I have this devices. By intel specification it support AMT. However kvm is not enable.
I do fpt -desc -d hp.bin and succesfully get file hp.bin.
After that I edit this file and save it as hp_fix.bin
Moreover, I get sucessfully get dump ftp -d hp_full.bin
An next step i look on ME:
E:\Soft\Intel CSME System Tools v11 r29\MEInfo\WIN64>MEInfoWin64.exe
Intel(R) MEInfo Version: 11.8.70.3626
Copyright(C) 2005 - 2019, Intel Corporation. All rights reserved.
Intel(R) Manageability and Security Application code versions:
BIOS Version P07 Ver. 02.31
MEBx Version 11.0.0.0010
GbE Version 0.1
Vendor ID 8086
PCH Version 0
FW Version 11.8.65.3590 H
Security Version (SVN) 3
LMS Version 1927.14.0.1305
MEI Driver Version 1931.14.0.1323
Wireless Hardware Version 2.1.77
Wireless Driver Version 20.70.12.5
FW Capabilities 0x593A1146
Intel(R) Standard Manageability - PRESENT/ENABLED
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - PRESENT/ENABLED
Re-key needed False
Platform is re-key capable True
Intel(R) AMT State Disabled
AMT Global State Enabled
Intel(R) Standard Manageability State Enabled
TLS Enabled
Last ME reset reason Power up
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Host Read Access to ME Enabled
Host Write Access to ME Disabled
Host Read Access to EC Disabled
Host Write Access to EC Disabled
SPI Flash ID 1 C84018
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Link Status Link Up
System UUID 0e781479-d74f-14c7-e1f2-d82aa45d135a
MAC Address f4-39-09-1d-f9-9e
IPv4 Address 10.0.16.115
IPv6 Enablement Disabled
IPv6 Address Unknown
Privacy/Security Level Default
Configuration State Completed
Provisioning Mode PKI
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Enabled
Wireless Micro-code Mismatch No
Wireless Micro-code ID in Firmware 0x24FD
Wireless LAN in Firmware Intel(R) Dual Band Wireless-AC 8265
Wireless Hardware ID 0x24FD
Wireless LAN Hardware Intel(R) Dual Band Wireless-AC 8265
Localized Language Russian
Independent Firmware Recovery Disabled
EPID Group ID 0x2055
LSPCON Ports None
5K Ports None
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
OEM Public Key Hash ME 0000000000000000000000000000000000000000000000000000000000000000
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
GuC Encryption Key ME 0000000000000000000000000000000000000000000000000000000000000000
FPF ME
Force Boot Guard ACM Disabled Disabled
Protect BIOS Environment Disabled Disabled
CPU Debugging Enabled Enabled
BSP Initialization Enabled Enabled
Measured Boot Disabled Disabled
Verified Boot Disabled Disabled
Key Manifest ID 0x0 0x0
Enforcement Policy 0x0 0x0
Now is clear, what i have a Read permission, but do not have a Write permission. I need to set MB to test/service mode.
Someone, can me say (see attachment), what think HP when paint this subscribe? Where is “FDO” contact plate? If I set a jumper, computer started, but after 5 sec. go down. Shorting of first upper plates don’t give a effect.
