Hi,
May I ask for some guru assistance please ?
I’m trying to mod my bios on an asrock X99 taichi. I have several reasons to achieve :
CPU microcodes are not up to date, and maybe that’s the reason why I can’t backup my system in clonezilla (screen is all messed up with error messages and cpu microcode refs) (I can backup in rescuezilla though)
I want to add and enable Resizable Bar for my new nvidia GPU to perform “better” (as it does underperform according to benchmarks)
So I read a lot of things, and here are the steps I followed and that I would be glad if some experts would validate. Questions are in BOLD BLUE
Preliminary actions - I gathered :
the manufacturer original bios(es) : 1.80 (my actual bios) and 1.82beta (a beta bios from 2019, with “updated” microcodes but they are still not up to date according to UBU) from https://www.asrock.com/mb/intel/X99%20Taichi/index.fr.asp#BIOS
uefitool 0.28 from h_ttps://github.com/LongSoft/UEFITool/releases/tag/0.28.0
ReBarDxe.ffs from h_ttps://github.com/xCuri0/ReBarUEFI
UBU (uefi bios updater) from h_ttps://winraid.level1techs.com/t/tool-guide-news-uefi-bios-updater-ubu/30357
uefitool NE from h_ttps://github.com/LongSoft/UEFITool/releases
IFRextractor from h_ttps://github.com/LongSoft/IFRExtractor-RS/suites/9555751857/artifacts/454700873
HxD hex editor
read the guide UEFItool guide at [Guide] How to extract/insert/replace EFI BIOS modules by using the UEFITool
Then I followed those steps :
modding (adding dxe driver) at the end of the big dxe section with uefitool(non ne), like explained here h_ttp://www.youtube.com/watch?v=vcJDWMpxpjEE
updated CPU microcodes as explained in the UBU thread
saved the bios with the option to remove flash protection (the bios has the exact same size after that)
And there starts the questionning :
on the ReBarUEFI github from xCuri0, there is something that is quite disturbing : “Some firmware don’t clear NVRAM variables (ReBarState) when the CMOS is cleared. This can be a problem as CMOS clear will reset BIOS settings (4G/CSM) while keeping ReBarState enabled requiring you to boot with iGPU/non-rebar GPU to disable ReBarState. To mitigate this issue you can use AMIBCP to enable 4G decode and disable CSM by default.”
I understood that :
- amibcp is not really available (is it ?)
- amibcp SHOULD NOT be used on “aptio V” bioses (99% of messing things), and it IS the plaform of my bios
- there are some “MMtool” available somewhere, I downloaded them, I can open my bios, but there is no place where I could change default settings values
… so how do I perform that task of changing default values in bios ? because I have clearly struggled to simply enable “above 4G decoding” in my actual bios, I did it maybe 10 times because either a) my windows did boot but I had no more bios post and display so no more bios settings or b) I had bios screen but windows would not boot and stay with a single “-” in top left corner …
so well, now that I have :
- moved from mbr to gpt => ok
- disabled CSM in bios and enabled “above 4G decoding” and “above 4G decoding patch” => ok
- and that I have windows booting AND bios POST
… how do I do that “simple task” of changing default values ?
I found this thread about UEFI editor (h_ttps://winraid.level1techs.com/t/tool-uefi-editor/91500/4)
But I’m quite struggling at :
- finding the “setup” section in the bios : the search for “high precision” pattern finds nothing and “HPET” finds only a section named “Platform” and not “setup” (but there are some “setup” matches sections elsewhere in the bios) => should I take and use this “Platform” PE32 ? => tried that one => the tool opens up settings but there is no “above 4g decoding”
==> tried the other section :
Unicode text “setup” in LzmaCustomDecompressGuid/PE32 image section at header-offset 42CCh
==> the tool opens up, and there ARE “above 4G decoding” and CSM sections
then … what should I set in the fields of the settings I want to mod ? “01” instead of “00” (to enable) ? or “0A” or what ?
and finally, how to reintegrate the eventual modded file(s) ? I used uefitool(non NE) and searched for AMITSE guid (B1DA0ADF-4F77-4070-A88E-BFFE1C60529A), then “replace body” of the setupdata section (identified as freeform subtype guid), saved file, reopened it OK. => is that the way to go ?
Am I safe here flashing the moded file in my bios ? I’m not really confident, if I did something wrong that I don’t even notice (?) (yeah, I have the chance to have a 2nd bios chip, and a safe backup between both chips, I used it already when I had no POST display, but I’d rather avoid this process as much as I can)
