I got only one question left, the values that you changed on the first fixed.bin, should I keep them changed or should I keep original? I am going to modify some options, year date only goes to 2020 and the CPU Smart its keeping the cpu fan too low, I want to change the 100% speed from 70 to 60º.
You can keep, you mean enabling Local ME FW update, correct? If yes, it’s OK to leave that enabled, that way you can update easily next time too if you want.
