Hello everyone,
I am having some trouble with an Intel Z77 chipset motherboard, a used Asus P8Z77-WS which I purchased recently and intended to use as a replacement for my other board an Asus P8Z77-V Premium which has an i7-3770K CPU. For the P8Z77-WS board I purchased a cheap i5-3330S CPU which is 2.7GHz default with a 3.2GHz Turbo. This is partly where the problem is because it will not now? enter Turbo mode when running intensive stress tests like prime95 or IntelBurnTest. Unfortunately I did not verify whether it was working after I set the PC up because I was eager to update the Bios and ME firmware to the latest. It was using quite an old Asus Bios which I updated to 3505 and then updated the old ME firmware first to the Asus v8.1 (8.1.0.1248) firmware and then to v8.1.70.1590 which I also use on the P8Z77-V Premium. The Turbo works fine on the P8Z77-v Premium with the unlocked i7-3770K. The online recommendations not involving anything with the ME firmware to get Turbo working (temporarily) have not worked.
There are also a few more problems which I believe could be related to the ME. The case fans always run at full speed no matter how they are set in the Bios ie silent makes no difference nor does any manual setting that I set. The speed never alters except for a very minor amount. The CPU fan does however run at a reduced speed, the CPU temperature is very low.
Lastly and something that I have a big issue with is the power usage of the system. Using a power meter showing the power from the wall, the P8Z77-WS uses 72 to 75 when idling whereas the P8Z77-V Premium uses only around 52/53 Watts when the EPU is set to max power saving. The P8Z77-WS was using around ~85-90 Watts with a GTX1660 fitted (idling) which I want to use on the motherboard.
I have attempted to downgrade the system Bios to a much earlier version which contains a very early v8.0 ME in DOS without success. Bios Flashback certainly does not alter the ME firmware. because I have reflashed via Bios Flashback the 3505 bios.
Reading online suggests that Intel implemented a firmware downgrade prevention which cannot be worked around but I think that this might only be on newer chipsets than the series 7 and newer ME firmware versions. Is that correct?
I would appreciate some help to get it fully working, the Turbo mode, case fans and the system power usage especially. I assume that there is a problem with the ME firmware, maybe some corruption although MEManufWin64.exe (shown below) does not seem to show any problem.
I have just attempted to re-do the 8.1 ME firmware update from the Asus website. It is a much older ME firmware but I thought it was worth a try seeing as the info below suggests? that the ME firmware lock does not look like it is active. Anyway the update is not proceeding, it has locked up saying not to shutdown or restart. It is taking far too long so it looks like something is not functioning. What should I do now?
Does the following line mean that the ME lock is off?
Host ME Region Flash Protection Override (HMRFPO) Status: Disabled
https://www.asus.com/Motherboards/P8Z77_WS/HelpDesk_BIOS/
P8Z77-WS:
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
ME Current Working State: Normal
Manufacturing Mode: Active
ME Current Operation Mode: Normal
Intel Manageability Engine Features
Intel ME Version: 8.1, Build 1590, Hot Fix 70
Intel ME Recovery Image Version: 8.1, Build 1590, Hot Fix 70
Intel ME FITC Version: 8.0, Build 1410, Hot Fix 2
ME Firmware Capabilities
Full Network Manageability: Not Capable
Standard Network Manageability: Not Capable
Manageability (AMT): Not Capable
Small Business Advantage: Not Capable
Manageability Upgrade: Not Capable
Intel Anti-Theft: Not Capable
Capability Licensing Service: Capable
Virtualization Engine: Not Capable
Power Sharing Technology (MPC): Capable
ICC Over Clocking: Capable
Protected Audio Video Path (PAVP): Capable
Identity Protection Technology (IPT): Not Capable
Remote PC Assist (RPAT): Not Capable
IPV6: Not Capable
KVM Remote Control: Not Capable
Outbreak Containment Heuristic (OCH): Not Capable
Virtual LAN (VLAN): Capable
Cipher Transport Layer (TLS): Not Capable
Wireless LAN (WLAN): Not Capable
Platform Trust Technology (PTT): Not Capable
Near Field Communication (NFC): Not Capable
ME Firmware Feature State
Full Network Manageability: Disabled
Standard Network Manageability: Disabled
Manageability (AMT): Disabled
Intel Anti-Theft: Disabled
Capability Licensing Service: Enabled
Virtualization Engine: Disabled
Power Sharing Technology (MPC): Enabled
ICC Over Clocking: Enabled
Protected Audio Video Path (PAVP): Enabled
Remote PC Assist (RPAT): Disabled
IPV6: Disabled
KVM Remote Control: Disabled
Outbreak Containment Heuristic (OCH): Disabled
Cipher Transport Layer (TLS): Disabled
Wireless LAN (WLAN): Disabled
Platform Trust Technology (PTT): Disabled
Near Field Communication (NFC): Disabled
ME Firmware Platform Type
Platform Target Usage Type: Desktop
Platform Target Market Type: Consumer
SKU: Regular SKU
ME Firmware Image Type: 1.5MB Firmware
Platform Brand: None
P8Z77-V Premium:
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
Intel(R) MEManuf Version: 8.1.10.1286
Copyright(C) 2005 - 2012, Intel Corporation. All rights reserved.
FW Status Register1: 0x1E000255
FW Status Register2: 0x60000106
CurrentState: Normal
ManufacturingMode: Enabled
FlashPartition: Valid
OperationalState: M0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
ICC: Valid OEM data, ICC programmed
Get FWU info command...done
Get FWU version command...done
Get FWU feature state command...done
Get ME FWU platform type command...done
Get ME FWU feature capability command...done
Feature enablement is 0x1101C40
gFeatureAvailability value is 0x1
Request Intel(R) ME test result command...done
System is running on consumer/1.5M image, start Intel(R) ME Runtime Test
ME initialization state valid
ME operation mode valid
Current operation state valid
ME error state valid
Verifying FW Status Register1...done
OEM ICC data valid and programmed correctly
vsccommn.bin was created on 03:27:24 06/19/2012 GMT
SPI Flash ID #1 ME VSCC value is 0x2005
SPI Flash ID #1 (ID: 0x1C3117) ME VSCC value checked
SPI Flash ID #1 BIOS VSCC value is 0x2005
SPI Flash ID #1 (ID: 0x1C3117) BIOS VSCC value checked
FPBA value is 0x0
No Intel vPro Wireless device was found
Request Intel(R) ME Runtime BIST test command...done
Get Intel(R) ME test data command...done
Total of 12 Intel(R) ME test result retrieved
MicroKernel - Internal Hardware Tests: Internal Hardware Tests - Passed
Policy Kernel - Power Package: Package 1 supported - Passed
Policy Kernel - Power Package: Default package supported - Passed
MicroKernel - Blob Manager: Set - Passed
MicroKernel - Blob Manager: Get - Passed
MicroKernel - Blob Manager: Remove - Passed
Policy Kernel - ME Configuration: Wlan Power Well - Passed
Policy Kernel - ME Configuration: PROC_MISSING - Passed
Policy Kernel - ME Configuration: M3 Power Rails Available - Passed
Policy Kernel - ME Recovery: ME Recovery mode check - Passed
Policy Kernel - Embedded Controller: Power source type - Passed
Policy Kernel - SMBus: Read byte - Failed
Error 9331: SMBus hardware is not ready
Clear Intel(R) ME test data command...done
Get EPID Group ID command...done
EPID Group ID: 846
EPID GID Check passed
Error 9296: MEManuf Test Failed
