-PCI Devices-
Host bridge : Intel Corporation Broadwell-U Host Bridge -OPI (rev 08)
VGA compatible controller : Intel Corporation Broadwell-U Integrated Graphics (rev 08) (prog-if 00 [VGA controller])
Audio device : Intel Corporation Broadwell-U Audio Controller (rev 08)
USB controller : Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03) (prog-if 30 [XHCI])
Communication controller : Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
Audio device : Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
PCI bridge : Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3) (prog-if 00 [Normal decode])
PCI bridge : Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3) (prog-if 00 [Normal decode])
PCI bridge : Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3) (prog-if 00 [Normal decode])
USB controller : Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03) (prog-if 20 [EHCI])
ISA bridge : Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
SATA controller : Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03) (prog-if 01 [AHCI 1.0])
SMBus : Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
Ethernet controller : Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
Network controller : Intel Corporation Wireless 3160 (rev 93)
BIOS Information
Vendor: LENOVO
Version: ABCN80WW
Release Date: 05/18/2015
Address: 0xE0000
Runtime Size: 128 kB
ROM Size: 6144 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Japanese floppy for NEC 9800 1.2 MB is supported (int 13h)
Japanese floppy for Toshiba 1.2 MB is supported (int 13h)
5.25"/360 kB floppy services are supported (int 13h)
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
8042 keyboard services are supported (int 9h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
BIOS Revision: 1.80
Firmware Revision: 1.80
Handle 0x0001, DMI type 1, 27 bytes
System Information
Manufacturer: LENOVO
Product Name: 80FF
Version: Lenovo G70-80
UUID: 9F293CB4-0D89-11E5-A961-68F728E55514
Wake-up Type: Power Switch
SKU Number: LENOVO_MT_80FF_BU_idea_FM_Lenovo G70-80
Family: IDEAPAD
Handle 0x0002, DMI type 2, 15 bytes
Base Board Information
Product Name: Lenovo G70-80
Version: NO DPK
Asset Tag: NO Asset Tag
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Type2 - Board Chassis Location
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
Handle 0x0003, DMI type 3, 22 bytes
Chassis Information
Type: Notebook
Lock: Not Present
Boot-up State: Safe
Power Supply State: Safe
Thermal State: Safe
Security Status: None
OEM Information: 0x00000000
Height: Unspecified
Number Of Power Cords: 1
Contained Elements: 0
SKU Number: SKU Number
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
Socket Designation: U3E1
Type: Central Processor
Family: Celeron
Manufacturer: Intel(R) Corporation
ID: D4 06 03 00 FF FB EB BF
Signature: Type 0, Family 6, Model 61, Stepping 4
Flags:
FPU (Floating-point unit on-chip)
VME (Virtual mode extension)
DE (Debugging extension)
PSE (Page size extension)
TSC (Time stamp counter)
MSR (Model specific registers)
PAE (Physical address extension)
MCE (Machine check exception)
CX8 (CMPXCHG8 instruction supported)
APIC (On-chip APIC hardware supported)
SEP (Fast system call)
MTRR (Memory type range registers)
PGE (Page global enable)
MCA (Machine check architecture)
CMOV (Conditional move instruction supported)
PAT (Page attribute table)
PSE-36 (36-bit page size extension)
CLFSH (CLFLUSH instruction supported)
DS (Debug store)
ACPI (ACPI supported)
MMX (MMX technology supported)
FXSR (FXSAVE and FXSTOR instructions supported)
SSE (Streaming SIMD extensions)
SSE2 (Streaming SIMD extensions 2)
SS (Self-snoop)
HTT (Multi-threading)
TM (Thermal monitor supported)
PBE (Pending break enabled)
Version: Intel(R) Celeron(R) 3205U @ 1.50GHz
Voltage: 0.8 V
External Clock: 100 MHz
Max Speed: 1500 MHz
Current Speed: 1500 MHz
Status: Populated, Enabled
Upgrade: <OUT OF SPEC>
L1 Cache Handle: 0x0006
L2 Cache Handle: 0x0007
L3 Cache Handle: 0x0008
Serial Number: To Be Filled By O.E.M.
Asset Tag: To Be Filled By O.E.M.
Part Number: To Be Filled By O.E.M.
Core Count: 2
Core Enabled: 2
Thread Count: 2
Characteristics:
64-bit capable
Multi-Core
Execute Protection
Enhanced Virtualization
Power/Performance Control
Handle 0x0005, DMI type 7, 19 bytes
Cache Information
Socket Designation: L1 Cache
Configuration: Enabled, Not Socketed, Level 1
Operational Mode: Write Back
Installed Size: 32 kB
Maximum Size: 32 kB
Supported SRAM Types:
Synchronous
Installed SRAM Type: Synchronous
Speed: Unknown
Error Correction Type: Parity
System Type: Data
Associativity: 8-way Set-associative
Handle 0x0006, DMI type 7, 19 bytes
Cache Information
Maximum Size: 32 kB
Synchronous
Speed: Unknown
System Type: Instruction
Handle 0x0007, DMI type 7, 19 bytes
Cache Information
Socket Designation: L2 Cache
Configuration: Enabled, Not Socketed, Level 2
Installed Size: 256 kB
Maximum Size: 256 kB
Synchronous
Speed: Unknown
Error Correction Type: Single-bit ECC
System Type: Unified
Handle 0x0008, DMI type 7, 19 bytes
Cache Information
Socket Designation: L3 Cache
Configuration: Enabled, Not Socketed, Level 3
Installed Size: 2048 kB
Maximum Size: 2048 kB
Synchronous
Speed: Unknown
Error Correction Type: Multi-bit ECC
Handle 0x0009, DMI type 8, 9 bytes
Port Connector Information
Internal Reference Designator: J1A1
Internal Connector Type: None
External Reference Designator: Keyboard
External Connector Type: PS/2
Port Type: Keyboard Port
Handle 0x000A, DMI type 8, 9 bytes
External Reference Designator: Mouse
Port Type: Mouse Port
Handle 0x000B, DMI type 8, 9 bytes
Internal Reference Designator: J2A1
External Reference Designator: TV OUT
External Connector Type: Mini DIN
Port Type: Video Port
Handle 0x000C, DMI type 8, 9 bytes
Internal Reference Designator: J2A2
External Reference Designator: CRT
External Connector Type: DB-15 female
Handle 0x000D, DMI type 8, 9 bytes
External Reference Designator: COM 1
External Connector Type: DB-9 male
Port Type: Serial Port 16550A Compatible
Handle 0x000E, DMI type 8, 9 bytes
Internal Reference Designator: J3A1
External Reference Designator: USB
External Connector Type: Access Bus (USB)
Port Type: USB
Handle 0x000F, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0010, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0011, DMI type 8, 9 bytes
Internal Reference Designator: J5A1
Port Type: USB
Handle 0x0012, DMI type 8, 9 bytes
Port Type: USB
Handle 0x0013, DMI type 8, 9 bytes
Internal Reference Designator: J5A2
Port Type: USB
Handle 0x0014, DMI type 8, 9 bytes
External Reference Designator: Network
External Connector Type: RJ-45
Port Type: Network Port
Handle 0x0015, DMI type 8, 9 bytes
Internal Reference Designator: J9G2
Internal Connector Type: On Board Floppy
External Reference Designator: OnBoard Floppy Type
External Connector Type: None
Port Type: Other
Handle 0x0016, DMI type 8, 9 bytes
Internal Reference Designator: J7J1
Internal Connector Type: On Board IDE
External Reference Designator: OnBoard Primary IDE
Port Type: Other
Handle 0x0017, DMI type 8, 9 bytes
Internal Reference Designator: J30
External Reference Designator: Microphone In
External Connector Type: Mini Jack (headphones)
Port Type: Audio Port
Handle 0x0018, DMI type 8, 9 bytes
External Reference Designator: Line In
Handle 0x0019, DMI type 8, 9 bytes
External Reference Designator: Speaker Out
Handle 0x001A, DMI type 9, 17 bytes
System Slot Information
Designation: J6C1
Type: x1 PCI Express x1
Current Usage: Available
Length: Other
Characteristics:
PME signal is supported
Hot-plug devices are supported
Bus Address: 0000:00:1c.0
Handle 0x001B, DMI type 9, 17 bytes
Designation: J6D2
Length: Other
Characteristics:
Bus Address: 0000:00:1c.1
Handle 0x001C, DMI type 9, 17 bytes
Designation: J7C1
Current Usage: In Use
Length: Other
Characteristics:
Bus Address: 0000:00:1c.2
Handle 0x001D, DMI type 9, 17 bytes
Designation: J7D1
Length: Other
Characteristics:
Bus Address: 0000:00:1c.3
Handle 0x001E, DMI type 9, 17 bytes
Designation: J8C1
Type: x4 PCI Express x4
Length: Other
Characteristics:
Bus Address: 0000:00:1c.4
Handle 0x001F, DMI type 11, 5 bytes
OEM Strings
String 1: OemString1
String 2: OemString2
String 3: OemString3
Handle 0x0020, DMI type 12, 5 bytes
System Configuration Options
Option 1: ConfigOptions1
Option 2: ConfigOptions2
Option 3: ConfigOptions3
Handle 0x0021, DMI type 13, 22 bytes
BIOS Language Information
Language Description Format: Long
Installable Languages: 8
en|US|iso8859-1,0
fr|CA|iso8859-1,0
zh|TW|unicode,0
ja|JP|unicode,0
it|IT|iso8859-1,0
es|ES|iso8859-1,0
de|DE|iso8859-1,0
pt|PT|iso8859-1,0
Currently Installed Language: en|US|iso8859-1,0
Handle 0x0022, DMI type 14, 23 bytes
Group Associations
Name: Firmware Version Info
Items: 6
0x003B (<OUT OF SPEC>)
0x003A (<OUT OF SPEC>)
0x0039 (<OUT OF SPEC>)
0x0038 (<OUT OF SPEC>)
0x0037 (<OUT OF SPEC>)
0x0036 (<OUT OF SPEC>)
Handle 0x0023, DMI type 14, 8 bytes
Group Associations
Name: Intel(R) Silicon View Technology
Items: 1
0x0041 (<OUT OF SPEC>)
Handle 0x0024, DMI type 15, 29 bytes
System Event Log
Area Length: 0 bytes
Header Start Offset: 0x0000
Header Length: 8192 bytes
Data Start Offset: 0x2000
Access Method: General-purpose non-volatile data functions
Access Address: 0x0000
Status: Valid, Not Full
Change Token: 0x12345678
Header Format: OEM-specific
Supported Log Type Descriptors: 3
Descriptor 1: POST memory resize
Data Format 1: None
Descriptor 2: POST error
Data Format 2: POST results bitmap
Descriptor 3: Log area reset/cleared
Data Format 3: None
Handle 0x0025, DMI type 16, 23 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: None
Maximum Capacity: 16 GB
Error Information Handle: No Error
Number Of Devices: 2
Handle 0x0026, DMI type 17, 34 bytes
Memory Device
Array Handle: 0x0025
Total Width: Unknown
Data Width: Unknown
Size: No Module Installed
Form Factor: DIMM
Set: None
Locator: ChannelA-DIMM0
Bank Locator: BANK 0
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer: Not Specified
Serial Number: Not Specified
Asset Tag: 9876543210
Part Number: Not Specified
Rank: Unknown
Configured Clock Speed: Unknown
Handle 0x0027, DMI type 17, 34 bytes
Memory Device
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: ChannelB-DIMM0
Bank Locator: BANK 2
Type: DDR3
Type Detail: Synchronous
Speed: 1600 MHz
Manufacturer: 0467
Serial Number: 67141718
Part Number: RMT3170ME68F9F1600
Rank: 1
Configured Clock Speed: 1600 MHz
Handle 0x0028, DMI type 19, 31 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000FFFFFFFF
Range Size: 4 GB
Physical Array Handle: 0x0025
Partition Width: 2
Handle 0x0029, DMI type 20, 35 bytes
Memory Device Mapped Address
Range Size: 4 GB
Physical Device Handle: 0x0027
Memory Array Mapped Address Handle: 0x0028
Partition Row Position: 254
Interleave Position: 2
Interleaved Data Depth: 1
Handle 0x002A, DMI type 21, 7 bytes
Built-in Pointing Device
Type: Touch Pad
Interface: PS/2
Buttons: 4
Handle 0x002B, DMI type 22, 26 bytes
Portable Battery
Manufacturer: -Virtual Battery 0-
Manufacture Date: 08/08/2010
Serial Number: Battery 0
Name: CRB Battery 0
Chemistry: Lithium Ion
Design Capacity: Unknown
Design Voltage: Unknown
SBDS Version: Not Specified
Maximum Error: Unknown
OEM-specific Information: 0x00000000
Handle 0x002C, DMI type 24, 5 bytes
Hardware Security
Power-On Password Status: Disabled
Keyboard Password Status: Disabled
Administrator Password Status: Disabled
Front Panel Reset Status: Disabled
Handle 0x002D, DMI type 26, 24 bytes
Voltage Probe
Description: Voltage Probe Description
Status: Unknown
Maximum Value: Unknown
Minimum Value: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
OEM-specific Information: 0x00008000
Nominal Value: 0.000 V
Handle 0x002E, DMI type 27, 15 bytes
Cooling Device
Temperature Probe Handle: 0x002F
Type: Fan
Status: OK
Nominal Speed: 8192 rpm
Description: Cooling Device Description
Handle 0x002F, DMI type 28, 24 bytes
Temperature Probe
Description: Temperature Probe Description
Status: Unknown
Resolution: Unknown
Tolerance: Unknown
Accuracy: Unknown
Nominal Value: 0.0 deg C
Handle 0x0030, DMI type 32, 11 bytes
System Boot Information
Status: No errors detected
Handle 0x0031, DMI type 39, 22 bytes
System Power Supply
Name: OEM Define 1
Manufacturer: OEM Define 2
Serial Number: OEM Define 3
Asset Tag: OEM Define 4
Model Part Number: OEM Define 5
Revision: OEM Define 6
Max Power Capacity: 75 W
Status: Not Present
Type: Regulator
Input Voltage Range Switching: Auto-switch
Plugged: No
Hot Replaceable: No
Handle 0x0032, DMI type 40, 17 bytes
Additional Information 1
Referenced Handle: 0x000e
Referenced Offset: 0x05
String: PCIExpressx16
Value: 0xaa
Additional Information 2
Referenced Handle: 0x0000
String: Compiler Version: VC 9.0
Value: 0x00
Handle 0x0033, DMI type 41, 11 bytes
Onboard Device
Reference Designation: IGD
Type: Video
Status: Disabled
Type Instance: 1
Bus Address: 0000:00:02.0
Handle 0x0034, DMI type 128, 8 bytes
OEM-specific Type
Header and Data:
80 08 34 00 55 AA 55 AA
Strings:
Oem Type 128 Test 1
Oem Type 128 Test 2
Handle 0x0035, DMI type 129, 8 bytes
OEM-specific Type
Header and Data:
81 08 35 00 01 01 02 01
Strings:
Insyde_ASF_001
Insyde_ASF_002
Handle 0x0036, DMI type 130, 20 bytes
OEM-specific Type
Header and Data:
82 14 36 00 24 41 4D 54 01 01 01 01 01 A5 1F 02
00 00 00 00
Handle 0x0037, DMI type 131, 64 bytes
OEM-specific Type
Header and Data:
83 40 37 00 11 00 00 00 00 00 00 00 00 00 00 00
F8 00 C5 9C 00 00 00 00 01 00 00 00 00 00 0A 00
EE 03 1C 00 00 00 00 00 C8 00 FF FF 00 00 00 05
B4 08 00 00 26 00 00 00 76 50 72 6F 00 00 00 00
Handle 0x0038, DMI type 133, 5 bytes
OEM-specific Type
Header and Data:
85 05 38 00 01
Strings:
KHOIHGIUCCHHII
Handle 0x0039, DMI type 136, 6 bytes
OEM-specific Type
Header and Data:
88 06 39 00 FF FF
Handle 0x003A, DMI type 200, 16 bytes
OEM-specific Type
Header and Data:
C8 10 3A 00 01 02 01 21 01 10 01 3D B2 80 01 05
Strings:
IdeaPad
80FF0065PB
Handle 0x003B, DMI type 221, 12 bytes
OEM-specific Type
Header and Data:
DD 0C 3B 00 01 01 00 02 06 00 00 00
Strings:
Reference Code - ACPI
Handle 0x003C, DMI type 221, 54 bytes
OEM-specific Type
Header and Data:
DD 36 3C 00 07 01 00 02 06 00 00 00 02 00 02 06
00 00 00 03 00 02 06 00 00 00 04 05 FF FF FF FF
FF 06 00 FF FF FF 08 00 07 00 FF FF FF 08 00 08
00 FF FF FF 00 00
Strings:
Reference Code - SA - System Agent
Reference Code - MRC
SA - PCIe Version
SA-CRID Status
Disabled
SA-CRID Original Value
SA-CRID New Value
OPROM - VBIOS
Handle 0x003D, DMI type 221, 12 bytes
OEM-specific Type
Header and Data:
DD 0C 3D 00 01 01 00 02 06 00 00 00
Strings:
Reference Code - Intel Rapid Start
Handle 0x003E, DMI type 221, 26 bytes
OEM-specific Type
Header and Data:
DD 1A 3E 00 03 01 00 02 06 00 00 00 02 00 00 00
00 1D 00 03 00 00 05 00 00 00
Strings:
Reference Code - CPU
uCode Version
TXT ACM version
Handle 0x003F, DMI type 221, 26 bytes
OEM-specific Type
Header and Data:
DD 1A 3F 00 03 01 00 02 06 00 00 00 02 00 FF FF
FF FF 00 03 04 0A 00 1C EE 03
Strings:
Reference Code - ME 10.0
MEBx version
ME Firmware Version
1.5MB SKU
Handle 0x0040, DMI type 221, 68 bytes
OEM-specific Type
Header and Data:
DD 44 40 00 09 01 00 02 06 00 00 00 02 03 FF FF
FF FF FF 04 00 FF FF FF 03 00 05 00 FF FF FF 03
00 06 00 FF FF FF FF FF 07 00 19 00 00 00 00 08
00 2C 00 00 00 00 09 00 03 00 00 00 00 0A 00 01
00 00 00 00
Strings:
Reference Code - PCH - Lynxpoint
PCH-CRID Status
Disabled
PCH-CRID Original Value
PCH-CRID New Value
OPROM - RST - RAID
LPTLp Bx Hsio Version
LPTH Cx Hsio Version
PCH9S A0 Hsio Version
WPTLp B0 Hsio Version
Handle 0x0041, DMI type 222, 14 bytes
OEM-specific Type
Header and Data:
DE 0E 41 00 01 99 00 03 10 01 20 02 30 03
Strings:
Memory Init Complete
End of DXE Phase
BIOS Boot Complete
Handle 0xFEFF, DMI type 127, 4 bytes
End Of Table
