What would be real good is to modify the bios for those boards that have the 1.2 TPM module to 2.0 so Windows 11 would play on say the X-79 Deluxe, which is part of the ASUS P9X79 boards, although they all do not have that module. Any directions about where that could be done? Or if it can or cannot be done at all?
Hello all,
I have a modded bios with a 3930k, samsung 970 evo plus and 3070ti fe working perfectly, less in the New World, where I get very low performance and the GPU uses only a 30% of power. Does anyone else have the same problem?
Hello, I uploaded the bios available in the first post and the PATA option appeared. In the bios I have Legacy booted and a different system, but the windows installer (running in legacy mode) signals that the system cannot be installed on this device because the BIOS doesn’t support booting from it. Have I missed a step :)?
/EDIT I will read the guide again and follow all the steps. .
Yes… OS “unknow” windows systems ALWAYS requires UEFI boot system NOT CSM/AUTO (legacy) to installations on NVMe.
If u tried a bit more and take some time readings on the forum… theres plenty of rush users like u with the same will of not learning and do basic errors.
Over_N_Out.
EDIT: How about this and try to read? A thread in main forum page…and u missed… fxxx lazzy people
[HowTo] Get full NVMe support for all Systems with an AMI UEFI BIOS
As I wrote above, I will follow the thread again - this problem already appeared on page 9 - but I have doubts to say UEFI is required instead of CSM / AUTO because I installed the system in legacy mode on a platform with the x570 chipset - unless this rule applies to this modification on x79.
Thanks very much guys. I used the modded bios from post #293. It works really well. Now I don’t need to buy new computer stuff. My old sata raid 0 SSDs got corrupted. This worked and now my 2011 socket lives on.
btw the hardware I used was samsung 970 evo plus and RIITOP PCIe adapter card with heatsink
Thanks Treehouse. I did mine a few years ago and the board’s still working fine. The information you posted is a good refresher and congrats on your success and kindness.
one more question I think i used your bios long time ago and till now i am on 2 PCIe ports with cheap chinese adapter cards with 1 nmve drive on each but i plan to buy 4 port nmve drive and add one more nmve for storage drive as my 2tb drive is in bad condition. and here is a question is your bios support pci sharing bifurcation ? So i can just buy 4 port adapter if not I will need to upload other bios .
No, I just inserted the NVMe EFI module. PCIe bifurcation needs an extra BIOS modification (will not be done by me).
thx for replay Fernando
Is there a guide for this at all? (I keep seeing references to a guide in the thread but the only one I can find is in reference to a different board) Does the ME need to be updated? And is the first FW in the thread the best one to use?
“Does the ME need to be updated? And is the first FW in the thread the best one to use?”
No, it can be updated as individual operation before or after the mod itself.
Usually latest shared mods, should be the more up to date, regarding used modules.
Users can share or not… a report of what was updated/used in it.
The issue is about how to update the Intel ME in the ASUS P9X79 PRO mainboard. Where is the tool? I’ve downloaded the BIOS here [Offer] P9X79 PRO BIOS Modded for NVMe SSD - #12 by Twister but I would like to replace NvmExpressDxE_2.ffs with version NvmExpressDxE_5.ffs and also to flash the Intel ME 8.1.70.1590 because right now the board has 8.1.51.1471. But, What tool do I need to flash the Intel ME? Where is it? Please help.
I’ve already flashed the BIOS with the included Intel ME updated but now I need to update the Intel ME itself. The one provided here is the EXTRACTED but I suppose that it’s needed to inject the EXTRACTED free version and not the one provided. Am I wrong? MEInject says that there is no suitable version to select from the dropdown list (It’s empty)
@LongHorn
Welcome to the Win-Raid Forum!
You have posted your 2 requests into a not matching thread and Forum Category.
If you want to replace the NVMe EFI module within the BIOS Region, you should follow the related advices, which can be found within the start post of >this< thread.
Regarding the update of the Intel ME Firmware you should look into the start post of >this< thread. Edit: MeatWar gave you already the related advice.
Good luck!
Thanks a lot for the fast answer. I’ve found this thread related to the P9X79 PRO modded for NVME and that’s why I posted it here, because I supposed that other users with same motherboard would take a look here. I’m sorry if it’s not the right place or procedure. I’ll try my best to find where on this forum to put a request for help about the procedure.
@LongHorn
The procedure regarding the replacement of any BIOS module is absolutely similar for all mainboards with an AMI UEFI BIOS.
Consequence: A specific guide for the P9X79 Pro BIOS is neither available nor useful.
I understand. I’ve tried to clarify my current situation in this new thread. I put it there for reference. I hope that it’s well.
po próbie aktualizacji biosu pisze że plik jest niepoprawny, gdzie można dostać gotowy dobry zmodyfikowany uefi ?
