I’ve previously successfully modded XPS bioses to enable all hidden options, update/patch CPU microcode and update VRAMs etc. All successfully done with a combination of Phoenix, UBU and my trusty HxD.
However when trying to patch the new Dell XPS 9360 (Kaby Lake) I keep finding structural problems to repack the modded BIOS. I can extract the HDR and ROMs from the EXE file found here: http://www.dell.com/support/home/us/en/1…?driverId=CKNJX
And I’ve successfully located and patched the BIOS setup module, which I’ve attached.
Problem is I can’t find a way to successfully repack the file into the original EXE or HDR. I suspect it’s due to the two-level compression that Dell has recently used. I’ve tried using Z.version.bat, which manages to unpack the files, however I can’t find a way to repack. Any suggestions?
First check to see if the system is protected via BootGuard. From the ME thread, run MEInfo and check the bottom of the report. If BG is active, you cannot do any modifications. If not, your best bet is either a direct chip dump/mod/reflash via a programmer or PhoenixTool. For the latter, I suggest you contact the dev at MDL and ask him/her to help you (I remember doing such in the past myself too).
Thanks. Yes that’s actually a good idea - I spoke with Andy in the past regarding a few changes to the Dell Tiano support. I’ll reach out and see it’s possible to extend support for the latest generation of Dell BIOSes.
One other question - I’m getting Error 86 on MEInfo, and all the drivers are installed (and ME is definitely present). FPTW -greset doesn’t work either. What could be the issue here?
Is there an “Intel(R) Management Engine Interface” device at Device Manager > System devices? If yes, what driver does it show? Have you tried either the DOS or EFI MEInfo to see if you get the same error? Try to shutdown the laptop and remove all power (AC + battery) for 1 minute, does that solve the communication error?
Intel(R) AMT State Disabled TLS Disabled Last ME reset reason Global system reset Local FWUpdate Enabled BIOS Config Lock Enabled GbE Config Lock Enabled Host Read Access to ME Disabled Host Write Access to ME Disabled Host Read Access to EC Disabled Host Write Access to EC Disabled SPI Flash ID 1 EF4019 SPI Flash ID 2 Unknown BIOS boot State Post Boot OEM ID 68853622-eed3-4e83-8a86-6cde315f6b78 Capability Licensing Service Enabled OEM Tag 0x00000000 Slot 1 Board Manufacturer 0x00001028 Slot 2 System Assembler 0x00000000 Slot 3 Reserved 0x00000000 M3 Autotest Enabled C-link Status Enabled Independent Firmware Recovery Disabled EPID Group ID 0xFC0 LSPCON Ports None 5K Ports None OEM Public Key Hash FPF 234EB9DE1AC240CC1376378CA22D245372D665B40F93D148141A66E9B76293EF OEM Public Key Hash ME 234EB9DE1AC240CC1376378CA22D245372D665B40F93D148141A66E9B76293EF ACM SVN FPF 0x2 KM SVN FPF 0x0 BSMM SVN FPF 0x0 GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000 GuC Encryption Key ME 0000000000000000000000000000000000000000000000000000000000000000
FPF ME — – Force Boot Guard ACM Enabled Enabled Protect BIOS Environment Enabled Enabled CPU Debugging Enabled Enabled BSP Initialization Enabled Enabled Measured Boot Enabled Enabled Verified Boot Enabled Enabled Key Manifest ID 0xF 0xF Enforcement Policy 0x3 0x3 PTT Enabled Enabled PTT Lockout Override Counter 0x3 EK Revoke State Not Revoked PTT RTC Clear Detection FPF 0x0
The fact that the driver is shown and that DOS works means that there is some sort of OS interference that does not allow the Windows tools to work properly. Some background utility or motioning program (aida64, hwinfo etc) could cause that. Other than that, as you said, BG is fully enabled on your system so you cannot modify it, to my knowledge.
Thanks for the help. Do you think there’s any chance I can modify the ME regions by shorting a couple of pins or editing using FITC (I’ve done this on previous XPS machines)
