The Intel SSD Toolbox is meanwhile outdated and not supported anymore by Intel.
Its successor is the “Intel(R) Memory and Storage Tool”. The first version is v1.5 and can be downloaded from >here<.
Here are some pictures (in German language):
Abelssoft’s SSD Fresh v2021.10.04 (win7 & up)
Indexing,Drive optimization,Timestamp,Hibernate,Windows kernel swapping,Prefetch,Defragmentation of boot files,Windows event logging,8.3 file name creation,Windows trim function,AHCI setting
@Fernando
I have tested the new released Intel MAS Tool v1.6.122 and the ‘Optimizer’ is now working well for the i750 SSD.
So, it was a pure MAS Tool problem !! and I do recommend to use v1.6 instead of buggy v1.5.
@100PIER :
Thanks for your report about the latest Intel MAS Tool v1.6.122. Although the start post has been declared as being outdated, I have moved your post into this much better matching thread.
To avoid any misunderstanding by the visitors of this thread I have exceptionally updated the start post regarding the Intel SSD Tool (replaced the Intel Toolbox by the MAS Tool).
Intel has released v1.7 of Memory and Storage Tool but the official page is not working,although Command-Line Interface version of the app’s page does.
here is the alternative download link; Intel Memory and Storage Tool 1.7
SSD Booster
It provides you with slider-type options for optimizing and tweaking Windows for SSD (enable/disable)
There are a total of ten options and include TRIM support, Driver Optimization, Search Indexing, Kernel Paging, Hibernate, Event Logging etc.
official download
mirror download
NB that the Crucial Storage Executive 3.46.062017.04
works on any NVMe SSD
as long as you have a compatible drive plugged in to install it:
https://www.thessdreview.com/daily-news/…n-any-nvme-ssd/
I do hope there’s still a copy of version 3.46.062017.04 around here somewhere!?
It’s still available for download here
A little harder to find a compatible crucial model (all a bit old). For example the SSD BX500 is not compatible for the over provisioning and for the momentum cache.
