@panosxidis
I’ve reuploaded it with 37 cpu microcode for Broadwell-e
For me the fastest my test cpu microcode for broadwell-e is 1C and maybe 19.i download last bios 4101 and i put 1C or 19 is fastest for me!
Could You share Your BIOS file ?
Hello guys as i have 6850k and Rampage v edition 10 Mobo i hava some questions
1st) what is the fastest microde for 6850k cpu 1c 19 or 22? (said in topic by @panosxidis and @Horstfuchs )
2st) if i put one of those fastest microcodes in latest bios 2101 overclocking will work or not?
thanks for answer have nice day
It will be really difficult to find out which microcode is fastest, because really all results will fall within margin of error. Only one thing is for sure, for maximum performance you will want a pre-Spectre/Meltdown microcode. 22 was the last pre-mitigation microcode for Broadwell-E, so I guess you can start there and work your way down if you wanted to benchmark.
Your overclock will work if you have made sure that Windows will not use its own microcode update file (rename or remove mcupdate_genuineintel.dll) and disabled Spectre/Meltdown mitigations inside the Windows registry or with InSpectre.
thx for answer mate where can i find and how to do ‘‘rename or remove mcupdate_genuineintel.dll’’ is there any guide?
@Sylar76 sylar ty so much from now on could you mod R510E latest version bios 2101 with pre-Spectre/Meltdown microcode. 22 and all other things the latest version only microcode will be pre-Spectre/Meltdown microcode. 22
waiting for your answer ty you so much again
It’s faster if you could attach here the microcodes you need as I’ve a lot of other work to do mate. Thanks
tbh i dont know how to do i just put here cpuid id and microcode uptade revision number? sorry about this i dont know how to find pre-Spectre/Meltdown microcode. 22 one too
Add: @Sylar76 hello again mate i am sorry that i could not help you i need one more thing if you could. Would you also mod R5E10 latest bios 2101 with latest avaible microcode for 6850k with latest version of every compenent in it i wanna test those bios and see if it is worth or no ty again so much
i would wait till you have time to make them so whenever you want to make them it wont be problem for me ty so much for your help
willing to test:) two modded bioses to test them out will report result here
@Worgened
Here is your modded bios with CPU Microcode 22, thanks to @panosxidis
https://drive.google.com/file/d/1fSveWRk…iew?usp=sharing
@Sylar76
@panosxidis
Thank you so much guys when do you have free time i would wait till you do:) Would you also mod R5E10 latest bios 2101 with latest avaible microcode for 6850k with latest version of every compenent like rst,lan,OROM/EFI and MEI in it i wanna test and comparison those bios and see if it is worth or not. ty again so much
@Worgened
Here it is the 2101 mod with the latest microcodes and raid and lan modules:
https://mega.nz/#!o6R3mK4S!_LPqt84YdnqlA…OFHRn60gq0tdSZI
Flash it via Asus Flashback. The bios mod file comes with Asus Flashback required file name after decompressing it.
hi all,
I heve this mobo RAMPAGE V EXTREME/U3.1 is there a modded bios to enable the use of an engineering Sample XEON CPU?
Thanks
Chris
@cheyworth - you need to give people the name/model of your ES Xeon, or the s-spec info off the chip, or if you know the CPUID that would work as well as this is the end goal needed to insert correct microcode
Hello,
Could I have latest BIOS for Edition 10 with best OC microcode for 5960X?
Just reformatted and installed latest WIN10pro on my RVE 6950X rig with an older modded 4101 and now cannot OC- I used inspectre to disable meltdown and spectre patches and also renamed mcupdate.dll. I still cannot boost on all cores. Is there an updated BIOS you could kindly whip up? Happy to send you a few coffee’s via paypal for all your hard work!
Hello again, I am looking to install the ASUS Hyper m.2 x16 v2 card into this motherboard (Rampage v extreme/u3.1, current bios 3504) but will need to enable pcie bifurcation (pcie slot 1, top) CPU is xeon E5 2580 v3. is this possible with a modded bios?
Thanks
Hi all, would like to know if there is a custom bios for a Rampage V Extreme that will allow me to boot correctly into Windows 10 Pro with an E5 2680V4 Engineering Sample? I’m getting Q-code 19 on boot and I have to deal with resetting the cmos every time to load Windows. I would also like to overclock it but i cant since i have to reset bios every time I boot. Thank you.
#'s on the physical chip
QHV7 2.20
L508D367 e4
35510260N00045
Do the bios’s for the Rampge v extreme also work for the Rampge v edition 10 ?
