[OFFER] ASUS Rampage V Extreme - modded BIOSes
@Blue_Stinger you need to tag user you are requesting alternate mirror link from, put @ directly in front of their name as I’ve done here with your name
new bios 3902 ASUS Rampage V Extreme (Last CPU Microcodes updated)
https://drive.google.com/file/d/1_8mUo4D…iew?usp=sharing
@Sylar76 Hi Sylar it appears that you are in the know when it comes to BIOS modding so I am going to ask if it is even possible for you to do one of the following on an ASUS Rampage V edition 10 bios.
Enable Bifurcation support OR
Change my PCIex16 Bus slot settings so they can run X16,X8,X8,X8 with the M.2 drive enabled even if it kills a non X16 slot in the process.
The reason why it I am running an Aorus GTX1080 Ti Extreme on my 1st slot which blocks my 2nd slot, on slot 3 I have and Avago 9361-8i Raid Controller and on the 4th a Mellenox Connect X2 SFP ( All slots referred to are mechanically the x16 slots ).
The problem being my Aorus only wants to run at 8x, Tweaking it requires 16x. If I enable 4 Way config in the ASUS bios which sets things to X16,X8,X8,X8 which is what it is anyway but the 2nd x8 is not being used it kills my M.2.
Basically ASUS have failed to take into account that these days most vid cards will block the 2nd X16 slot. I also tried using the switch to literally turn off the 2nd slot and it made no difference so Bifurcation or a modded BIOS is my only choice because I don’t think ASUS is going to do squat.
If you can’t do it or don’t know what the hell I’m talking about that’s all good but I thought I’d at least ask.
As I don’t get a Rampage V Edition 10 and I’m not skilled regarding Bifurcation support I can’t help you. Maybe @Lost_N_BIOS can.
@Falloutboy - I got your PM, and see your post here, I can help, please make a new thread for your board model and I will get started there helping you with this.
In your thread, please include a zip or 7zip of all your main BIOS pages that are currently visible (main, advanced, boot, save and exit etc), and also include on inside advanced so I can see all the visible submenus (Scroll up/down if needed)
If you can see Intel or IntelRC menu, please also include images inside that as well, all of the IIO contents, mainly root of IIO-IIO3 You can F12 screenshot to USB I believe, then zip those up for me, if you know how please redo the image from BMP to JPG or PNG whichever is smaller, thanks.
Thanks @Sylar76
No problems just to let you know for GMT purposes I live in New Zealand.
I will get together all the information you asked for ASAP and I can do PNG’s which are nice and small.
Communication may be a little patchy though as I am a care provider for people with disabilities and can be needed at the drop of a hat. but when I am home I will keep my browser logged in here so you can see I am about.
Thank you so much as this was becoming a major headache for me.
Make a thread and we’ll get it done We don’t need to be online at same times, it will get done eventually
@Lost_N_BIOS :
Thanks the thread is here Rampage V Extreme Edition 10 BIOS update for PCIe Lane control while keeping NVME active.
I’ve tried to be thorough.
Guys i tested all cpu microcodesd best is one click behind the patch spectre!!!the last not good for perfomance
Yes, the fastest Microcode should be 22.
Is that the Extreme or the Extreme Edition 10?
How much of a performance hit is it, surely it can’t be as bad as a 500mhz loss on o/c?
4101 Beta
https://dlcdnets.asus.com/pub/ASUS/mb/LG…E-ASUS-4101.zip
Rampage V Extreme 4101 - Rampage V Extreme 4101
rst - 14.8.2.2397
lan - 0.0.23; 0.1.14
mcode 37 and 14
https://1drv.ms/u/s!AmgmarLdXm_-gr0gZM24MLIx8AvFgQ?e=9HE8zw
Can someone cook new 4101 with latest LAN, RST, with fastest microcode before spectre please ?
tell me what cpu microcode is and i put in 4101 bios
Hi, panosxidis
Please tell me which version of microcode and BIOS for i7 5960X is best for the patch spectre in terms of better performance on Windows 10?
Your Mod 3902 BIOS with Ethernet controller update and cpu microcodes for ASUS RAMPAGE V X99 best or new beta 4101 BIOS? If latest 4101 BIOS best please create mod of this BIOS and place to this https://www.upload.ee
Thanks!
Here we go :
Latest Bios 4101 with orom/efi RST/LAN updated as well as microcodes for latest spectre/meltdown patches and 1903 May Update compatibility.
https://drive.google.com/open?id=1Fz5Vy_…5ydNGu6Yrj9cxk_
Thanks! With best regards!
@Sylar76
On the Broadwell-e is not last cpu microcode!! your bios cpu microcode is 36 the new one is 37
