[OFFER] ASUS Rampage V Extreme - modded BIOSes
If someone need Rampage V Extreme 4101 Bios updated or Edition 10, please provide the needed cpu microcodes and I’ll try to mod when I have few mins.
i need to edition 10 the newest bios is 2101 with oldest microcode probably is 22.
someone has microcode 22?
Here we go:
Rampage V Extreme Bios 4101 with latest orom/efi/mcodes
https://drive.google.com/file/d/14ZKvGLn…iew?usp=sharing
Rampage V Edition 10 Bios 2101 with old cpu microcode 22 (Broadwell-E)
https://drive.google.com/file/d/1C1v0VTm…iew?usp=sharing
@Sylar76
you are just brilliant
THANKS!
Dear guys, I tested and tested today and it seems the Microcode 22 is really a bit faster than 38 with Spectre/Meltdown Fix disabled.
Could you please use your latest R5E10 bios with MC22 (post 443)
… and put in the latest RST-ROM 18.31.1.5256 (I have the link but not allowed to post it here, you can find it here easily).
I will try if the RST ROM works better than the original one on X99.
Thanks :slight_smile:
@X909
I’ve already updated it with latest X99 compatible IRST-ROMS. 18.xxx version doesn’t work.
Ah ok thanks! I see its 14.7 or so… 17.xx does work. But maybe no improvement.
Im also searching for the very last microcode from intel should be 3C but I can not find the file.
For “work” I’m meaning the presence of Intel Rapid Storage menu under advanced options in UEFI bios allowing to create raid arrays or handle hard drive units.
Yeeah, you are totally right. 17.x shows in UEFI but doesnt find the devices!
So, your last UEFI should be the "final" one for this platform, if not a miracle happens and someone finds out how to enable reBAR.
Could you please make a second version with the latest Microcodes? I have found the one for Broadwell-e here:
github.com/platomav/CPUMicrocodes/blob/master/Intel/cpu406F1_platEF_ver0B00003C_2020-11-19_PRD_7A1A7840.bin
Sorry, Im still not allowed to post links.
Wow they seem to make still new microcodes for the Platform.
https://github.com/platomav/CPUMicrocode…RD_407BC9CE.bin
@Sylar: would you be so nice to make your last UEFI File for the R5E10 again with the 3E Microcode?
New Rampage V Extreme 4101 / Edition 10 2101 modded bios:
- Added latest Haswell-E / Broadwell-E (306F2/406F1) Microcodes (44/3E).
https://drive.google.com/drive/folders/1…i6r?usp=sharing
I saw the 4101 Bios on ASUS’s website awhile back and now it’s no longer there. The most current one I’m seeing, is 3701, which is what I have. Aside from, I’m guessing the Spectre/Meltdown patch, why would I install 4101, or even this particular BIOS that you’re sharing? I’ve installed BIOS before on my R5E, but I’m honestly a bit hesitant, since 3701 "works". I can be convinced, though if need be.
(I had to remove the link in the quote since I’m a new member)
3701 is a stable bios, 4101 is beta. The Spectre/Meltdown patch is related to CPU Microcodes and Windows hotfix, thus it is not strictly related to a specific bios version,
as anyone could update cpu microcodes for his own. I’ve shared it because someone asked for it, that’s all.
Sorry for offtop and my bad English. Can enyone mod last beta bios 2101 for X99 Deluxe II with latest microcode and best/last oproms/EFI LAN sata? I’ll be very thankful.
Any chance of getting the new Bios with 22 microcode made available again?
Love your work mate.
I would like to have the last mod of 4101 of the Rampage V extreme but with the microcode 22, please is there any opportunity to do it?
If it had to be done, I would obviously make a donation for the inconvenience.
The microcode 22 supports 6900K? :confused:
if not, what are the fastest microcode por the 6900k (6th series)?
Thanks!!!
@Sylar76
@panosxidis
@Yrielbcn
Here we go: https://drive.google.com/file/d/1Vdu3KpH…iew?usp=sharing
i flashed ur bios mod3, but the aida64 tells me i have the 38h microcode, the same microcode than i had before with the 3801 bios, i did with the biosflashback tool and 2GB usbstick.
@Sylar76
something is wrong but I don’t know what
attach picture
@Yrielbcn
Of course it is, the windows is still loading his latest Intel mcode updated DLL, on top of the bios mcode.
how i can solve this problem?
all i want the 22h code. I need delete C:\Windows\System32 mcupdate_genuineintel.dll?
If I update the system will I have the same problem?
Sorry for the inconvenience
