Then I will add autoselection for the search pattern.
Add:
I cannot get this bat file to work. Windows Enterprise N 2016 LTSB 64-bit
"/f was unexpected at this time"
All I want to do is change the Intel RAID ROM/EFI BIOS module to v15.9.1.3271 on the latest BIOS update for my Asus Maximus Hero X Wifi (So I can install Windows 7)
@b60khansen
1) Run as Administrator or UAC full disabled.
2) To check, disable the antivirus.
I checked on W10 LTSB, there were no problems. Unless posting on the "Desktop".
I was successful at flashing your modded BIOS, thank you.
Important!
Windows Security found "Trojan:Win32/Occamy.C" in MCE.exe file of UBU_v1_74_0_4.rar file downloaded from mega.nz
Important
Use a proper AntiVirus solution. False positive.
DrvVer 0.25.2
- fix GOP 9.0.2001
- fix LX Killer
@all UBU users:
To make it easier for you I have uploaded the latest updated variant of the UBU tool v1.74.0.4 to my MEGA account.
I am currently delaying the release of UBU. Experimenting with the replacement of GOP_VBT for the entire line from HSW to CFL+.
@ALL
Friends, owners of motherboards based on 370 and 390 chipsets, need your help.
If your BIOS has a GOP of 9.0.1082 and higher (official), then you should try to downgrade to 9.0.1080, and check whether all video ports work or not.
We need to understand the effect of the VBT version on the GOP version.
Thanks.
After download of UBU from the developers link my Windows 10 Defender says:
Status: Entfernt oder wiederhergestellt
Erkannte Bedrohung: Trojan:Win32/Occamy.C
Warnstufe: Schwerwiegend
Datum: 02.09.2019 17:14
Betroffene Elemente:
file: D:\Downloads\UBU\MCE.exe
@SoniX : MSI z370m mortar here (DisplayPort + HDMI).
I currently have 9.0.1084 and just found a new BIOS with 1086. what should I do? is there an option in UBU to downgrade or should it be done manually?
@elisw
Thanks!
In UBU:
File from "Files\Intel\GOP\1151\IntelGOPDriver.efi" copy to folder "Files\Intel\GOP\1151v2"
If you select "Video", it should be displayed as 9.0.1080.
Replace, flash and check.
done!
both HDMi and DP are working fine, could enter the BIOS and edit parameters.
Unfortunately I cannot check the DVI port as I don’t have a cable/adapter.
edit: not sure if it is relevant but it takes a bit longer to turn off: screen goes black, no HDD activity but it takes nearly 30 seconds to stop all lights and fan.
Thank you This information is enough for me.
When I update the Gigabit LAN modules of my ASUS Maximus X code board, I get this warning message:
For compatibility of the DevID,
it is possible to install up to versions 6.6.04 and/or 1.5.62
What does it exactly mean? To be complete, here’s what all the text I got:
Network
[Current version]
EFI Intel Gigabit UNDI - 0.0.13
OROM Intel Boot Agent CL - 0.1.10
[Available version]
-\ for i82579/i217/i218/i219 chips
EFI Intel Gigabit UNDI - 0.0.23
OROM Intel Boot Agent CL - 0.1.14
-\ for i210/i211/i350 chips
EFI Intel PRO/1000 UNDI - 8.7.10
OROM Intel Boot Agent GE - 1.5.88
-\ for 10 Gigabit chips
1 - Replace Intel
0 - Exit to Main Menu
Choice:1
EFI Intel Gigabit SubGUID 4953F720-006D-41F5-990D-0AC7742ABB60
parseFile: non-empty pad-file contents will be destroyed after volume modifications
File replaced
OROM Boot Agent CL SubGUID 50339D20-C90A-4BB2-9AFF-D8A11B23BC15
Set Device ID 0x15B8
File replaced
Press any key to continue . . .
@kevindd992002
This is for special occasions. When on board for example 2 networks, and one of them has outdated information about Device ID.
