The problem with the function "Intel SSD Optimizer" is not fot fixed with this version Intel SSD Toolbox v3.5.10 when running on any of my Intel SSDs [SATA (i80, i320 models) or NVMe (i750 model)]. (Error 10/114).
However, TRIM via W10 optimize or TRIMcheck tool or ANVIL bench TRIM does work without any problem.
Update of the Start Post
Changelog:
- Updated: Samsung Magician (now v5.3.1.2010 dated 03/14/2019)
Enjoy it!
Dieter (alias Fernando
New Crucial Executive Storage v3.65 https://www.touslesdrivers.com/index.php…23&v_code=60748
Changelog:
- Updated: Crucial Executive Storage Tool (now v3.65 dated 03/13/2019)
Enjoy it!
Dieter (alias Fernando)
Also KIngston SSD Tool has been updated recently to v1.1.2.0. The link is OK, only the comments to update. Thanks Fernando.
Changelog:
Updated:
Kingston SSD Manager (now v1.1.2.0 dated 04/02/2019)
Thanks to 100PIER for the info. -
Intel SSD Toolbox (now v3.5.11 dated 04/11/2019)
Thanks to Pacman for the link.
Enjoy it!
Some updates :
ADATA SSD ToolBox v3.0.11
https://www.adata.com/AppStore/ADATA_SSDToolBoxSetup.zip
Corsair SSD Toolbox v1.2.5.7
https://downloads.corsair.com/Files/SSD/…1.2.5.7_WIN.zip
Crucial Storage Executive v5.02
https://assets.crucial.com/wcsstore/Cruc…tive-win-64.zip
Kingston SSD Manager v1.2.1
https://media.kingston.com/support/downl…tup_1.1.2.1.exe
Lexar SSD Dash v5.1.5
http://www.lexar.com/wp-content/uploads/…-Dash-v5.15.zip
Samsung Magician (Consumer Edition) v6.0.0
https://s3.ap-northeast-2.amazonaws.com/…n_Installer.zip
SanDisk SSD Dashboard v2.5.1.0
https://downloads.sandisk.com/Dashboard/…hboardSetup.exe
Seagate SeaTools SSD GUI v4.1.70
https://www.seagate.com/files/old-suppor…oolsSSD-GUI.zip
SK hynix Easy Kit (SSD Manager) v1.4.3
https://www.touslesdrivers.com/index.php…23&v_code=56732
Toshiba (OCZ) SSD Utility v3.2.3303
https://ssd.toshiba-memory.com/download/…303-Windows.zip
Western Digital SSD Dashboard v2.5.1.0
https://wddashboarddownloads.wdc.com/wdD…hboardSetup.exe
HTH
Thanks shroeder,
Startpost should be updated, i.e. Corsair SSD Toolbok v1.2.5.7 instead of v1.2.5.5.
@shroeder :
Thanks for the information and the links to the latest SSD Tools.
@all:
As my final activity within this thread I have done today a last update of the start post (the Samsung Magician Tool was already up-to-date before).
If you want to get these information in the future, someone else should start a new thread.
Thanks for your interest!
OCZ SSD Utility v3.4.3335 is out aswell…
https://ssd.toshiba-memory.com/en-emea/download/
@N6O7 :
Thanks for the info, which verifies, that the start post of this thread is already outdated 1 day after the last update.
An updated Intel SSD Toolbox v3.5.12 dated 11/12/2019 is available.
Download link:
>Intel SSD Toolbox v3.5.12<
Enjoy it!
Samsung Magician Software Version 6.1.0.170
In case of problem with download, it can also be found <here>
Intel® Solid State Drive Toolbox
Date: 5/29/2020
Version: 3.5.13 (Latest): https://downloadcenter.intel.com/downloa…e-Drive-Toolbox
Release Notes: https://downloadmirror.intel.com/29609/e…_325993-053.pdf
Hello, is it possible to list the software versions compatible with Windows XP?
I have Kingston SSD right now.
But I would buy the next discs from the manufacturers with XP compatible software.
Thank you.
@Cixert :
Welcome to the Win-RAID Forum!
As the thread title indicates, the start post is outdated and will not be updated anymore.
My tip: Test all SSD tools for compatibility with Windows XP (you may need SSDs from different manufacturers) and present your results within >this< Sub-Forum.
Good luck!
Intel SSD Toolbox v3.5.14 is out:
https://downloadcenter.intel.com/downloa…?product=80096*
Release notes
Intel SSD Toolbox v3.5.15: Intel SSD ToolBox
release notes
to Cixert and other Xp users,
SSD Tweaker (XP and up) has paid and free versions
Free version does trim check,prefetch & superfetch control,memory management,disable boot tracing,DIPM enable support and more ssd/windows tweaks.not updated since 01/27/2019
or Smart Defrag (Xp and up),supports trim
or Tweak Me! (Xp,up to win7) system,registry and ram cleaning,trim support,ssd optimization,startup manager.not updated since 11/03/2012
create a scheduled scan/check and it might be the next best thing
