[Discussion] UBU Tool related Questions/Reports/Suggestions
@aGeoM
Oops! Sorry, I did not pay attention to the build 105 -> 135.
@ALL
People who have 32MB BIOSes and have EFI LAN Intel versions higher than 6.6.04, please post links.
I need to configure file replacement correctly.
Thank.
Intel® I211-AT, 1 x Gigabit LAN Controller(s)
Realtek® RTL8125-CG 2.5G LAN
ROG Strix X570-E Gaming
UBU v1.78.0 b2
- Display all double EFI&OROM files.
- Replacing all double EFI&OROM files
– AMD RAID Xpert2
– Realtek 2.5Gb
LAN Intel later
Added:
File removerd
Get this error replacing RealTek UNDI Driver, but still seems to work though.
1 - Replace Intel
2 - Replace Realtek
S - Share files
0 - Exit to Main Menu
Choice:2
EFI Realtek GUID DEB917C0-C56A-4860-A05B-BF2F22EBB717
parseFile: non-empty pad-file contents will be destroyed after volume modifications
File replaced
‘ser’ is not recognized as an internal or external command,
operable program or batch file.
OROM Realtek SubGUID C0FB2C99-B1BE-430B-A856-5E91DE2CF421
File replaced
EFI Realtek UNDI Driver - 2.053
OROM Realtek 2.5 Gb PXE - 3.01
Press any key to continue . . .
replace ser for set line 1134
Fixed "ser"
As you expected:
Thanks.
UBU v1.78.0 b4
– AMD RAID Xpert2
– LAN Realtek 2.5Gb
– LAN Intel
Edit:
File removed. Wait release/
@SoniX :
I just have tested the UBU tool v1.78.0_b4. Result: The BIOS update worked flawlessly (not yet flashed). That is a big success!
Here is the final Picture:
goodwork, with this last ubu microcode amd zen 2 can update microcode, now i awnt find a guide to update bios from my tuf x570 gaming plus
@SoniX :
Flashing of the modded BIOS by using the Flashrom tool was fine as well.
From my side you can publish the updated UBU tool v1.78.x for everyone.
@Fernando
Thank you :slight_smile:
A bit later.
@Fernando
A Flashrom tutorial showing your methodology for the more “adventurist types”?
ie. internal vs external methods
@hancor :
Interested UBU users can find my short guide about how to use the tool named Flashrom >here< within the chapter “Guide for ASRock Mainboards”, but it will work with other mainboards as well.
Once you have created the bootable DOS USB Flash Drive, the flashing procedure is very simple.
I think these are new (?):
EFI Intel VROC with VMD 7.5.0.1030
RaidOrom 7.0.0.2008
sSataOrom 7.0.0.2008
files.rar (148 KB)
@plutomaniac
Yeah, the new version. Just why 3 files?
VROC with VMD consists of two files.
Ah sorry, I thought the 2nd efi was junk before. I haven’t been looking for BIOS modules since 2016 so I’m out of the loop.
Extracted.rar (188 KB)
@plutomaniac
Now everything is correct.
If it’s not difficult, then discard this BIOS in the PM, I will look at the EFI files. And then it’s strange - the OROM is present, but the EFI is not.
Thank. :))
Hello
Thanks to @plutomaniac for the files
I tried to update EFI Intel VROC with VMD with the new version (7.5.0.1030), but it’s still the old version (6.2.0.1034)
An idea ?
Thanks
