Intel AX211 no-vPro to AX211 vPro upgrade
Hello, sorry for the silly question, but I am quite new to CSME.
I have new HP Elite 800 g9 with Alder Lake (CSME 16.1.25.1991), it comes with all the vPro ingredients (AMT is available and enabled, KVM works) but the Wifi RF module, which is a non-vPro part. Since I might actually need it for a while, I wanted to check whether I could simply swap it with the vPro version and see it show up under AMT.
So, I dumped the SPI with FPT and loaded it in FIT and could see that under the “Wireless LAN Configuration” section ME CLINK Signal is enabled (so the vPro communication bus is enabled) and power well set to SLP_WLAN, so here everything seems to be correctly set.
However, I wonder whether this would be sufficient, or if there is anything else that might not work, for example the ME binary might not have support.
Any thought?
By the way, I can share the SPI image if it helps.
Thanks!
Please post the complete output of MEInfo -verbose.
What cpu and what LAN card is installed? Chipset is Q670?
It’s not very common that vpro- enabled machines don’t have vpro enabled WLAN Cards?
I tried but I got a “PCH is not supported”, I guess because it’s version 16.1.25.1932 (vs. version 16.1.25.1991). I’ll try to do another search, but a pointer to a newer release is very welcome.
Yes, Intel Q670 paired with the non-vPro Intel AX211 PHY. Yeah, I thought all the AMT systems with WLAN had the full vPro and annoyed me quite a bit when I checked the part number. I can’t believe they did it to save some 6$, but on the other hand I don’t think they really maintain two different FW updates for such a small difference. In fact I checked the available downloads from HP and they are the exact same softpaq bios file for both the elite 600 (ISM) and the 800 (AMT), regardless. By the way, ISM supports remote management via WLAN starting with Alder Lake/CSME 16, so I would expect to be always there/enabled.
Also, I checked the dump with UEFITool and I can see in one of the ME (Boot) partitions the WLAN microcode and a binary named “wlan_drv”. What else can I check? Would I need to clear something else before upgrading? I have noticed that disk/memory upgrades are not refected in the AMT inventory (without un-provisioning first?). What would you suggest doing?
Thanks!
PCH is not supported seems to be more than a version conflict? Post a screenshot of the output / the command window.
Hi, sorry for the delay, a few things got in the way this week… and sorry, contrary to my believe I didn’t have the drivers installed, now it works. It also worked under Linux. I also have the output file for the Elite 600, which is effectively the exact same flash image but configured with ISM. Both are i5-12500T, Lan i219-LM, Q670 stepping B0, both with non-Vpro AX211.
Elite 800:
Intel (R) ME Info Version: 16.1.25.1932
Copyright (C) 2005 - 2022, Intel Corporation. All rights reserved.
FW Status Register1                          0x90000245
FW Status Register2                          0x69000506
FW Status Register3                          0x00000030
FW Status Register4                          0x00004000
FW Status Register5                          0x02041F03
FW Status Register6                          0xC46003CB
General FW Information
Current FW State Normal
Flash Partition Table Valid
FW Memory State CM0 with UMA
FW Initialization Complete
BUP Loading state Success
FW Error Code No Error
FW Mode Of Operation Normal
SPI Flash Log Not Present
FW Loading Phase HOSTCOMM Module
FW Loading Phase Status UNKNOWN
ME File System Corrupted No
RPMC status OK
Platform Type                                Desktop
FW Image Type                                Production
Last ME Reset Reason                         Global system reset
BIOS Boot State (EOP)                        Post Boot
BIOS Boot State (CBD)                        Post Boot
Boot Critical Code Redundancy                Disabled
Current Boot Partition                       1
OEM Chipset Init                             Available
OEM Chipset Init Version                     160.2.153.11
Factory Defaults Restoration Status          Disabled
CPUID                                        0x90675
Factory Defaults Recovery Status             Enabled
Firmware Update OEM ID                       00000000-0000-0000-0000-000000000000
Intel(R) ICPS SW SKUing Eligible             Disabled
Crypto HW Support                            Enabled
Intel(R) ISH Power State                     Disabled
OEM Tag                                      0x00
FW Update State                              Disabled
TLS State                                    Enabled
CSME Measured Boot to TPM                    Disabled
BIOS Recovery State                          Disabled
Intel(R) ME Code Versions
BIOS Version U21 Ver. 02.10.04
MEBx Version 0.0.0.0000
GbE Version 0.3
MEI Driver Version 2210.2.80.0
FW Version 16.1.25.2124 H Corporate
LMS Version 2203.2.21.3
Extended Platform Services
License Installed False
License Period 0 Periods
IUPs Information
PMC FW Version 160.2.0.1042
LOCL FW Version 16.1.25.2124
WCOD FW Version 16.1.71.0063
NPHY FW Version 13.60.211.7253
SPHY FW Version 13.0.1.7083
PCHC FW Version 16.1.0.1014
PCH Information
PCH Name ADL
PCH Device ID 7A83
PCH Revision ID B1
PCH SKU Type Production PRQ Revenue
PCH Replacement State Disabled
PCH Replaceable Counter 0
PCH Unlocked State Disabled
Transactional FW Information
Original image type Corporate
Current sku type Corporate
Flash Information
Storage Device Type SPI
SPI Flash ID 1 EF4019
RPMC Unsupported
RPMC Bind Counter 0
RPMC Bind Status Pre-bind
RPMC Rebind Unsupported
RPMC Replay Protection Max Rebind 1
BIOS Read Access 0x010F
BIOS Write Access 0x010A
GBE Read Access 0x0009
GBE Write Access 0x0008
ME Read Access 0x000D
ME Write Access 0x0004
EC Read Access 0x010F
EC Write Access 0x010F
FW Capabilities 0x1DF6D107
Intel(R) Active Management Technology Present/Enabled
Intel(R) Protected Audio Video Path Present/Enabled
Intel(R) Dynamic Application Loader Present/Enabled
Intel(R) Platform Trust Technology NOT PRESENT
Persistent RTC and Memory Present/Enabled
End Of Manufacturing
NVAR Configuration State Locked
EOM Settings Lock(Flash,Config)
EOM Flow Full
HW Binding State Enabled
Flash Protection Mode Protected
FPF Committed Yes
Intel(R) AMT State in FW Present/Enabled
MAC Address 7c-4d-8f-a8-b0-28
IPv4 Address 0.0.0.0
IPv6 Enablement Disabled
Configuration State Not Started
Provisioning Mode PKI
Auto-BIST State Disabled
Wired AMT Link Status Link Up
Localized Language English
Wireless C-Link Status Enabled
System UUID 00000000-0000-0000-0000-000000000000
Intel(R) Manageability HW Status Enabled
Discrete vPro NIC on-board State Disabled
On Board Discrete vPro NIC SMBus address 0x00
vPRO TBT Dock State Disabled
On dock vPro NIC SMBus address 0x00
Thunderbolt Port1 SMBus Address 0x20
Thunderbolt Port2 SMBus Address 0x21
Thunderbolt Port3 SMBus Address 0x22
Thunderbolt Port4 SMBus Address 0x23
AMT Global State Enabled
Redirection Privacy / Security Level Default
Intel(R) Trusted Device Setup
Intel(R) Trusted Device Setup Supported Disabled
Intel(R) Signing Policy Seal Signing Required
Intel(R) Reseal Timeout 0x06
Intel(R) Seal State Unknown
PAVP State Yes
Security Version Numbers
Trusted Computing Base SVN 1
Firmware Version Control SVNs
    PMC                                      0   [minimum allowed: 0]
    CSE                                      4   [minimum allowed: 0]
    ROT KM                                   0   [minimum allowed: 0]
    IDLM                                     0   [minimum allowed: 0]
    CSME bootstrap                           0   [minimum allowed: 0]
    SECURE BOOT BSMM                         1   [minimum allowed: 0]
    OEM KM                                   0   [minimum allowed: 0]
    SECURE BOOT KM                           0   [minimum allowed: 0]
    UCODE                                    1   [minimum allowed: 0]
    SECURE BOOT ACM                          2   [minimum allowed: 0]
HW Glitch Detection 0x549
TRC Polarity Rising Trans
TRC Mode Full-cycle polarity trans
TRC State Enabled
Intel(R) Unique Platform ID
UPID supported Disabled
Platform Service Record
Platform Service Record Supported No
Intel(R) PTT initial power-up state Disabled
Intel(R) PTT State Disabled
SMx State Enabled
RSA1K Support Disabled
Debug Information
Token Present No
Consent No
DFx Policy Unprivileged Public Debug Enabled
FW Supported FPFs FPF UEP
*In Use
1st OEM Key Hash Revoked Disabled Disabled # Disabled=0, Enabled=1
1st OEM Key Hash size Disabled Disabled # Enabled=0, Disabled=1
1st OEM RSA Key size Enabled Enabled # Disabled=0, Enabled=1
2nd OEM Key Hash Revoked Disabled Disabled # Disabled=0, Enabled=1
2nd OEM Key Hash size Disabled Disabled # Enabled=0, Disabled=1
2nd OEM RSA Key size Enabled Enabled # Disabled=0, Enabled=1
BSMM Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
CSE FW Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
CSME Bootstrap Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
DNX Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
Error Enforcement Policy 0 Enabled Enabled # Disabled=0, Enabled=1
Error Enforcement Policy 1 Enabled Enabled # Disabled=0, Enabled=1
Flash Descriptor Verification Disabled Disabled # Disabled=0, Enabled=1
Glitch Detection Disabled Enabled Enabled # Enabled=0, Disabled=1
IDLM Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
Intel PTT Encryption Key Not Revoked Not Revoked # Not Revoked=0, Revoked=1
Intel(R) Manageability HW Fuse Status Enabled Enabled # Enabled=0, Disabled=1
Intel(R) PTT Disabled Disabled # Disabled=0, Enabled=1
OEM ID 0x00 0x00
OEM KM Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
OEM Key Manifest Disabled Disabled # Disabled=0, Enabled=1
OEM Key Revocation State Disabled Disabled # Disabled=0, Enabled=1
OEM Platform ID 0x00 0x00
OEM Secure Boot Policy 0x7B 0x7B
CPU Debugging Disabled Disabled # Enabled=0, Disabled=1
BSP Initialization Enabled Enabled # Enabled=0, Disabled=1
Protect BIOS Environment Enabled Enabled # Disabled=0, Enabled=1
Measured Boot Enabled Enabled # Disabled=0, Enabled=1
Verified Boot Enabled Enabled # Disabled=0, Enabled=1
Key Manifest ID 0x01 0x01
Force Boot Guard ACM Enabled Enabled # Disabled=0, Enabled=1
OEM key Hash RSA key size Enabled Enabled # Disabled=0, Enabled=1
PID Refurbish Counter 0x00 0x00
PMC Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
PTT Lockout Override Counter 0x00 0x00
Persistent PRTC Backup Power Enabled Enabled # Enabled=0, Disabled=1
ROT Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
RPMB Monotonic Counters 0x00 0x00
RPMC Over EC Disabled Disabled # Disabled=0, Enabled=1
RPMC Rebinding Disabled Disabled # Disabled=0, Enabled=1
RPMC Support Disabled Disabled # Disabled=0, Enabled=1
SOC Config Lock State Enabled Disabled # Disabled=0, Enabled=1
SPI Boot Source Enabled Enabled # Enabled=0, Disabled=1
SPIRAL CPU Enabled Enabled # Disabled=0, Enabled=1
Secure boot KM Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
TXT Supported Enabled Enabled # Disabled=0, Enabled=1
UFS Boot Source Disabled Disabled # Enabled=0, Disabled=1
uCode Firmware Version Control Enabled Enabled # Disabled=0, Enabled=1
DNX SVN 0x00 0x00
IDLM SVN 0x00 0x00
OEM KM SVN 0x00 0x00
PMC SVN 0x00 0x00
ROT KM SVN 0x00 0x00
Secure boot ACM SVN 0x00 0x00
Secure boot BSMM SVN 0x00 0x00
Secure boot KM SVN 0x00 0x00
Ucode SVN 0x00 0x00
1st OEM Public Key Hash FPF 0D7C0D45CE688443FCA03B4DC069BC4B41D6B089B64B4D62CCA373CEF094C317A29E549AAE9A2BF0BAEDDBBF20742C00
1st OEM Public Key Hash UEP 0D7C0D45CE688443FCA03B4DC069BC4B41D6B089B64B4D62CCA373CEF094C317A29E549AAE9A2BF0BAEDDBBF20742C00
2nd OEM Public Key Hash FPF 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
2nd OEM Public Key Hash UEP 000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Elite 600:
FW Status Register2                          0x89110106
FW Loading Phase Maestro
FW Loading Phase Status MAESTRO_CM0_ENTRY_COMPLETE_START
RPMC status OK
CPUID                                        0x90675
OEM Tag                                      0x00
TLS State                                    Enabled
GbE Version 0.3
MEI Driver Version 2251.4.2.0
LMS Version 2302.4.3.0
Wireless Hardware Version 2.1.77
Wireless Driver Version 22.230.0.8
IUPs Information
PCH Information
PCH Name ADL
PCH Device ID 7A83
PCH Revision ID B1
Flash Information
SPI Flash ID 1 C22019
RPMC Unsupported
RPMC Bind Counter 0
FW Capabilities 0x1DF2D106
Intel(R) Standard Manageability Present/Enabled
EOM Flow Full
FPF Committed Yes
Intel(R) AMT State in FW Present/Disabled
MAC Address 7c-57-58-14-bb-54
Configuration State Completed
Wired AMT Link Status Link Down
Localized Language Italian
System UUID ffaba40f-1fd0-4a01-aa42-0161a1a0f5e1
Wireless IPv6 Enablement Unsupported
Intel(R) Standard Manageability State Enabled
Intel(R) Seal State Disabled
PAVP State Yes
HW Glitch Detection 0x509
TRC State Enabled
SMx State Enabled
Debug Information
Token Present No
Consent No
*In Use
OEM ID 0x00 0x00
DNX SVN 0x00 0x00
IDLM SVN 0x00 0x00
PMC SVN 0x00 0x00
Ucode SVN 0x00 0x00
I am quite sure now that it would work, at the very least when the OS is running.
Well, no experience with wireless for newer ME versions, but I don’t see anything that’s missing? Did you check the wireless firmware entry in FIT when decomposing? (Wireless compatibility depends on existing firmware in ME for corresponding wireless generation)
I’d just buy one module and try, they aren’t too expensive?
With installed WLAN card and firmware mismatch this was mentioned in MEInfo 14 at least:
(Why is one machine just ISM?)
One machine is just ISM because HP tries to squezee more money by selling the same product under two different model names, and the AMT one for a premium. They seem to have the same identical ME code, and indeed ISM should now support wi-fi as well starting from this generation. Yes, I think I’ll end up buying and reporting back for the record, but I wanted to have a second opinion first and make sure nothing would break.
Here it says “Solar”, which is the latest codename appeared in the ucode for Linux, so it should refer to the latest AX211/AX411 radio. Also, CLINK is enabled and IIRC is the SMBus used for reporting the vPro capabilities of the module.
UEFITool shows a wlan_drv and the microcode, so I guess nothing should prevent it from working. I’ll go ahead with the purchase and let you know!
The question was if it’s hardware (chipset / processor) or ME config where they restricted capabilities. ME config can quite easily be changed.
No, the rest is vPro capable on both (and indeed work), just the radio module. About changing the config on these… despite Sure Start it should work, but I tried shorting the FDO pad and couldn’t rewrite the ME section. Both flash are also a wson-8 package, so not as frictionless.
Anyway, thank you for your help :slightly_smiling_face: I will come back with any update once I receive the modules.
For the record, AMT/ISM over WiFi works perfectly after swapping the radio module with the vPro part on both PCs. Thanks everybody for helping!
Thanks for the feecback!
can you tell me what kind of model you used
AX211.NGWG MM:999M0W
AX211.NGWG.NV MM:999M5J
Thank you very much
999M0W is ok
Does this allow you to use Wake On Wirelss Lan for the upgraded 800 G9?
I have a G9 I want to wake via wifi but see no option in the BIOS, only Wake on Lan (BIOS version U21 02.16.00). Not sure if this upgrade will allow that or if the vPro functionality is unrelated
