ME Analyzer: Intel Engine Firmware Analysis Tool Discussion
1
MEA.exe ..\bios.bin -ubu
in UBU v1.32.1
1
MEA.exe ..\bios.bin
in UBU v1.32
It is difficult to remove a key "-ubu"? ;)
OK,removed "-ubu" text.
Now OK.....
Thanks SoniX.
Update 06/09/2015:
ME Analyzer v1.3.0
Added support for Lordkag’s Extractor
Added support for UEFI Bios Updater (UBU)
Added TXE 1.2 firmware detection & support
Added Skylake Flash Descriptor Access Region support
Added ME 11.0 Skylake COR/CON & H/LP SKU support
Added ME 11.0 Skylake PCH-H/LP FIT SKU detection
Added ME 11.0 Skylake Release (PRD, PRE, BYP) support
Added ME 11.0 Skylake Type (RGN, EXTR, UPD) support
Added ME 11.0 Skylake Version Control Number (VCN) support
Added ME 11.0 Skylake Partial Update firmware detection
Added Multiple Engine Firmware Region (number only) detection
Added Unidentifiable Engine Firmware Region (ex: Corrupted) detection
Added Fujitsu Compressed Engine Firmware Region detection
Improved Multi Drop functionality to keep images with any messages
Improved Multi Drop functionality to not delete but rename known files
Improved SPI Flash Descriptor Access Region detection
Improved User Interface & Messages for easier understanding
Improved MEA Info v0.3 with better Error Handling & Messages
Adjusted latest ME 11.0 CON H SKU to 11.0.0.1171
Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1160
Adjusted latest ME 11.0 COR H SKU to 11.0.0.1168
Adjusted latest ME 11.0 COR LP SKU to 11.0.0.1122
Adjusted latest ME 10.0 1.5MB SKU to 10.0.45.1024
Adjusted latest ME 10.0 5MB SKU to 10.0.46.1002
Adjusted latest ME 9.1 1.5MB SKU to 9.1.32.1002
Adjusted latest ME 9.1 5MB SKU to 9.1.32.1002
Adjusted latest ME 8 1.5MB SKU to 8.1.65.1586
Adjusted latest ME 8 5MB SKU to 8.1.65.1586
Adjusted latest ME 7 1.5MB SKU to 7.1.80.1214
Adjusted latest TXE 2.0 1.375MB SKU to 2.0.0.2077
Adjusted latest TXE 1.2 1.375MB BYT-MD SKU to 1.2.0.1149
Adjusted latest TXE 1.1 1.375MB BYT-MD SKU to 1.1.4.1145
Adjusted latest SPS 3 Sub-SKU 0 to 03.00.07.173.0
Updated pre-fixed detection of TXE 2.x BSW & CHT platforms
Updated pre-fixed detection of TXE 1.x BYT-M/D & BYT-I platforms
Updated Engine Firmware Repository Database to r24
Engine Firmware Repository Database r24
Added ME 11.0.0.1171_CON_H_PRD_EXTR
Added ME 11.0.0.1168_CON_H_PRD_RGN
Added ME 11.0.0.1168_COR_H_PRD_EXTR
Added ME 11.0.0.1166_CON_H_PRD_EXTR
Added ME 11.0.0.1166_COR_H_PRD_EXTR
Added ME 11.0.0.1163_COR_H_PRD_EXTR
Added ME 11.0.0.1163_CON_H_PRD_RGN
Added ME 11.0.0.1160_CON_LP_C0_PRD_RGN
Added ME 11.0.0.1160_CON_H_D0_PRD_RGN
Added ME 11.0.0.1160_COR_H_PRD_EXTR
Added ME 11.0.0.1160_CON_LP_B1_PRE_RGN
Added ME 11.0.0.1160_CON_H_D0_PRE_RGN
Added ME 11.0.0.1160_CON_H_C0_PRE_RGN
Added ME 11.0.0.7101_CON_H_PRD_EXTR
Added ME 11.0.0.1158_COR_H_PRD_EXTR
Added ME 11.0.0.1158_CON_H_PRD_EXTR
Added ME 11.0.0.1155_CON_H_PRD_EXTR
Added ME 11.0.0.1153_COR_H_PRD_EXTR
Added ME 11.0.0.1151_COR_H_PRD_EXTR
Added ME 11.0.0.1149_CON_H_PRD_EXTR
Added ME 11.0.0.1144_COR_H_PRD_EXTR
Added ME 11.0.0.1140_CON_H_PRD_EXTR
Added ME 11.0.0.1131_CON_H_PRD_EXTR
Added ME 11.0.0.1122_COR_LP_B1_PRE_RGN
Added ME 11.0.0.1122_COR_LP_B0_BYP_RGN
Added ME 11.0.0.1122_COR_H_C0_PRE_RGN
Added ME 11.0.0.1122_COR_H_B0_PRE_RGN
Added ME 11.0.0.1120_CON_H_PRE_EXTR
Added ME 10.0.46.1002_5MB_PRD_RGN
Added ME 8.1.65.1586_1.5MB_PRD_RGN
Added TXE 2.0.0.2077_1.375MB_PRD_RGN
Added TXE 1.2.0.1149_1.375MB_PRD_RGN
Added TXE 1.1.1.1130_1.375MB_PRD_RGN
Added TXE 1.1.0.1113_1.375MB_PRD_RGN
Removed TXE 1.1.0.1113_1.375MB_PRD_EXTR
Added SPS 03.00.07.173.0_PRD_RGN
Added SPS 02.03.00.386.1_PRD_RGN
Added SPS 02.01.07.076.1_PRD_RGN
Added SPS 02.00.07.011.1_PRD_RGN
ME Analyzer v1.3.4
Added ME 11.0 Skylake firmware detection at GUID DE90FFA8
Added Dell Firmware Update OEM ID detection
Adjusted latest ME 11.0 COR H SKU to 11.0.0.1171
Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1168
Adjusted latest ME 11.0 COR LP SKU to 11.0.0.1166
Adjusted latest ME 10.0 1.5MB SKU to 10.0.46.1002
Updated pre-fixed detection of ME 11.0 CON/COR H/LP SKUs
UEFIFind v0.3.4 by CodeRush is now included at MEA for Skylake
Updated Engine Firmware Repository Database to r25
Note for UBU & Extractor: MEA will automatically pick your own UEFIFind.exe from …\MEA directory. Don’t include it twice.
Engine Firmware Repository Database r25
Added ME 11.0.0.1171_COR_H_PRD_EXTR
Added ME 11.0.0.1168_CON_LP_PRD_RGN
Added ME 11.0.0.1166_CON_LP_PRD_EXTR
Added ME 11.0.0.1166_COR_LP_C0_PRD_RGN
Added ME 11.0.0.1166_COR_H_D0_PRE_RGN
Renamed ME 11.0.0.1166_COR_H_D0_PRD_RGN
Added ME 11.0.0.1166_CON_H_PRD_RGN
Removed ME 11.0.0.1166_CON_H_PRD_EXTR
Added ME 11.0.0.1166_COR_H_PRD_RGN
Removed ME 11.0.0.1166_COR_H_PRD_EXTR
Added ME 10.0.46.1002_1.5MB_PRD_EXTR
Added ME 7.1.0.1005_5MB_CPT_PRE_EXTR
UBU 1.37 with ME Analyzer v1.3.4…why RED warning ?
With ME Analyzer v1.3.0 is OK.
@ ex58:
There is a bug with v1.3.4 (which will be fixed soon) when it comes to UEFIFind.exe but it’s only for Extractor, not Ubu. I can run it just fine with UBU v1.37 and MEA v1.3.4:
Have you removed the UEFIFind.exe from UBU folder?
Can someone else test this as well? All you need is UBU v1.37 and any Skylake SPI image.
The problem is in the path to UEFIFind (one extra dot). I get the same, even when placing UEFIFind in MEA folder. To solve it, I have to put UEFIFind to Extractor’s folder parent, two levels up from MEA.exe tool.
HA-HA, ow… That’s funny.
I have a folder called UBU (old name, don’t want to change it) and inside I have many subfolders two of which are Extractor and UBU. UBU and Extractor folders do have UEFIFInd.exe inside but I also have UEFIFind.exe at the parent UBU folder. During my testing, I thought that MEA was using the UEFIFind.exe from the UBU/Extractor subfolders but it was always the one under the parent UBU folder. So as lordkag said, that’s two folders up MEA. Lovely…
The bug I was referring to is actually different. Previously the different directory (./) was triggered only when -adir argument was called which is fine for UBU and Extractor. But Extractor sometimes calls other arguments without -adir so in such a case it would report the error.
Anyway, both bugs will be fixed with v1.3.5 which will be released tomorrow with some new SKL firmware (1171 CON LP etc).
I don’t know if it was an error in previous Extractor test versions, but the current one always uses -adir when calling MEA. UBU does the same, so it might be easy to search in current folder by default, or search in parent folder when -adir. But due to how CMD and Python interact, I believe you have to search in current folder when using -adir, just as default case. Only for MEA_DB.txt there is a different case, where you have to search for MEA\MEA_DB.txt when using -adir.
Oh yes, you are right. I forgot for a moment that even when you call -msg you do need -adir so that the MEA_DB.txt is found, searched and then display any relevant “rare” messages. The current fixed version is set like this:
But I suppose, if -adir is always called by UBU and Extractor for the MEA_DB, the other three checks (ubu, extractor, messages) are not needed. I’ll revert back to -adir check only and now the double dot is fixed. I think it works that way (based on a quick UBU check) but tomorrow I will make sure with both UBU and Extractor before v1.3.5 is released.
But if we assume the same situation from MEA_DB.txt, then the combination .bat + .py will set the default folder as the one of .bat, not MEA. So having two cases is not useless, but it will give you the same bugged result, I think. Only the second case is needed for UEFIFind, no matter if -adir or not. But check with a separate clean folder for UBU and for Extractor, I won’t try to guess when it comes to CMD, too many burns.
ME Analyzer v1.3.5
Added proper FWUpdate OEM ID detection for Skylake
Added display of ME 11.0 Skylake Stepping/Revision (table-based)
Fixed “UEFIFind.exe file not found” error at UBU & Extractor
ME7 PRE/BYP UPD images won’t be reported as new if RGN/EXTR exists
Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1171
Adjusted latest ME 11.0 COR LP SKU to 11.0.0.1169
Updated Engine Firmware Repository Database to r26
Engine Firmware Repository Database r26
Added ME 11.0.0.1171_CON_LP_PRD_EXTR
Added ME 11.0.0.1169_COR_LP_PRD_EXTR
Added ME 11.0.0.1169_CON_LP_PRD_EXTR
Added ME 11.0.0.1165_COR_LP_PRD_EXTR
Added ME 11.0.0.1165_CON_LP_PRD_EXTR
Added ME 11.0.0.1160_COR_LP_PRD_EXTR
Added ME 11.0.0.1158_CON_LP_BYP_EXTR
Added ME 11.0.0.1155_COR_H_PRD_EXTR
Added ME 11.0.0.1148_COR_H_PRD_RGN
Added ME 11.0.0.1120_CON_LP_BYP_EXTR
Added ME 11.0.0.1115_CON_LP_BYP_EXTR
Added ME 11.0.0.1100_CON_LP_BYP_EXTR
Added ME 10.0.26.1000_5MB_PRD_EXTR
Added ME 7.1.13.1088_1.5MB_CPT_PRD_RGN
Removed ME 7.1.13.1088_1.5MB_CPT_PRD_EXTR
Added ME 7.1.13.1088_1.5MB_CPT_PRE_RGN
Added ME 7.1.13.1088_5MB_CPT_PRD_RGN
Removed ME 7.1.13.1088_5MB_CPT_PRD_EXTR
Added ME 7.1.13.1088_5MB_CPT_PRE_RGN
Removed all ME7 PRE/BYP UPD images
@lordkag
The UEFIFind.exe command worked as expected without any additional change other than removing the double dot from the path. It seems that Popen uses the .py directory as the working one even when called by another process. However, that does not apply to Open file to read/write command.
ME Analyzer v1.3.6
Added support for ME 10.0 1.5MB Apple MAC firmware SKU
Improved ME 11.0 PCH-H/LP No Emulation FIT SKU detection
Adjusted latest ME 11.0 CON H SKU to 11.0.0.1173
Adjusted latest ME 10.0 1.5MB Apple MAC SKU to 10.0.35.1012
Adjusted latest ME 9.5 1.5MB Apple MAC SKU to 9.5.4.1856
Adjusted latest TXE 2.0 1.375MB SKU to 2.0.1.2084
Updated Engine Firmware Repository Database to r27
Engine Firmware Repository Database r27
Added ME 11.0.0.1173_CON_H_PRD_EXTR
Added ME 11.0.0.1160_COR_LP_PRD_RGN
Removed ME 11.0.0.1160_COR_LP_PRD_EXTR
Added ME 10.0.35.1012_1.5MB_MAC_PRD_EXTR
Added ME 9.5.4.1856_1.5MB_MAC_PRD_EXTR
Added ME 9.0.6.1492_1.5MB_PRD_EXTR
Removed ME 9.0.5.1367_1.5MB_MAC_PRD_EXTR
Added TXE 2.0.1.2084_1.375MB_PRD_RGN
Added TXE 2.0.1.2084_1.375MB_PRE_RGN
ME Analyzer v1.3.7
The Updated entry is now shown for all Production images
ME Info v0.4 is now a standalone executable window
Removed MEA Menu mode (use Drop or ME Info instead)
Adjusted latest ME 11.0 CON H SKU to 11.0.0.1178
Adjusted latest ME 11.0 COR H SKU to 11.0.0.1178
Adjusted latest ME 10.0 1.5MB SKU to 10.0.47.1006
Adjusted latest TXE 1.2 1.375MB BYT-T SKU to 1.2.1.1153
Updated Engine Firmware Repository Database to r28
Note 1: Msvcr100.dll might not be needed anymore for Windows XP. If someone can test it, please do so and report back.
Note 2: UBU & Extractor only need MEA.exe, MEA_DB.txt and Msvcr100.dll (maybe, for Windows XP only)
Engine Firmware Repository Database r28
Added ME 11.0.0.1178_CON_H_PRD_RGN
Added ME 11.0.0.1178_COR_H_PRD_RGN
Added ME 11.0.0.1173_COR_H_PRD_EXTR
Added ME 10.0.47.1006_1.5MB_PRD_RGN
Added ME 10.0.47.1006_1.5MB_PRE_RGN
Added ME 10.0.47.1006_1.5MB_BYP_RGN
Added ME 7.1.86.1221_5MB_ALL_PRD_EXTR
Added ME 7.1.60.1193_5MB_ALL_PRD_EXTR
Added ME 4.2.40.1048_ALL_PRD_EXTR
Added ME 4.2.30.1040_ALL_PRD_EXTR
Added ME 4.1.11.1051_ALL_PRD_EXTR
Added ME 4.0.8.1139_ALL_PRD_EXTR
Added ME 2.2.30.1046_AMT_PRD_RGN
Added ME 2.2.10.1039_AMT_PRD_RGN
Added TXE 1.2.1.1153_1.375MB_PRD_EXTR
Added TXE 1.2.0.1144_1.375MB_PRD_EXTR
Engine Firmware Repository Database r29
Added ME 11.0.0.1173_CON_H_PRD_RGN
Added ME 11.0.0.1173_COR_H_PRD_RGN
Removed ME 11.0.0.1173_COR_H_PRD_EXTR
Added ME 11.0.0.1160_COR_H_PRE_EXTR
Added ME 11.0.0.1158_COR_H_D0_PRD_RGN
Removed ME 11.0.0.1158_COR_H_PRD_EXTR
Added ME 11.0.0.1158_COR_H_C0_PRE_RGN
Added ME 11.0.0.1158_COR_H_D0_PRE_RGN
Added ME 11.0.0.1158_COR_LP_B0_BYP_RGN
Added ME 11.0.0.1158_COR_LP_B1_PRE_RGN
Added ME 11.0.0.1158_COR_LP_C0_PRD_RGN
Added ME 11.0.0.1153_COR_H_PRE_EXTR
Added ME 11.0.0.1133_COR_H_PRD_EXTR
Added ME 7.0.2.1164_5MB_CPT_PRD_RGN
Removed 7.0.2.1164_5MB_CPT_PRD_EXTR
Added ME 7.0.2.1164_5MB_CPT_PRE_RGN
Added ME 7.0.0.1149_5MB_CPT_PRD_UPD
Added ME 7.0.0.1149_5MB_CPT_PRD_RGN
Added ME 7.0.0.1149_5MB_CPT_PRE_RGN
Removed all ME 6.0 IGN UPD images
ME Analyzer v1.3.8
ME 6.0 IGN UPD images won’t be reported as new if RGN/EXTR exists
Adjusted latest ME 11.0 CON/COR H SKU to 11.0.0.1180
Adjusted latest ME 11.0 COR LP SKU to 11.0.0.1173
Adjusted latest ME 9.5 1.5MB/5MB SKU to 9.5.52.1940
Adjusted latest ME 6 1.5MB UPD firmware to 6.1.31.1075
Updated pre-fixed detection of ME 11.0 Firmware SKUs
Updated Engine Firmware Repository Database to r30
Note: UBU & Extractor only need MEA.exe & MEA_DB.txt
Engine Firmware Repository Database r30
Added ME 11.0.0.1180_CON_H_PRD_RGN
Added ME 11.0.0.1180_COR_H_PRD_RGN
Added ME 11.0.0.1173_COR_LP_C0_PRD_RGN
Renamed ME 11.0.0.1173_COR_H_D0_PRD_RGN
Added ME 11.0.0.1173_COR_H_D0_PRE_RGN
Added ME 11.0.0.1173_COR_LP_B1_PRE_RGN
Added ME 11.0.0.1171_COR_LP_C0_PRD_RGN
Added ME 11.0.0.1171_CON_LP_C0_PRD_RGN
Removed ME 11.0.0.1171_CON_LP_PRD_EXTR
Added ME 11.0.0.1160_COR_H_PRD_RGN
Removed ME 11.0.0.1160_COR_H_PRD_EXTR
Added ME 9.5.52.1940_1.5MB_PRD_RGN
Added ME 9.5.52.1940_5MB_PRD_RGN
Added ME 7.1.10.1065_5MB_CPT_PRD_RGN
Removed ME 7.1.10.1065_5MB_CPT_PRD_EXTR
Added ME 7.1.10.1065_5MB_CPT_PRE_RGN
Added ME 6.1.31.1075_1.5MB_PRD_UPD
Added ME 6.1.31.1075_5MB_MB_PRD_UPD
ME Analyzer v1.3.10
Added SPS 4 OPR/REC/EXTR firmware detection & support
Added SPS 1 OPR/REC firmware detection & support
Added MEA Help/Usage Screen (-? or -h to view it)
Improved Fujitsu Compressed UMIM SPI/RGN detection
SPS 1-4 OPR/REC images won’t be reported as new if EXTR exists
Adjusted latest ME 11.0 COR LP SKU to 11.0.0.1180
Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1173
Adjusted latest SPS 4 Sub-SKU 0 to 04.00.03.036.0
Adjusted latest SPS 3 Sub-SKU 1 to 03.00.07.168.1
Updated Engine Firmware Repository Database to r31
Engine Firmware Repository Database r31
Added ME 11.0.0.1180_COR_LP_C0_PRD_RGN
Added ME 11.0.0.1180_COR_LP_B1_PRE_RGN
Added ME 11.0.0.1180_COR_H_D0_PRE_RGN
Renamed ME 11.0.0.1180_COR_H_D0_PRD_RGN
Renamed ME 11.0.0.1180_CON_H_D0_PRD_RGN
Added ME 11.0.0.1178_COR_H_D0_PRE_RGN
Added ME 11.0.0.1178_COR_LP_B1_PRE_RGN
Renamed ME 11.0.0.1178_CON_H_D0_PRD_RGN
Renamed ME 11.0.0.1178_COR_H_D0_PRD_RGN
Added ME 11.0.0.1173_CON_LP_C0_PRD_RGN
Added ME 11.0.0.1173_CON_H_D0_PRE_RGN
Added ME 11.0.0.1173_CON_LP_B1_PRE_RGN
Renamed ME 11.0.0.1173_CON_H_D0_PRD_RGN
Added ME 11.0.0.1171_CON_H_D0_PRD_RGN
Removed ME 11.0.0.1171_CON_H_PRD_EXTR
Added ME 11.0.0.1171_CON_H_D0_PRE_RGN
Added ME 11.0.0.1171_CON_LP_B1_PRE_RGN
Renamed ME 11.0.0.1171_COR_H_D0_PRD_EXTR
Renamed ME 11.0.0.1168_CON_LP_C0_PRD_RGN
Renamed ME 11.0.0.1168_CON_H_D0_PRD_RGN
Added ME 11.0.0.1168_COR_H_D0_PRD_RGN
Removed ME 11.0.0.1168_COR_H_PRD_EXTR
Added ME 11.0.0.1168_CON_H_D0_PRE_RGN
Added ME 11.0.0.1168_COR_H_D0_PRE_RGN
Added ME 11.0.0.1168_COR_LP_C0_PRD_RGN
Renamed ME 11.0.0.1166_CON_H_D0_PRD_RGN
Renamed ME 11.0.0.1166_CON_LP_C0_PRD_EXTR
Renamed ME 11.0.0.1160_COR_LP_C0_PRD_RGN
Renamed ME 11.0.0.1160_COR_H_D0_PRD_RGN
Renamed ME 11.0.0.1158_CON_LP_B0_BYP_EXTR
Renamed ME 11.0.0.1158_CON_H_D0_PRD_EXTR
Added TXE 2.0.0.2075_1.375MB_PRD_EXTR
Added SPS 04.00.03.036.0_PRD_EXTR
Added SPS 03.00.07.168.1_PRD_EXTR
Added SPS 03.00.07.157.1_PRD_EXTR
ME Analyzer v1.3.11
Merged MEA & MEInfo into MEA (-info to view it)
Fixed issue that triggered -h parameter by accident
Fixed issue that caused -extr to report images as UMEM
Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1180
Adjusted latest SPS 4 Sub-SKU 0 to 04.00.03.061.0
Updated Engine Firmware Repository Database to r32
Engine Firmware Repository Database r32
Added ME 11.0.0.1180_CON_LP_C0_PRD_EXTR
Added ME 11.0.0.1171_COR_H_D0_PRD_RGN
Removed ME 11.0.0.1171_COR_H_D0_PRD_EXTR
Added ME 11.0.0.1171_COR_H_D0_PRE_RGN
Added ME 11.0.0.1171_COR_LP_B1_PRE_RGN
Added ME 10.0.45.1022_1.5MB_PRD_RGN
Removed ME 10.0.45.1022_1.5MB_PRD_EXTR
Added ME 10.0.45.1022_1.5MB_PRE_RGN
Added ME 10.0.45.1022_1.5MB_BYP_RGN
Added SPS 04.00.03.061.0_PRD_EXTR
ME Analyzer v1.3.12
Added Fujitsu non-Compressed UMEM RGN/UPD detection
Adjusted latest ME 11.0 CON H SKU to 11.0.0.1191
Adjusted latest SPS 4 Sub-SKU 0 to 04.00.03.075.0
Updated Engine Firmware Repository Database to r33
Engine Firmware Repository Database r33
Added ME 11.0.0.1191_CON_H_PRD_EXTR
Added ME 11.0.0.1180_CON_LP_C0_PRD_RGN
Removed ME 11.0.0.1180_CON_LP_C0_PRD_EXTR
Added SPS 04.00.03.075.0_PRD_EXTR
Added SPS 04.00.03.068.0_PRD_EXTR
Added SPS 04.00.03.056.0_PRD_EXTR
Added SPS 04.00.03.046.0_PRD_EXTR
@ plutomaniac:
Some weeks ago I had successfully updated the Intel ME Firmware for my ASRock Z97 Extreme6 mainboard to v9.1.32.1002.
Yesterday I flashed the brandnew BIOS v2.50. While trying to modify it by using UBU v1.42 I got a strange Intel ME Analyzer v1.3.11 result:
Just to make sure, whether the previous ME Firmware update was overwritten by the new BIOS, I ran the MEInfo tool. Here is the result:
What is the reason for these different results?
Hello, I happened to be online so I’ll reply quickly:
I’m certain you know this but just in case, MEA shows the ME firmware that is inside the loaded SPI image (not the system’s SPI chip). The latest BIOS from the OEM seems to have the older 9.1.25 inside. Your system is updated to the latest though via FWUpdate. If you want to check your own system’s ME firmware, run MEA -info command. As for Updated No, it’s not since the latest is 9.1.32 and not 9.1.25.
