@bundyboy
for XP
bootloader path: \ntldr
for USB 3.0 try
https://www.win-unattended.de/Benutzer/F…5.3%20WHQL.rar
try nvidia.com or amd.com for GPU driver
try realtek.com for lan driver
@infuscomus :
Hi,
Ok. i will try them now.
but it’s weird that USB 2.0 is not working also. as my motherboard has two USB 2.0 ports, and all other ports are USB 3.0…
my motherboard is Asus PRIME A320M-K
in fact I only need USB drivers, nothing else.
tnx
@bundyboy
what they don’t tell you nowadays is that USB 2.0 ports are connected to the USB 3.0 controller on the motherboard, so you still need the USB 3.0 controller driver to use the USB 2.0 ports.
@infuscomus :
ok ![]()
i am going to try this drivers for usb.
can you suggest also some other ?
tnx
Drivers for usb not working ![]()
What can i do now ?
@bundyboy
can you grab the Hardware IDs for your USB 3.0 controllers?
@infuscomus
yes.
here are screenshoots from windows 10:
Also if I can’t find the drivers at all…
can I buy this: https://www.aliexpress.com/item/32999965…rchweb201603_55
this PCI Express has own controller and everything, right ? as is says that it works with windows xp.
so in other words i need only to connect it to motherboard ?
tnx
@bundyboy
the 43BC controller should work with the 1.0.5.3 driver I mentioned earlier.
for the 145F controller there is this hacked etron driver that might possibly work (i have not tested it for myself)
that pci-e card should work for XP, i think it uses a VIA chipset.
etron_hacked.zip (278 KB)
@infuscomus
i will try this driver now.
and as for pci-e card, it says: Support Windows XP / Vista /Win7/8/10 Server 2008 or later
so in worst case i will buy this pci-e card
tnx
@infuscomus
i have successfully installed the usb drivers with 1.0.5.3 driver you mentioned earlier.
I only needed unistall usb devices from device manager, and again install drivers. now they are working ![]()
also if you can suggest maybe driver for XFX RX 570 8GB GDDR5 ? i have full hd resoultion, but without driver,
it lags when i move window from point to another…
I want to thank you again for your help
@bundyboy
you can try the R9 270 drivers for XP, but I doubt they will work.
https://www2.ati.com/drivers/13-12_xp32_dd_ccc.exe
you would have better luck with an nvidia GTX 980 - they work if you add the ID to the inf
GTX 1000 and later do not work
@infuscomus
so actually i can try latest amd drivers for xp ?
thank you
@bundyboy
you will need to add your RX 570 Hardware ID to the inf file
@infuscomus
Hi,
please tell me do you know why is this happening ?
please see: Why I get this error: No DLLs were found in the Waterfall procedure
we receive this error on new computer with your modified windows xp sp3.
while on old pc with win xp sp3, we dont receiver this error…
what could be a problem ?
and do you know maybe where is stored the default installation folder for Intel® Integrated Performance Primitives - IPP ?
Thank you
@bundyboy
can you grab the missing files off of the old PC?
@infuscomus
but i cant find them…
on old pc with win xp sp3, I cant find this files.
Also for example if I go to control panel - add/remove programs
there it says that Intel IPP is installed…
it should be in C:\Program Files\Intel\IPP<br />according to this: http://registrationcenter-download.intel…de_win_ia32.pdf
but this folder or something similar does not exist, although it is installed.
can you tell me how to find installation folder or files ?
also do you know why on new pc with yours modified windows xp sp3 wont work ?
Thank you
EDIT by Fernando: Unneeded blank lines and one of the 2 “Thank you” removed (to save space)
@bundyboy
make sure show hidden files is enabled
there is a piece of software called search everything - it’s more reliable than windows search for finding exact files you’re looking for.
https://www.voidtools.com/downloads/
@infuscomus @bundyboy
Please stop setting unneeded blank lines. It enlarges each post unnecessarily and decreases its readability.
Thanks in advance!
@infuscomus
ok. i will try that.
tell me do you have maybe modded windows 7 32bit ? or setup will work normally ?
@bundyboy
the installer boots fine, but i haven’t done a full windows 7 install to know if it works.
