[Guide] How to Use a CH341A SPI Programmer/Flasher
On your question about the BIOS chip image on the software, this is incorrect image, the BIOS does NOT go that direction nor in that socket of the programmer. I assume this is just generic “Hey here’s a BIOS chip on a programmer” and is incorrect, even if you use the ending socket.
I did not write any guide, so I am not sure what image you are referring to? The BIOS or SOIC8 pins, should go into the middle socket (not the rear one as the chip is in your images), and pin one is on the lever side (As you see here in the fourth image in part #3 on page one)
For CH341A, all driver is same, you only need to install once for any/all versions. You want PAR driver (CH341PAR.exe)
Yes I saw your post at #34, and I replied to it at post #36. I have tested these chips in ASProgrammer and it’s detected and programs correctly, I’ve verified this on multiple occasions.
Yes, please stop wasting your time in Win10, it’s a fail for everything except leaving backdoors open for anyone wanting to peer in
@Lost_N_BIOS
I stopped to play with CH341A Programmer under W10 and I got the opportunity to play with a Sony VAIO W7 64bit SP1 system.
Some progress because the BIOS chip is now ‘detected’ but the “MAIN MEMORY” contents does remain “all FF” !!
CH341A Software v1.34 test results:
ASProgrammer v4.0 test results:
Conclusion:
The both tools does detect a BIOS chip, but the both do detect a ‘similar models’ problem:
-> CH341A Software v1.34 does suggest 7 models even if we have selected properly the model MX25L12873F. Why this unuseful suggestion after the proper selection ?
-> ASProgrammer v1.40 does suggest 11 models but the “Find IC” pop up does open with the “IC marking contain:” filled in blank , and does offer no select button.
This does look like a freeze and No Main Memory contents is displayed !
With CH341A Software ALL the Main Memory contents does display FF
So, why this tool does display FF ! The BIOS chip is not a FF filled chip because it does work and boot well !!
Any idea to progress on this very painful “Programmer Tool” validation procedure exercise ?
Thanks for your future comments.
I came across a similar? fault with my old notebook- I couldn’t read the bios chip, a simple old GD25Q32. It took a while until I found out that Samsung had grounded pin 3- IO#2/write protect. Neither a CH341 nor a TL866 plus could handle that: The 866 gave a short circuit warning, the ch341 didn’t say anything but the led went off and the software said “CH341 not connected”.
Disconnected the wire for pin 3 from clamp- everything fine! But I first disconnected the wrong wire (ground,pin 4)- The chip could be ‘read’ just fine but there were only ‘FF’.
Possibly not your problem but maybe worth a check if the motherboard designer had some ideas, too? (Nevertheless did my CH341 never like to write 128 Mb chips...)
@lfb6
Thanks for your interesting experience.
On my side the BIOS chip is very recent as the mboard is a very recent design (ASUS Prime Z390M-Plus).
As you can see on my screenshots posted the CH341A Software does indicate: “Device state: connected”
Device state Connection is quite stable: No alternate red warning ‘not connected’ message with ‘connected’. So, I don’t suspect any ‘bad’ electric contact.
My CH341A Pro Programmer and Clip are also recent.
Do you use a CH341 or a CH341A Programmer ?
Do you use W7 or W10 interface ?
I got a green and a black CH341, both are CH341A, the black one states CH341APro. W10Pro, 1809, 64bit (1709 did work, too- never worried about Win10??). Not reading 128MbChips is possibly software related, never tried newer CH341.exe versions than 1.29, but could today program a Winbond 25Q128FV properly with a CH341A and ASprogrammer 1.3.14.
Yes, recognizing a disconnected programmer is quite easy. But when I disconnected ground (pin4), everything worked fine, "reading" the chip without any complaints but delivering only FFs.
This does confirm the problem is more a hardware problem somewhere and not really a W10 problem.
Do you plan to use CH341A Software v1.34 and ASProgrammer v1.4 for your tests ?
ASprogrammer 1.4 seems to work with both CH341A programmers for Winbond 25Q128FV, too. I think that’s good enough for me…
I never spared a thought on Windows 10 by the way, I always use the programmer/programming software as a normal user (UAC fully enabled) and there was no difference between Windows 7 and Windows 10?
Thanks for the information that for you ASProgrammer v1.4 does work fine under W10 as well as under W7.
On my side I am stuck with no Programmer solution working for the BIOS chip for any of my two ASUS Prime Z390M_Plus mboards.
I didn’t check ASprogrammer 1.4 under W7, I used the CH341A with Software 1.29 and TL866 under Win7.
But: Just to be sure I tried now ASprogrammer 1.4 under W7 in a virtual machine (host W10P x64 1809) and it’s working fine with a DIP8 25Q128FV. I assume that a native W7 would do, too.
Made some experiments, though:
For a DIP8 25Q128FV you can disconnect GND(4), IO3(7), IO2(3)- it doesn’t matter. If you in addition disconnect CLK(6) or IO1(2) or IO0(5) you get everything FF FF (means both chip identification and data).
More interesting, maybe:
If you disconnect CLK(6) or IO1(2) or IO0(5) alone you still get everything FF FF, ASprogrammer14 not complaining at all!
Are you sure that you don't have a contact- problem?
@lfb6
Thanks a lot for sharing your experiments.
You are right I had a contact problem with the Clip Board !!
I do significant progress and finally do succeed today under W10 x64 with ASProgrammer v1.4 as well with CH341A Software v1.34:
@Lost_N_BIOS
I "ll send you a PM about ASUS Z390M-Plus modded BIOS file to use for CH341A programmer.
However, a strange situation because Read/Verify operation does fail with CH341A Software v1.34 and is OK with ASProgrammer v1.40 (test done twice):
So, what Programmer Tool is good ?
Tested with CH341A Software v1.40 the Read/Verify operation is OK under W10:
Nota: I do observe CH341A Software v1.34 Read/Verify operation always does fail at about 50% of the operation. Is it a buffer size limitation bug ?
With my Z390 board I had to use the 1.4 programmer from LostNBios for it to work right. And I used Windows 7 but dunno if it works in Windows 10.
@KedarWolf
With CH341A Software v1.40 Free under W10 interface the Read/Verify operation is OK on my side.
Which Z390 mboard do you tested ?
Z390 Aorus Master. It reads, writes and verifies correctly, and I can boot from the BIOS when done.
I really don’t know, which programmer tool is "best". And: Do you mean hardware or software?
I would never rely on the verify function of the software alone. I program the chip, read it back and compare source- file and the file read from the chip on the PC. (For all Windows versions and back to MS-DOS a simple ‘fc /b source.rom readfromchip.rom’ in a command window will do)
You actually don’t know what happened with these three softwares when you don’t read back the SPI and compare it with the source. When comparing results you should also compare the rom read back from ASp1.4 with the roms read back from both versions of the CH341- programmer. Worst case is that all three are different…
The CH341A is a nice cheap tool, but there is sometimes a lot to worry about (mostly software)!
@KedarWolf
What exact Manufacturer/type/model 128Mbits BIOS Chip do yo have on your mboard ?
I don’t remember. It’s a removable socketed BIOS, but I don’t recall what it was detected as.
My BIOS chip is soldered (not socketed removable) and is a MICRONIX MX25L12873F, so may be very different from yours.
@lfb6
Thanks for your very interesting comments:
So, in my case (ASUS Prime Z390M-Plus) I do keep only 2 software programmer solutions running under W10 64bit v1809 interface :
1) CH341A Software v1.4
2) AsProgrammer v1.4.0
I have triple checked that for the both tools a “Read/Verify” operation is OK
and for the both tools a “Read/Verify/Save” operation does produce identical 16MB .bin saved file (checked with Hex Editor HxD tool v2.2.1.0)
Question: 'You don’t rely on the Verify function of the software alone.'
But, I am not sure to understand your ‘verify’ method:
Does your “Verify” method consist of these successive operations :
1st_Read_IC_Memory => Save ‘File_1’ => Program from the saved ‘File_1’ => 2nd_Read_IC_Memory => Save ‘File_2’ => Compare (HxD tool) ‘File_1’ and ‘File_2’.
‘File_1’ and ‘File_2’ should be detected as identical files via the ‘Compare’ function of HxD tool.
But if the files are not identical you have programmed your BIOS with may be one uncertain file and may be your BIOS is bricked ?
Do you confirm I have well understood your ‘risky’ Verify method ?
Normally I start with a changed bios file I want to flash, that’s my source file. I program it into the chip and if the program says ‘Verify OK’ I read the content of the newly programmed chip again, save it and compare it to the source file once again on the PC.
May be a bit paranoid, but I don’t trust especially the CH341 programmer software too much here. What do you mean is risky?
I understand you check that your changed bios file is well properly programmed into the bios chip.
But if your changed bios file does brick the bios chip contents you have to recover the bios chip contents with a good reference bios file.
So, I assume you have somewhere archived a 100% sure reference bios file for a ‘recover’ operation to avoid the risk to have a definitevly bricked BIOS.
Is it correct ?
Like you, my preference is definitively AsProgrammer v1.4.0 under W10 interface.
Do you use ‘Blank check’ function ? What is it ? What is the purpose ?
When we use “Erase” function it is a “FF” fullfillemnt or a “00” (blank ?) fullfilement with this tool ?
