Heloo friends, I’m having a hard time finding the bin for my BIOS.
I’m sorry, my English, and I posted in the wrong place.
It is a china mini pc.
My mobo, it’s GBDW1-VERB.D
I7 processor 5500 2.4 to 3.0 turbo boost
Vga HD 5000 series
The bios, winbond 25q64fvsig
I count on your help!
Thank you and have a good day!
@filipels :
Welcome at Win-RAID Forum!
If you want help, you should attach a link to the latest BIOS, which is offered by the manufacturer of the mainboard/Mini-PC, ad tell us, why/what you want to modify/update the BIOS.
Regards
Dieter (alias Fernando)
My computer, after a change in Bios, does not power on, not video, turns on the power LED (blue).
I need the file to restore the bios, flash.
These no brand Chinese Broadwell machines usually use BIOS like the ones found here [1, 2]. So read those threads and try those images with caution (pick what is proper for your system etc).
If you mean that some BIOS setting prevents powering on, you may just reset your CMOS.
