Lenovo IdeaPad 710S-13IKB
Motherboard: LS711 16817-1 448.0A701.0011
I do have the clean/RGN firmware for 11.5.0.1058 CON LP if you want to stay at 11.5, just know that it has been replaced by 11.6.
This is from my own notebook. I just checked the file with ME Analyzer. If you need this bios to extract ME let me know I can send to youā¦
Thank you razor_amd for your interest in ME Analyzer and for reporting new firmware. That firmware has been found, please update MEA to the latest version.
thanks for all my friend
Did I miss something or have all links to Intel SPS firmware repositories been removed? Is there a possibility to get a link to the SPS 3.x repository?
Thanks in advance, regards!
SPS is given into two parts, Recovery and Operational. Flash Image Tool is required to build a full SPS region out of these two. I donāt know how versions work (they are not linear like ME/TXE) but I could upload them temporarily if you want. But not now, remind me in a week if youāre still interested.
Thanks a lot for your offer. I will remind you in about a week.
I found some examples of SPS firmware and could compare extracted region files to the OPR and REC parts. All the rgn-files I viewed had a double (identical) operational section (MEA says "Dual OPR") and one recovery section. But there were also differences in extracted OPR and REC sections even for the same version, depending on manufacturer. And there are 4 other sections which seem to be specific to vendor/board and SPS version.
Looking for ME 10.0.55.3000 with ROM Bypass preferably if anybody has one. Otherwise any ME 10.0.X.X with ROM Bypass.
Thanks in advance!
Donāt know if someoneās still collecting: SPS 3 3.01.03.043 can be found in this BIOS package. MEA states it has multiple versions in it?
SPS 3 versions seems to be hardware related:
For Xeon E3 V3/4 versions in this BIOS package
For Xeon E5 V3/4 versions in this BIOS package
They cover the following releases:
Xeon E3 v3/4
03.00.07.024 release
03.00.07.018 release
03.00.07.013 release
03.00.07.012 release
03.00.05.128 release
03.00.05.110 release
03.00.05.068 release
03.00.04.209 release
03.00.04.164 release
03.00.04.162 release
03.00.03.082 release
03.00.03.078 release
03.00.02.203 release
Xeon E5 V3/4
03.01.03.043 release
03.01.03.032 release
03.01.03.021 release
03.01.03.018 release
03.01.03.005 release
03.01.03.004 release
03.01.03.003 release
03.01.03.002 release
03.01.02.005 release
03.01.01.006 release
03.00.07.168 release
03.00.07.154 release
03.00.07.145 release
03.00.07.141 release
03.00.07.114 release
03.00.06.277 release
03.00.06.274 release
03.00.06.267 release
03.00.05.402 release
03.00.05.382 release
03.00.04.459 release
03.00.03.695 release
03.00.03.688 release
I do collect SPS firmware and thatās why MEA shows the green message when something not-in-db is found. However I tend to ignore the .cap files from Intel because they are annoying/custom. I need to manually create the OPR and REC from these so I donāt bother anymore. I donāt understand how SPS versioning works, itās not linear. Maybe the minor version signifies something.
Do those work for you? SPS 3 03.01.03.043 (extracted)
(Why does MEA tell me the version is unknown when I let it check the cap- file but doesnāt say anything when checking OPR- or REC- files?)
I canāt check/test these files or MEA these days, so I donāt know.
Hi, plutomaniac, if you have a sps tools, could you please upload it for public usage? That would very helpfull for me, cause ME tools works incorrect with sps firmware.
Hello to all,
I received a notebook for repair, I got new cstxe file inside an old bios file and the ME analyzer told me to report it here. Also I have downloaded and extracted new bios from manufacturer website so you should have a clean one also. In rar file, there are both bios files.
https://www.mediafire.com/file/o1xv31d7nā¦_3.0.1.1105.rar
Hello razor_amd,
Thank you very much for your report and for using ME Analyzer. The dumped image is very interesting and a little different from what Iāve seen so far. Iāll need to look into it and update MEA to work with it. The image from the OEM is exactly what MEA expects. Do you know what model that is by any chance?
Hello, I downloaded the Analyzer and it also told me to post here. I hope this aids in your effort to better understand the ME.
Comes from a HP Elitebook 8570w.
Greetings!
ME8_5M_Production.zip (4.41 MB)
i need cse txe 3.0.1.1105
Thank you for your report Swoosh and for using ME Analyzer.
It may be that the original bios from notebook was corrupt, so I downloaded fresh from their site. The notebook is Acer Aspire ES1-132, motherboard is: da0zhpmb8f0 rev.f
