Did you follow my guide (= start post of this thread)? If yes, don’t press F6 when prompted! The “7B” error message indicates the integration of a wrong driver, the “A5” indicates a wrong ASCI support setting. Did you use a clean (= untouched) XP as source? Which driver did you integrate and which one of the listed Intel SATA AHCI Controllers did you highlight?
PCI\VEN_8086&DEV_A282&SUBSYS_310217AA&REV_00 PCI\VEN_8086&DEV_A282&SUBSYS_310217AA PCI\VEN_8086&DEV_A282&CC_010601 PCI\VEN_8086&DEV_A282&CC_0106 ------------------------------ But I’m going to install XP
@qq2348227 : Which is your request/problem? Is the used source ISO file untouched (nothing integrated)? Did you integrate the “Universal 32bit Intel RST driver v11.2.0.1006 mod+signed by me”? What happens, when you try to get XP installed?
virgin microsoft msnd chinese edition winxp with sp3 iso use nLite soft Integrated your registration x86 driver this: c) For all users with an Intel AHCI/RAID system from ESB2 or ICH7R/M up (incl. X79, X99 and 8-/9-/100-/200-Series Chipsets): For all these users, who want to get XP (32bit) installed in AHCI or RAID mode, I recommend to download and integrate this modified v11.2 RST driver (the regular Intel RSTe driverpacks will not work for all users): >Universal 32bit Intel RST textmode driver v11.2.0.1006 mod+signed by Fernando (latest variant)< (>MIRROR<) ------------------------------------- nLite soft select A282 F6 AHCI driver build a new iso use this iso boot pc press f7 then 7b error blue screen -------------------------------- thank you
dear Fernando if you have b250 chipset machine , test your fix driver install xp
The 7B bluescreen indicates the integration of a not matching driver or the choice of a not matching Intel SATA Controller model while doing the integration. Are you sure, that you didn’t make a mistake at that point?
I don’t have a system with an Intel 200-Series chipset, but I have successfully tested the XP installation with my Intel Z170 chipset system.
usb-cdrom boot plug intel b250 usb 2.0 port or nec usb 3.0/20.0 card all error 7b blue screen usb -cdrom hardware:zm-ve200 or ve200 se ,ve300,ve400,iodd 2541
If you are in China, I’ll send you a iodd 2541 Because the world has you and it’s wonderful You are great, admiring you
@qq2348227 : Since the Windows XP Setup doesn’t support the USB Controllers of modern PC systems, you have to boot off an Optical Drive (CD/DVD). Question: Does the i386 directory of your XP source contain a file named WINNT.SIF? If yes, it is not an original XP image. Unfortunately I live far away from China. So I can only try to help you this way.
re-customized: “Universal 32/64bit Intel RST AHCI+RAID drivers v11.2.0.1006 mod+signed by Fernando” dated 05/30/2012 (re-modded and freshly digitally signed at 03/15/2018)
re-customized: “Universal Intel RST Drivers & Software Set v11.2.0.1006 mod+signed by Fernando” (drivers re-modded and freshly signed at 03/15/2018)
re-customized: “Universal 32/64bit Intel MSM AHCI+RAID drivers v8.9.8.1005 mod+signed by Fernando” dated 04/05/2010 (re-modded and freshly digitally signed at 03/15/2018)
re-customized: "Universal Intel MSM Drivers & Software Set v8.9.8.1005 mod+signed by Fernando (drivers re-modded and freshly signed at 03/15/2018)
Notes: All above drivers now will support even the latest Intel 300-Series and X299 Chipset systems.
Good luck with these mod+signed Intel RST/MSM drivers with enhanced compatibility! Dieter (alias Fernando)
c) For all users with an Intel AHCI/RAID system from ESB2 or ICH7R/M up (incl. X79, X99, X299 and 8-/9-/100-/200-/300-Series Chipsets): For all these users, who want to get XP (32bit) installed in AHCI or RAID mode, I recommend to download and integrate this modified v11.2 RST driver (the regular Intel RSTe driverpacks will not work for all users): >Universal 32bit Intel RST textmode driver v11.2.0.1006 mod+signed by Fernando done at 03/15/2018)< (>MIRROR<)
is this driver should suitable for motherboard chipset asus H-110mk ? currently using processor i3-7100 kabylake thank you
I have successfully install windows XP , but may i know how to get the missing driver such as network card audio PCI memory controller universal serial bus video controller standard floopy disk controller ? since asus website doesn’t have win XP driver . TQ @fernando
Hi Fernando i has the same problem that has "yeakyau". I sucessfully install xp in my PC with motherboard Asus Z97-P. Now for Network i installed a driver for XP for realtek card that is inside the moderboard and it is working. I am missing drivers for PCI cards and some USB controllers.
@yeakyau : Unfortunately I cannot help you regarding XP drivers for other devices. My advice: Check the HardwareIDs of the related devices and do a Google search for matching XP drivers.
Greetings, I would appreciate some help. I’m confused about where to find what S-ATA controller my system has (Z97 chipset, Asus Z97-m plus board) and do you have xp version for it? I would like to dual boot win10 and xp32bit and because I already have win XP installed (IDE) on a separate drive, could I update driver in device manager in XP ?
