Here are my results from MEInfo (MSI GE72 laptop, chipset HM170):
Copyright(C) 2005 - 2016, Intel Corporation. All rights reserved.
FW Status Register1: 0x90000245
FW Status Register2: 0x00F60506
FW Status Register3: 0x00000000
FW Status Register4: 0x00084400
FW Status Register5: 0x00000000
FW Status Register6: 0x40000000
CurrentState: Normal
ManufacturingMode: Disabled
FlashPartition: Valid
OperationalState: CM0 with UMA
InitComplete: Complete
BUPLoadState: Success
ErrorCode: No Error
ModeOfOperation: Normal
SPI Flash Log: Not Present
Phase: ROM/Preboot
ICC: Valid OEM data, ICC programmed
ME File System Corrupted: No
PhaseStatus: AFTER_SRAM_INIT
FPF and ME Config Status: Match
FW Capabilities value is 0x31111940
Feature enablement is 0x11111940
Platform type is 0x11220321
No Intel vPro Wireless device was found
Intel(R) ME code versions:
Windows OS Version : 6.1.7601 āService Pack 1ā
Table Type 11 ( 0x 0B ) found, size of 5 (0x 05 ) bytes
Table Type 0 ( 0x 00 ) found, size of 24 (0x 18 ) bytes
BIOS Version E1795IMS.114
Table Type 1 ( 0x 01 ) found, size of 27 (0x 1B ) bytes
Table Type 2 ( 0x 02 ) found, size of 15 (0x 0F ) bytes
Table Type 3 ( 0x 03 ) found, size of 22 (0x 16 ) bytes
Table Type 8 ( 0x 08 ) found, size of 9 (0x 09 ) bytes
Table Type 9 ( 0x 09 ) found, size of 17 (0x 11 ) bytes
Table Type 10 ( 0x 0A ) found, size of 6 (0x 06 ) bytes
Table Type 12 ( 0x 0C ) found, size of 5 (0x 05 ) bytes
Table Type 32 ( 0x 20 ) found, size of 20 (0x 14 ) bytes
Table Type 34 ( 0x 22 ) found, size of 11 (0x 0B ) bytes
Table Type 26 ( 0x 1A ) found, size of 22 (0x 16 ) bytes
Table Type 36 ( 0x 24 ) found, size of 16 (0x 10 ) bytes
Table Type 35 ( 0x 23 ) found, size of 11 (0x 0B ) bytes
Table Type 28 ( 0x 1C ) found, size of 22 (0x 16 ) bytes
Table Type 27 ( 0x 1B ) found, size of 15 (0x 0F ) bytes
Table Type 29 ( 0x 1D ) found, size of 22 (0x 16 ) bytes
Table Type 39 ( 0x 27 ) found, size of 22 (0x 16 ) bytes
Table Type 41 ( 0x 29 ) found, size of 11 (0x 0B ) bytes
Table Type 248 ( 0x F8 ) found, size of 9 (0x 09 ) bytes
Table Type 7 ( 0x 07 ) found, size of 19 (0x 13 ) bytes
Table Type 4 ( 0x 04 ) found, size of 48 (0x 30 ) bytes
Table Type 16 ( 0x 10 ) found, size of 23 (0x 17 ) bytes
Table Type 17 ( 0x 11 ) found, size of 40 (0x 28 ) bytes
Table Type 19 ( 0x 13 ) found, size of 31 (0x 1F ) bytes
Table Type 221 ( 0x DD ) found, size of 12 (0x 0C ) bytes
Table Type 20 ( 0x 14 ) found, size of 35 (0x 23 ) bytes
Table Type 130 ( 0x 82 ) found, size of 20 (0x 14 ) bytes
Table Type 131 ( 0x 83 ) found, size of 64 (0x 40 ) bytes
MEBx Version found is 11.0.0.0005
MEBx Version 11.0.0.0005
GbE Region does not exist.
GbE Version Unknown
Vendor ID 8086
PCH Version 31
FW Version 11.0.0.1168 H
LMS Version Not Available
MEI Driver Version 11.0.5.1189
Wireless Hardware Version 2.1.77
Wireless Driver Version 18.12.0.3
FW Capabilities 0x31111940
Intel(R) Capability Licensing Service - PRESENT/ENABLED
Protect Audio Video Path - PRESENT/ENABLED
Intel(R) Dynamic Application Loader - PRESENT/ENABLED
Service Advertisement & Discovery - NOT PRESENT
Intel(R) NFC Capabilities - NOT PRESENT
Intel(R) Platform Trust Technology - PRESENT/DISABLED
TLS Disabled
Last ME reset reason Power up
Local FWUpdate Enabled
BIOS Config Lock Enabled
GbE Config Lock Enabled
Get flash master region access statusā¦done
Host Read Access to ME Disabled
Host Write Access to ME Disabled
Get EC region access statusā¦done
Host Read Access to EC Disabled
Host Write Access to EC Disabled
Protected Range Register Base #0 0x0
Protected Range Register Limit #0 0x0
Protected Range Register Base #1 0x0
Protected Range Register Limit #1 0x0
Protected Range Register Base #2 0x0
Protected Range Register Limit #2 0x0
Protected Range Register Base #3 0x0
Protected Range Register Limit #3 0x0
Protected Range Register Base #4 0x0
Protected Range Register Limit #4 0x0
SPI Flash ID 1 C84017
SPI Flash ID 2 Unknown
BIOS boot State Post Boot
OEM ID 00000000-0000-0000-0000-000000000000
Capability Licensing Service Enabled
OEM Tag 0x00000000
Slot 1 Board Manufacturer 0x00000000
Slot 2 System Assembler 0x00000000
Slot 3 Reserved 0x00000000
M3 Autotest Disabled
C-link Status Disabled
Independent Firmware Recovery Disabled
EPID Group ID 0xF81
OEM Public Key Hash FPF 0000000000000000000000000000000000000000000000000000000000000000
Retrieving Variable āOEM Public Key Hashā
OEM Public Key Hash ME 66687AADF862BD776C8FC18B8E9F8E20089714856EE233B3902A591D0D5F2925
ACM SVN FPF 0x0
KM SVN FPF 0x0
BSMM SVN FPF 0x0
GuC Encryption Key FPF 0000000000000000000000000000000000000000000000000000000000000000
Retrieving Variable āGuC Encryption Keyā
GuC Encryption Key ME 6DB65FD59FD356F6729140571B5BCD6BB3B83492A16E1BF0A3884442FC3C8A0E
FPF ME
ā ā
Force Boot Guard ACM Disabled
Retrieving Variable āForce Boot Guard ACM Enabledā
Disabled
Protect BIOS Environment Disabled
Retrieving Variable āProtect BIOS Environment Enabledā
Disabled
CPU Debugging Enabled
Retrieving Variable āCPU Debuggingā
Enabled
BSP Initialization Enabled
Retrieving Variable āBSP Initializationā
Enabled
Measured Boot Disabled
Retrieving Variable āMeasured Boot Enabledā
Disabled
Verified Boot Disabled
Retrieving Variable āVerified Boot Enabledā
Disabled
Key Manifest ID 0x0
Retrieving Variable āKey Manifest IDā
0x0
Enforcement Policy 0x0
Retrieving Variable āError Enforcement Policyā
0x0
PTT Enabled
Retrieving Variable āIntel(R) PTT Supportedā
Enabled
PTT Lockout Override Counter 0x0
EK Revoke State Not Revoked
PTT RTC Clear Detection FPF Not set
As you can see, FW Status Register3: 0x00000000 and firmware version is 11.0.0.1168 H. ME Analyzer shows instead 11.0.0.1180, Region, but Extracted, Consumer H and NOPDM.
Database r57
File: E1795IMS.114
Firmware: Intel ME
Version: 11.0.0.1180
Release: Production
Type: Region, Extracted
FD: Locked
SKU: Consumer H
Rev: D0
VCN: 7
PDM: No
PV: Yes
Date: 24/09/2015
FIT Ver: 11.0.0.1180
FIT SKU: PCH-H HM170
Platform: SKL-SPT
Latest: No
Which version of the ME firmware can I flash? This version: 11.0.10.1002_CON_H_D0_NOPDM_PRD_RGN ?
