What were your actions? If I understand you correctly, then first you saved the settings from 199 to an SSF file. Then, I loaded the settings from the SSF file to 221. - (That is, as usual for OROM VBIS) And then he corrected the settings you need.
@plutomaniac yes it did not work. GOP 1080 already gave problems with VBT 199, transferring the settings to a newer VBT solved all my issues with both 1080 and 1086
Yes, the "Watch" notifications are for Issues, Tags, Code comments, conversations etc. For code commits, you’ll have to check the Activity at github.com while logged in. Or add the branches tab as a bookmark and check it from time to time.
I tried transferring settings to vbt228 but got the following message:
When checking these out there are a lot of power conservation settings missing in vbt228. As for the eDP Link Training, the value is now expressed in Khz, while in older vbt this is expressed in Gbps.
Yes, the settings you specified in 228 are marked as "Skip". They are usually ignored or immediately deleted from the (SSF) settings file. It’s bad when the old parameters are larger than what is provided in the new files. Example, fby old parameter - 2 byte, and new parameter - 1 byte.
There were bytes became kilohertz … That I can not say anything except as "The manufacturer reserves the right to make changes" …
I think we should look for the settings in 221. This image flip, as I understand it, is observed only on notebooks. On desktops there are no such problems, it is checked.
