Use 6.3.0.1005 instead master tistou77
@Santa2017
Thanks, but I don’t have this version for "EFI Intel VROC with VMD"
And version 7 is newer
@tistou77
To replace "VROC with VMD" option is used:
"V - Replace VROC with VMD"
Show the screen replacement and the result.
@SoniX Ah yes, I had completely forgotten, what an idiot
A small suggestion, possible to add next to "EFI Intel VROC for SATA (ID 2826 and ID 2827) to differentiate each “module” ?
Tested and I got errors when launching UBU
Which mistakes?
@SoniX @tistou77 #968
I think you mean this error every time UefiFind is used in UBU
I’m using Windows 7 x64
Yep, continous out of range errors…
EFI Intel Gigabit UNDI - 0.8.06 (from B460)
OROM Intel Boot Agent GE - 0.4.09 (from Z490)
OROM VBIOS Cezanne - 017.010.000.015.000000 date_03/04/20 (new item)
OROM VBIOS Picasso - 016.002.000.011.000000 date_09/02/19 (>016.002.000.010.000000 date_04/25/19) strange, but newer than 016.002.000.011.048929 (date_08/23/19)
OROM VBIOS Raven - 016.002.000.011.000000 date_09/02/19 (>016.002.000.010.000000 date_11/05/18)
OROM VBIOS Raven 2 - 016.002.000.011.000000 date_09/02/19 (>016.002.000.010.000000 date_01/03/19)
OROM VBIOS Renoir - 017.010.000.015.000000 date_03/10/20 (new item)
@SoniX
pack.rar (208 KB)
Thank you for OROM VBIOS. I will add.
These versions are supporting i225, support i210/211/350, etc.
So far, as a beta version, since there is no official release in "Intel Network Connections Software" package.
Added:
Until the name of the new EFI LAN for i225 becomes clear, in UBU Drvver will be defined as PRO2500.
Since the driver inherits PRO1000 + i225 support.
DrvVer v0.27.3
- Fixed Intel GOP IceLake
- Fixed Intel VROC v7 and v8
- Displayed Intel LAN PRO2500 for i210/211/225/350 etc/
[Discussion] UBU Tool related Questions, Reports and Suggestions (66)
Thanks
Are those the ones extracted by plutomaniac ?
Not found on your Mega link
Yesterday, you had not posted a more recent version of the drvVer file ?
I thought I saw that
OoPs! Sorry.
DrvVer v0.27.3
Edit:
File removed. As part of UBU 1.78
@SoniX
Can u please verify if the OROM RSTe is properly updated (manual update) in this bios???
https://mega.nz/file/gn5igYRK#NlIsYOqHOJ…xHl1ADuKgVOwflo
About RST(e) orom, I can’t remember why UBU can’t update them
