@ plutomaniac: Thanks for the quick reply and the clear statement. I must admit, that I didn’t know, that the ME Analyzer, which is part of the UBU tool, shows something else than the MEInfo tool, but after having run the latest MEA.exe with the command suffix -info I got clarity:
Ah no, just like UBU shows what Intel oROMs/Modules a given SPI image has, it also calles MEA which it turn shows what ME a given SPI image comes with.
When it comes to what firmware the actual system has at it’s SPI chip you can use MEA (only for firmware & driver versions) or MEInfo of course. MEA -info is just a lot faster to perform (and multi-platform) when only the firmware or driver version is what you are looking for.
Yes, my previous post was the result of an error of reasoning. There is a big difference between the Intel ME Firmware, which is within a BIOS file, and the Intel ME Firmware, which is within the BIOS chip of the user. Thanks again for the clarification.
Thank you very much for registering to let me know of this. To extract the System Tools you need WinRar 5.x or the latest version of 7-zip. Are you planning to update your firmware? Can you do me a quick small favor? At the System Tools package, go to FWUpdate folder (let’s say Windows64), open a command prompt and run FWUpdLcl64 -save ME.bin. Then attach here the ME.bin file that appeared. I am looking for people who have “corporate” systems with 5MB firmware like yours and thus the message you saw.
Thank you for the file you attached. I downloaded it with difficulty due to forum weirdness with certain filetyes so I re-packaged/attached it as a .rar archive. Check the other thread you opened for a reply regarding your update problem.
@ pustekuchencake:
Thank you for using ME Analyzer. You need to determine the platform as well to know whether you need 1.5MB or 5MB firmware. Afterwards you can proceed to update to the latest ME8 firmware which is 8.1.65.1586. The ME is practically the backbone of a modern Intel system, more info on it’s uses and “hidden” benefits at the ME thread.
Fixed issue that caused Multi Drop to rename wrong files Adjusted latest ME 11.0 CON H SKU to 11.0.0.1194 Adjusted latest ME 11.0 CON LP SKU to 11.0.0.1191 Adjusted latest ME 11.0 COR H SKU to 11.0.0.1191 Adjusted latest ME 10.0 5MB SKU to 10.0.47.1006 Adjusted latest ME 9.5 1.5MB SKU to 9.5.55.1948 Adjusted latest ME 9.1 1.5MB SKU to 9.1.37.1002 Updated pre-fixed detection of ME 11.0 Firmware SKUs Updated Engine Firmware Repository Database to r34
Engine Firmware Repository Database r34
Added ME 11.0.0.1194_CON_H_PRD_EXTR Added ME 11.0.0.1191_CON_LP_C0_PRD_RGN Added ME 11.0.0.1191_COR_H_PRD_RGN Added ME 11.0.0.1183_CON_H_PRD_RGN Added ME 11.0.0.1183_CON_LP_C0_PRD_RGN Renamed ME 11.0.0.1169_COR_LP_C0_PRD_EXTR Renamed ME 11.0.0.1169_CON_LP_C0_PRD_EXTR Renamed ME 11.0.0.1165_CON_LP_C0_PRD_EXTR Renamed ME 11.0.0.1165_COR_LP_C0_PRD_EXTR Added ME 11.0.0.1153_COR_LP_PRE_EXTR Added ME 11.0.0.1153_COR_LP_BYP_EXTR Added ME 10.0.47.1006_5MB_PRD_RGN Added ME 10.0.45.1024_5MB_PRE_RGN Added ME 10.0.45.1024_5MB_BYP_RGN Added ME 9.5.55.1948_1.5MB_PRD_RGN Added ME 9.5.50.1932_1.5MB_PRD_RGN Added ME 9.5.50.1932_1.5MB_PRE_RGN Added ME 9.5.50.1932_5MB_PRD_RGN Added ME 9.5.50.1932_5MB_PRE_RGN Added ME 9.1.37.1002_1.5MB_PRD_EXTR Added ME 9.1.32.1002_1.5MB_PRD_RGN Removed ME 9.1.32.1002_1.5MB_PRD_EXTR Added ME 9.1.32.1002_1.5MB_PRE_RGN Added ME 8.1.65.1586_1.5MB_PRE_RGN Added ME 8.1.65.1586_5MB_PRE_RGN
Added ME 11.0 Skylake unknown SKU suggestions based on Kernel & FIT Added ME 11.0 Skylake Kernel/FIT SKU analysis forced display (-dker to view) Major TXE overhaul at SKU, Platform, Rare Firmware checking Added obligatory checks that the DB & UEFIFind files exist Added additional ME 4 ROM-Bypass SKU firmware support Added simplistic ME3 ASF & QST SKU ROMB UPD detection Added detection of known Intel Engine EFI GUIDs Added Extractor support for unknown TXE SKUs Added very early AMD PSP firmware detection Added option to hide the temporary 5MB/Corporate note for UPD samples (-updn) Improved SKU detection across the board (ME 2-10, TXE 1-2, SPS 1-3) Moved all latest firmware version checks from MEA to DB Moved all ME11 hash-based SKU detection from MEA to DB Moved all TXE hash-based validation checks from MEA to DB Fixed issue that caused detection of old ME 11.0 PRE firmware as PRD Fixed issue that caused wrong detection of ME4 & ME6 IGN RGN images as EXTR Fixed rare issue that caused MEA to scan the wrong SKU at ME 2 - ME 6 UPD images Fixed issue that did not show the relevant ME 11.0 Kernel DB entries under some circumstances Updated Engine Firmware Repository Database to r35
Engine Firmware Repository Database r35
Latest ME 11.0 COR H SKU to 11.0.0.1194 Latest ME 11.0 CON LP SKU to 11.0.0.1194 Latest ME 11.0 COR LP SKU to 11.0.0.1194 Latest ME 5 AMT Pro SKU to 5.2.71.1048 Latest TXE 2.0 1.375MB SKU to 2.0.2.3094 Added ME 11.0.0.1194_COR_H_XX_PRD_EXTR Added ME 11.0.0.1194_CON_LP_XX_PRD_RGN Added ME 11.0.0.1194_COR_LP_XX_PRD_RGN Added ME 11.0.0.1183_COR_H_XX_PRD_RGN Added ME 11.0.0.1183_COR_LP_C0_PRD_RGN Added ME 11.0.0.1177_COR_H_D0_PRD_EXTR Renamed ME 11.0.0.1133_COR_H_XX_PRE_EXTR Renamed ME 11.0.0.1115_CON_H_XX_BYP_EXTR Added ME 9.0.0.1308_5MB_PRD_EXTR Added ME 7.1.30.1142_5MB_CPT_PRD_RGN Removed ME 7.1.30.1142_5MB_CPT_PRD_EXTR Added ME 7.1.30.1142_5MB_CPT_PRE_RGN Added ME 7.1.4.1068_5MB_CPT_PRD_UPD Added ME 7.0.10.1203_5MB_CPT_PRD_RGN Removed ME 7.0.10.1203_5MB_CPT_PRD_EXTR Added ME 7.0.10.1203_5MB_CPT_PRE_RGN Added ME 7.0.10.1203_5MB_CPT_PRE_UPD Renamed ME 6.0.21.1188_IGN_IP_PRD_EXTR Renamed ME 6.0.20.1185_IGN_IP_PRE_EXTR Renamed ME 6.0.20.1185_IGN_IP_PRD_EXTR Added ME 5.2.71.1048_AMT_PRD_UPD Added ME 5.2.70.1046_AMT_PRD_UPD Added ME 5.2.60.1043_AMT_PRD_UPD Added ME 4.0.0.1035_ALL_BYP_RGN Added ME 4.0.0.1035_ALL_BYP_UPD Renamed ME 4.2.30.1040_TPM_PRD_RGN Renamed ME 4.2.21.1037_TPM_PRD_RGN Renamed ME 4.2.20.1036_TPM_PRE_RGN Renamed ME 4.2.20.1036_TPM_PRD_RGN Renamed ME 4.2.20.1036_ALL_PRE_RGN Renamed ME 4.2.20.1036_ALL_PRD_RGN Renamed ME 4.2.10.1023_TPM_PRE_RGN Renamed ME 4.2.10.1023_TPM_PRD_RGN Renamed ME 4.0.0.1100_ALL_PRE_RGN Renamed ME 4.0.0.1100_ALL_PRD_RGN Added ME 3.0.9.1133_AMT_PRD_UPD Added ME 3.0.5.1125_AMT_PRD_UPD Added ME 3.0.4.1120_AMT_PRD_UPD Added ME 2.1.0.1032_AMT_PRD_UPD Added TXE 2.0.2.3094_1.375MB_PRD_RGN Added TXE 2.0.2.2092_1.375MB_PRD_RGN Added TXE 2.0.1.2091_1.375MB_PRD_RGN Added TXE 2.0.0.2077_1.375MB_PRE_RGN Added TXE 1.1.4.1145_1.375MB_IT_PRD_RGN Added TXE 1.1.0.1089_1.375MB_IT_PRD_EXTR Added TXE 1.0.2.1060_3MB_IT_PRD_RGN Added SPS 03.00.07.018.0_PRD_EXTR Added SPS 03.00.03.009.0_PRD_EXTR
Thank you aragog for using MEA and for reporting your 5MB system. The new 1.4.0 version of MEA does not show that message for ME8 as I’ve already found another user with such system. But if you want, use FWUpdate tool (also attached) with the command FWUpdLcl64.exe -save me.bin and upload/attach the resulting file. I see the system language is not English (Russian I think) and since this message is also language related I’d like to see your own resulting file as well if you may.
Added ME 11.0 Skylake Secure Version Number (SVN) support Fixed SPS 3 ckeck for updated firmware issue Fixed false early detection of unknown AMD PSP firmware Removed known Intel Engine EFI GUID search at UEFI Strip mode Removed ME 11.0 COR and added TXE 1.2 at UPD sample note Updated Engine Firmware Repository Database to r36
Engine Firmware Repository Database r36
Latest ME 11.0 COR H SKU to 11.0.0.1197 Latest ME 9.1 5MB SKU to 9.1.37.1002 Latest ME 6 1.5MB SKU to 6.2.50.1062 Latest SPS 4 Single SKU to 04.00.03.078.0 Added ME 11.0.0.1197_COR_H_XX_PRD_RGN Added ME 11.0.0.1194_COR_H_D0_PRD_RGN Removed ME 11.0.0.1194_COR_H_D0_PRD_EXTR Renamed ME 11.0.0.1194_CON_H_D0_PRD_EXTR Renamed ME 11.0.0.1194_COR_LP_C0_PRD_RGN Renamed ME 11.0.0.1194_CON_LP_C0_PRD_RGN Added ME 11.0.0.1191_COR_LP_C0_PRD_RGN Added ME 11.0.0.1191_COR_H_D0_PRE_RGN Added ME 11.0.0.1191_COR_LP_B1_PRE_RGN Renamed ME 11.0.0.1191_CON_H_D0_PRD_EXTR Renamed ME 11.0.0.1191_COR_H_D0_PRD_RGN Renamed ME 11.0.0.1183_CON_H_D0_PRD_RGN Renamed ME 11.0.0.1183_COR_H_D0_PRD_RGN Added ME 9.1.37.1002_5MB_PRD_RGN Added ME 7.1.70.1198_1.5MB_ALL_PRD_UPD Added ME 6.2.50.1062_1.5MB_PRD_UPD Added ME 6.2.40.1045_1.5MB_PRD_UPD Added ME 6.2.30.1040_1.5MB_PRD_UPD Added ME 6.2.20.1035_1.5MB_PRD_UPD Added ME 6.2.0.1022_1.5MB_PRD_UPD Added ME 6.1.10.1052_1.5MB_PRD_UPD Added ME 6.0.31.1208_1.5MB_PRD_UPD Added SPS 04.00.03.078.0_PRD_EXTR Added SPS 03.01.02.005.0_PRD_EXTR
Added ME 11.0.0.1194_CON_H_D0_PRD_RGN Removed ME 11.0.0.1194_CON_H_D0_PRD_EXTR Added ME 10.0.25.1048_5MB_PRD_RGN Removed ME 10.0.25.1048_5MB_PRD_EXTR Added ME 9.5.10.1652_5MB_PRD_RGN Added ME 9.0.12.1397_5MB_PRD_RGN Added ME 9.0.1.1333_5MB_PRD_RGN Removed ME 9.0.1.1333_5MB_PRD_EXTR Added ME 7.1.51.1177_5MB_ALL_PRD_UPD Added ME 7.1.31.1147_5MB_CPT_PRD_UPD Added ME 6.2.30.1040_5MB_DT_PRD_UPD Added ME 6.2.0.1022_5MB_DT_PRD_UPD Added ME 6.1.10.1052_5MB_DT_PRD_UPD Added ME 6.1.0.1042_5MB_MB_PRD_UPD Added ME 6.1.0.1042_1.5MB_PRD_EXTR Added ME 6.0.4.1205_5MB_MB_PRD_UPD Added ME 6.0.3.7143_5MB_MB_PRE_UPD Added ME 6.0.3.1195_5MB_DT_PRD_UPD Added ME 6.0.2.1194_5MB_MB_PRD_UPD Added ME 6.0.2.1194_5MB_MB_PRD_EXTR Added ME 6.0.2.1194_1.5MB_PRD_UPD Added ME 4.2.40.1048_AMT_PRD_UPD Added ME 4.2.30.1040_AMT_PRD_UPD Added ME 4.2.20.1036_AMT_PRD_UPD Added ME 4.1.10.1046_AMT_PRD_UPD Added ME 4.0.12.1147_AMT_PRD_UPD Added ME 4.0.3.1146_AMT_PRD_UPD Added ME 4.0.3.1124_AMT_PRD_UPD Added ME 4.0.1.1108_AMT_PRD_UPD Added TXE 1.1.3.1133_1.375MB_MD_PRD_RGN Removed TXE 1.1.3.1133_1.375MB_MD_PRD_EXTR
