[Offer] P9X79 PRO BIOS Modded for NVMe SSD
Hey, so I’ve been struggling to get this working on my own P9X79 Pro, and I tried flashing diegotru’s modded bios using the USB Flashback button feature, but I’m not entirely sure if it worked, or I’m unsure if I’m missing something within the Bios options, what it did do is show a new boot for a boot left over for ZorinOS, so I think it sort of worked, and I tried install Windows onto the NVMe while having all the Sata SSD’s disconnected since it kind of messed it up last time when I did have them still connected since one of them currently has my install of Windows. But it’s still not showing in the bios options. I really do need help with this.
These old boards only will show an NVMe disk entry boot when a finished OS installation was done, until then, there’s really no info, like modern mbs, about a connected NVMe disk unless temporary switching to Legacy bios (Just for testing purposes and confirmation of mod flashed) and a PATA device will be seen.
It’s all addressed in Fernando’s guide
Well, I’m still no further since, my flashback button doesn’t work so I instead tried to flash the modded bios with AI Suite II, and I think I’ve managed to mod it, and I have even managed to install Windows onto it, but the only problem now is that even with Windows installed but it’s still not showing up on the Bios boot…
Installation is to be done with only the NVMe attached, disconnect all other disks, bios with UEFI settings ONLY (not Legacy/CSM Auto or ON as per previous PATA test), USB x64 UEFI OS, erase any partitions if disk has MBR, setup will set it up as GPT, it’s all in the guide sir and thousands of users have done it, what else can we say…
Okay, so I actually finally figured out what went wrong, the bios flashing actually didn’t work, and my Flashback button doesn’t seem to work at all, but then I remembered watching this video, and so I decided to try En Root’s method of flashing the modded bios, using AI Suite II and name swapping between the original and modded bios, and so I decided to try that but instead I decided to go with Twister’s bios since it has more SATA related updates for the motherboard.
https://youtu.be/sxX0RtX5e6g?si=N_MD2NpVRNm1Fu5M
And so when I decided to try this flashing method, at first the computer was slowing down dramatically and I was feeling nervously worried, thinking “Oh crap, I bricked my motherboard!” but then a minute later the bios flashing was finally done, and then I went straight back into the bios options to see if it truly worked, and lo and behold, the fabled PATA_SS drive was finally showing for the NVMe drive! Then I installed Windows 10 IoT LTSC onto it using Rufus although for some reason the drivers for the installer don’t seem to work on USB 3.0, but it does work on USB 2.0, but whatever, in the end I installed it and bam, it’s finally done and working beautifully! Now I’m a very happy raccoon! ^^
Hi Fernando I need some small help with another mod for this boards I send you prv a message if you could help me with this it will be a great bios for this board .
one more question about this [Request] Ultimately modded ASUS P9X79 PRO BIOS this bios will work ? with rtxa2000 12gb + rtx306012gb and maybe quadro M5000 ?
