Change in 10) paragraph of the guide.
Non-official OROM VBIOS+BSF SKL/KBL/CFL 5191
- extended the supported DevID support for CFL
Add:
Delete file. 5191 == 1059
Updated Collection Intel OROM in "VBIOS_and_BSF.7z":
- added OROM VBIOS+BSF
– Skylake/Kabylake/Coffeelake v1059
有1052的BSF 脚本吗?
@SoniX
Before I try following your guide in updating my Intel GPU vBIOS, can you check if the official latest BIOS (https://www.dropbox.com/s/tma0cvk7bxgk1h…S-1602.zip?dl=0) for my board needs the said update? Thanks for the help.
@Sonix
Right, I know the versions inside the BIOS as that’s easily seen with the UBUTool. I also know the latest IntelGOP is 9.0.1080. But where can I confirm that the latest version of the Intel VBIOS is 1059? I don’t see 1059 listed in the word document that is included in the zip file collection that you can download from your guide.
EDIT: Nevermin, I figured it out
Hi. Can any one help me with import VBIOS 1044 to my UEFI MSI Z97 Mpower?
E7915IMS.part1.rar (5 MB)
E7915IMS.part2.rar (1.19 MB)
1044.rar (81.7 KB)
@meteora
E7915IMS.part1.rar broken.
Yes! It works! Very thanks!
I noticed that the versions of the modules in the BIOS and Windows do not change. After all updates I have:
In BIOS I have:
CPUmicrocode: 306c3/1E
VBIOS: 1038 (in win too. In intel graphic driver)
GOP: 5.5.1032 (in win too. In intel graphic driver)
But UBU says that:
CPUmicrocode: 306c3/25
VBIOS: 1044
GOP: 5.5.1034
This is right? No need fix?
After update VBIOS I have artifacts and freeze…
And I see that after your updating zone of bootguard protection are changed. There is no "red zone" in UEFITool. How do you make this?
Only UEFITool NE Alpha shows bootguard red zones.
Yes i know. But after updating by SoniX red zone is gone. After this i do me_cleaner with flag -S and this work (without 30 min shutdown and error bootguard verif. dxe fail)!
I wasn’t sure if you noticed that UEFItool version difference. SoniX will have to let you know what all he did to the BIOS.
Ok. at this moment i understand - this is UBU destroyed bootguard. When i update cpu microcode in UBU with flag U (Use UEFItool replace) - bootguard is destroyed. When i used flag D (Insert into a DXE volume) - it’s ok and bootguard not destroyed. After this i checked my GOP driver ver. and this is 1034 (updated)
So you got it fixed now?
Just now bootguard is fixed, but i think that is GOP 5.5.1034 not stable for me. I have MSI Z97 MPower and 4690k @ 4.7 / NB @ 4.3. I have freeze and artifacts on onboard HD4600. I continue to test…
If it ends up not working how you wanted simply flash back to stock BIOS
