@svarmod
start for half a second = vcore supplied != instant shutdown because of short circuit. I will report about long time capabilities when that damn SPI finally arrives.
Talking of: On Asrock Z270 Gaming K6 I do not manage to get past IME shutdown problem, even when with HDA mod. I tried both integrated flasher and afudos.
You can share the bios mod, I am also using the mainbroad Asrock H110 BTC pro, thanks !
Hi! Anyone modded ASROCK B250 Gaming K4 with i7-8700, i’ve try with CoffeeTime but failed!!
@vuquanict
Whats went wrong? Did you flash full modbios image? What about socket pins?
svarmod,
I have this board and was considering flashing it so thank you for uploading the BIOS. With this board can I flash this modded BIOS with the built-in flash tool or do I need to use another tool? Thank you.
@Datlore001
Gigabyte Q-flash has some updating restrictions, better use FPT or AFU. There are no any locks on Gigabyte so no problems with these tools.
@svarmod
I’ve flashed with FPTW64 -bios -f bios.bin
This is pin mod.
When insert CPU and power on, system turn off after one second.
Hello, I have Asus z170s sabertooth.
I have a plan 9900k on z170 with h/t.
2202 bios + coffeetime and I got New mod bios.
But "init 16cpus" did not patched.
Is it ok? It will works?
Sorry about poor english. Thanks.
@vuquanict
You flashed only bios region, you also need rewrite ME and FD to i7 starts. Look for info about unlocks in previous posts.
@Er236
Yes, it should work in general, but I recommend to remake mod with latest CoffeeTime version.
Thank you.I will try and post a result.
Thanks to you. I remake mod-bios by lastest coffeetime.
All data patched. I will buy 9900K, and report here later.
Hi everyone, i’m using mainboard Asus B250f gaming and Cpu G3930. I just wanna to use G5400 or I3 8100, but i read this thread is so hard to try. This way is for all mobo, isn’t it? I got the video how to mod bios on youtube for mobo asus h110, it look too easy. Could someone tell me what i need to run G5400, i3 8100 on my mobo asus b250f gaming? I really appreciate it!
This video i get on youtube: https://www.youtube.com/watch?v=FdUSgtlwZZU
shameless selfquote
Rechecked with Gaming K6 and also tried FPT as afudos could not possibly work anyway. Main problem was the HDA mod though, I can not even dump UEFI. Probably the small contacts on ALC1220, though I left impressions in both of them. Has anyone yet suceeded unlocking descriptor on an ALC 1xxx board?
I tried an Asrock B150M Pro4S which much larger ALC 888 package next and succeeded after a couple of tries. Boot and loads up to 4 threads of Prime95 work fine, though the system freezes if I make real use of the 9900K. Don’t know whether this is due to UEFI problems or general capability of this board. (And don’t know either when/whether I will invest time into that issue.)
Hi to all!
I want to ask you how to MOD this bios for I3-8300 CPU. When I connect an integrated graphic card, HDMI slot, it doesn’t work (black screen at startup and reboot). Computer works only with ext graphic card (AMD Graphics).
Desktop board - ASUS ROG Maximus VIII Impact, Z170
M8I Bios
Many Thanks for Your Help!!
@yeumanu
Start tool from attached file on your Asus B250 and write here what ME version reported.
@Koloboks
Upload bios you used.
Intel-SA-00086-GUI.rar (1.12 MB)
Finaly, Today I can run i7-8700ES on my MSI B250 Krait Gaming with based on MSI Z370 Krait Gaming bios.
Special thank to @svarmod
Thank svarmod for reply me. But i can’t find "VBios and BSF Package and MMTool.exe" for download? I will download Four software and try to mod bios. Could you help me to download it?
Edit//
Sorry for my question: I have been created mod bios from "Easy automated Mod tool’s Revlaay" ([TOOL] Easy automated Mod tool for Coffee Lake bios)
Every thing will be done. So could i use UBU to update this new bios to run coffeelake? And another question is i wanna run G5400 on my mobo Giga Z170x gaming 5, or asus B250f gaming, but revlaay say: this cpu must be isolate 2 pin, is it right? I’m newbie, it so hard to try modding software and more modding hardware
hello bro, you bought i7 8700es from Vozstore. Or you’re the owner of that vozstore? Could you tell me what price you get i7 8700?
i bought from that store (5 củ :v)
@yeumanu
If you want to get advices, then maybe you should follow the recommendations?
Check your ME version on both boards with previously attached tool, it takes 1 min.
Sorry for my bad english, Svarmod. This is my ME version on my Giga Z170x gaming 5. It’s too new, isn’t it?
Intel(R) ME Inforrmation
Version: 11.8.50.3425
SVN: 3
