Hello everybody!
I have one question, is it possible to downgrade Intel ME 11.8.65.3590 firmware to 11.8.65.3572 without hardware programmer, on ASUS Maximus Ranger, Z170 chipset?
Thanks.
What about E1 pinmod, unlock FD, then FPT flash ME region?
I also have an ASUS motherboard with the Z170 chipset and I’m waiting for the upgrade to Intel ME 11.8.65.3590. Do you have any problems with that version if you want to downgrade?
@ibsajc - You cannot downgrade ME easily, which is answered above at #2. If you are considering downgrading, then don’t update, it’s not something you can easily switch back and forth unless you have a flash programmer in your hand
Thanks @Lost_N_BIOS.
I do not intend to downgrade unless the Intel ME 11.8.65.3590 version has problems.
I am going to upgrade to correct the vulnerabilities of INTEL-SA-00213 because the Z170 chipset motherboard is in a critical server system.
Ok, thanks. I don’t have any problem with 11.8.65.3590, i’m just curious.
