[Guide] HowTo Unlock a Tongfang Chassis BIOS
@Lost_N_BIOS the light effect are difference,but I will upload the quick bios look video tomorrow
@Lost_N_BIOS
I zipped my lighting effect options inside the bios.
Here are the options:
Disable
Breathing
Wave
Rainbow
Marquee
Raindrop
color.rar (147 KB)
Thanks @cloudstar - Seems like this setting will be an issue for doing all these models blindly (not yours or lunlau’s, but all the others I planned to do), since I need to see this in each system and it seems like all may be different.
Not sure if I can just set both enabled blindly and it’s OK, need someone to test I suppose
Here is your mod BIOS Sorry for the extended delay!!
http://s000.tinyupload.com/index.php?fil…343383627971172
NO ONE else flash that BIOS above, it is user specific, you have been warned!!!
If anyone waiting, I am still doing all mentioned above, mod files will be available shortly for all those models
@Lost_N_BIOS
Sorry I just flashed the file you gave me and it went well, But upon browsing all the settings and after a reboot my laptop went on this mode black screen. Ill attached the picture.
Can you help me how to recover this. I read your post not to switch graphics and I think I didn’t mess with that.
Sorry but can you help me again. Thank You
Image.zip (453 KB)
Sorry to see that! Graphics settings change is the only one that will give you black screen, guess I need to use larger font ? >> You said ā€œI think I didn’tā€ There is no ā€œthink you didn’tā€, only do or do not (Yoda says these are only options)
Don’t worry, you are not alone, this is almost the first thing everyone does for some reason, and 50% of the time w/ laptop this is why people want unlocked and I forget to remind them too, and then they join the pile as well
Nothing you can do now except purchase a flash programmer (CH341A) + SOIC8 test clip with cable. Let me know if you need linked examples at ebay
You can try blind recovery, but you’ll have to adjust this per your packages and probably @pcfr33k will need to look at your stock BIOS package (Post #90) and maybe make you some edited batch file for USB without knowing keystrokes etc.
[SOLVED] How to unlock BIOS options of rebranded TONGFANG chassis systems? (20)
@Lost_N_BIOS
Thank You but my laptop is now fix. I just reset the CMOS Battery and it is working fine now.
See attached picture for the unlock bios menu. Thank you very much for you support.
BIOS.rar (1.35 MB)
@cloudstar - Hot damn, you got lucky, very nice to hear it Maybe you didn’t change anything relating to disabling graphics then
Maybe you undervolted too low, or set memory speed too high etc?? Usually those will reset with clear CMOS, but graphical settings often do not for some reason, and I assumed you changed something there so didn’t even think to mention clearing CMOS.
Be careful now! You’re welcome, and enjoy the plethora of settings to mess around with You can change graphics memory amounts, that’s fine
Hi, I’m excited to see the unlocked way you have written in the pages.
But I’m not sure that this method can be used in my laptop which the series is GK5CP0Z [XMG NEO 15 (ID: XNE15E19)]
I saw you had mentioned this type in #91. (Eluktronics MECH 15 2060 - 20191016T230304Z - BIOS GK5CP0ZN152, now the latest version is 1.53)
But I can’t get more ideas in that reply…
So I wanna know this BIOS can be unlocked by your means?
Here is the website of the latest bios: https://download.schenker-tech.de/package/xmg_neo15xne15e19/
Really appreciate your help! ^^
owwww, I seems that i should @ you =-=
@Lost_N_BIOS
Heya. Can someone Help me with the Unlock of my PCSpecialist Recoil III BIOS?
Its a GK7CP7S with BIOS 1.55
One Problem is that PCSpecialist wont give out the Bios Files.
Does someone have those?
I can only offer a FPT Dump.
@NightStorm1000 - I deleted your other post, no need for same question in two threads, hope you don’t mind
I do prefer to have a copy of the stock BIOS/EC/Flash tool package but it’s not required. Did you look around in google?
I mainly want those in case some user later wants a mod BIOS for this model and they are on older BIOS, then I can give them package to update first.
If you can’t do the edits using the advanced guide in spoiler at first post, here’s where we start
I do not need your FPT dump yet, only after we solve error from step 2 below first, then you make a new dump. If no error at step two, then upload your biosreg.bin file for me.
Check BIOS main page and see if ME FW version is shown, if not then download HWINFO64
Then on the large window on left side, expand motherboard and find ME area, inside that get the ME Firmware version.
Once you have that, go to this thread and in the section ā€œCā€ download the matching ME System Tools Package
(ie if ME FW version = 10.x get V10 package, if 9.0-9.1 get V9.1 package, if 9.5 or above get V9.5 package etc)
Intel Management Engine: Drivers, Firmware & System Tools
Once downloaded, inside you will find Flash Programming Tool folder, and inside that a Windows or Win/Win32 folder.
Select that Win folder, hold shift and press right click, choose open command window here (Not power shell).
At the command prompt type the following command and send me the created file to modify >> FPTw.exe -bios -d biosreg.bin
Right after you do that, try to write back the BIOS Region dump and see if you get any error >> FPTw.exe -bios -f biosreg.bin
If you do get error, show me image of the command entered and the error given
^^ This is important step, don’t forget ^^
If you are stuck on Win10 and cannot easily get command prompt, and method I mentioned above does not work for you, here is some links that should help
Or, copy all contents from the Flash Programming Tool \ DOS folder to the root of a USB Bootable disk and do the dump from DOS (FPT.exe -bios -d biosreg.bin)
https://www.windowscentral.com/how-add-c…creators-update
https://www.windowscentral.com/add-open-…menu-windows-10
https://www.laptopmag.com/articles/open-…ator-privileges
Or here is simply registry edit that adds ā€œOpen command window here as Administratorā€ to the right click menu
Double-click to install, reboot after install may be required
http://s000.tinyupload.com/index.php?fil…134606820377175
@Lost_N_BIOS
Yeah I looked. Nothing found until now.
I contacted PCSpcialist again and asked them to just send it to me.
I currently do not have my Notebook on my but i will be at home in around 2-3 Hours.
I will try the Steps and will let you know then.
Thank you very much for your help.
They all like to act like it’s something special they have, or that it’s hard for them as a reseller ā€œto get the filesā€ from manufacturer. You know they have it all right there and can easily attach to any email/request they want.
Tell them you paid top $$ to get their system, at least they could appreciate your purchase through them instead of someone else by offering you a little support by the means of a stock BIOS/EC FW package, latest/updated or not (hopefully not older though ).
OK, when you get home do as I mentioned above, then we’ll get it unlocked in a hurry Actually, I wont be online in a few hours, but I will get your file later today and have BIOS done for you tonight (17 hours from now, unless I have time this afternoon)
You’re welcome!
@Lost_N_BIOS
So.
I did the FPT Dump and reflashed it.
The Result is:
I’ll send you the Dump over PM. I havent heard back from PCSpecialist yet.
Thanks!
@NightStorm1000 - here is unlocked BIOS, please confirm for me you can also now see new additional Light Effect option at original Advanced.
This is second or third mod I’ve done for these new rounds of Tongfang based systems that have this Light Effect option and not sure why they hide the second set of options from users?
PCSpecialist-Recoil-III-GK7CP7S-NightStorm1000-Mod
Flash it via >> FPTw.exe -bios -f biosregmod.bin
Add Main 2, Adv 2, Chipset, Boot 2, switch Exit/Save&Exit + Unsuppress secondary Light Effect @ OG ADV (And other settings too)
*** WARNING *** - This BIOS is user specific! If you are not user NightStorm1000 at Win-RAID.com forum, DO NOT USE THIS BIOS!!
If you do, and you are not NightStorm1000, then you will loose your serial, UUID, OG NVRAM, and possibly LAN MAC ID as well.
You have been warned!!!
If you need unlocked BIOS, please make a request and provide your BIOS region dumped by FPT
Thank you so much. It works flawless.
Finally I can set all my Underclock and Undervolt Settings in BIOS.
@NightStorm1000 - You’re welcome And thanks for your quick test and report back!
@Ziliang - Sorry, I missed your post until now! Do you still need help unlocking your BIOS? If yes, let me know and we’ll get started
Yes, I have waited for your reply.
But I still get no tips of the BIOS document, So how can I modify it?
@Ziliang - Do you have 2060 one or 2070? I already unlocked 2060 one, but BIOS 1.52, so if you have 2060 and using 1.53 BIOS I’ll have to do again.
Please confirm which exact model you have, and then I will get it’s stock BIOS. From you, I also need you do the following (don’t send me FPT BIOS region file, unless you can do second step without error)
If there is error at step #2, first I’ll show you how to unlock, then you will make a new biosreg dump and send to me
How to modify yourself, general method is shown at post #1 of this thread, but other changes may be required, I’d have to see BIOS and let you know.
I know on 2060 1.52, two other edits not shown in post one are required, but only if you want a secondary Main to be visible.
