[Discussion] UBU Tool related Questions/Reports/Suggestions
Is this normal? Another branch?
EFI_Intel_PRO1000_UNDI_8.5.21.rar (132 KB)
@westlake
This is a bug in the script. Line 1003 Skipped && after Replace before Extract
And these?
BIOS fille
BIOS file (and try to update Realtek items… quit to desktop)
BIOS file
Sorry… :slight_smile:
@westlake
1) LAN Intel 2.5G (i225) not supported until official releases are published.
2) Fix d UBU.bat
OROM RTK
1
2
3
4
:orom_repl
[UP]set repl_ok=0
cecho {0E}OROM in GUID %1{#}{\n}
But OROM RTK and Intel in this BIOS can only be replaced manually, since it is a composite FFS of 3 RAW(OROM),
EFI AMD GOP Driver - 2.14.0.0.17
EFI AMD RAIDXpert2-Fxx - 9.3.0-00221
OROM VBIOS Cezanne - 017.010.000.027.000000
OROM VBIOS Renoir - 017.010.000.027.000000
EFI_AMD_RAIDXpert2-Fxx_9.3.0-00221.rar (124 KB)
EFI_AMD_GOP_Driver_2.14.0.0.17.rar (40.4 KB)
OROM_VBIOS_Cezanne_017.010.000.027.000000.rar (32.7 KB)
OROM_VBIOS_Renoir_017.010.000.027.000000.rar (32.5 KB)
How do I extract the .dat files from the .bin in the VBIOS files to use with UBU Tool?
Out DrvVer 0.28.3
- AMD GOP Driver 2.14.0.17.10
VBIOS files rename as:
for Renoir - files\amd\vbios\vbios_1636.dat
for Cezanne - files\amd\vbios\vbios_1638.dat
Number is Device ID
the New EFI intel LAN 1.00 gives me better ping on Modern warfare i dont know why!!nice
BIOS file
BIOS file
@westlake
You only need to attach the original files.
Added:
I’m only interested in the original BIOS for SuperMicro.
Since versions 6.7.xx+ are not compatible for 82579/217/218/219, but they are. I wonder why.
SoniX, error in script UBU.
I check it, but EFI driver cnanges in BIOS really.
Thank you @SoniX for the new update, microcode replace is working now, but i found another bug. With 1.79.10 i can replace AMD GOP, but in 1.79.11, i got file cannot be opened error. Same FM2A75 Pro-4M 2.60 bios.
PREM1Z, we know about this bug, read earlier msgs.
You can choose 1, change EFI GOP driver and it will change
What about this new efi rom? Where I could find it?
“Can’t open file” for AMD GOP Driver.
This is my joint.
In folder “Files\AMD\GOP\v1” rename the file 1AMDGopDriver.efi as AMDGopDriver.efi
I renamed this file for tests by mistake.
I do not advise replacing LAN Intel without special need.
Newer versions of EFI are not always compatible with old BIOS.
And in general OROM and EFI for LAN do not play any role in OS.
I’m uploading an archive with a few UBU detected modules. Check if something is new.
ubu.rar (535 KB)
The updated UBU Tool includes these or do I need to manually ad them? @SoniX
@@plutomaniac
Something that is, for example, TGL 1046. It is necessary to correct DrvVer.
Everything else was already there.
@KedarWolf
EFI AMD GOP Driver - 2.14.0.0.17 - there is no such version, only 2.14.0.17.10.
All other files are already included.
Thank you! Working now, really appriciate your work, awesome tool! :slight_smile:
EFI Intel PRO1000 UNDI - 9.0.03 -> 6.6.04
BIOS file
