USB device, no external driver required for Windows 10 and later operating systems. The operating system’s factory driver is perfectly adequate.
Understandable and I agree that the drivers are adequate. However I enjoy tinkering around and the NVME driver switch has improved performance in many ways. It would’ve been nice if I could test the same with my peripherals.
If you have a suggestion which drivers I could use, please let me know.
I have the same opinion about PCIe SSDs. I stopped using third party drivers a while ago, there is no point. Manufacturers don’t release newer and newer versions for these for a reason, like for a VGA. Microsoft on the other hand updates every few months. But this topic belongs in another thread.
AMD USB 4.0 ([email protected]_05.24)
PCI\VEN_1022&DEV_15C4
PCI\VEN_1022&DEV_15C5
PCI\VEN_1022&DEV_162E
PCI\VEN_1022&DEV_162F
PCI\VEN_1022&DEV_1668
PCI\VEN_1022&DEV_1669
Neither the directory names nor the file dates are the original ones! But none of them make any difference.
amd_usb4.rar (204.3 KB)
I strongly disagree with you westlake:
Here is a before and after of my 58GB Optane 800P:
ie: stock MS vs Intel mod driver:
NB the R4K Q1T1 numbers as 66% of Windows I/O is them, NOT the large sequential #s SSD marketers wave around like burning flags.
92 MB/s faster reads.
92 MB/s is more than most NAND based NVMe SSDs do for R4K.
For my Corsair MP600 I get a good 30MB/s more in Random writes by using the mod Samsung drivers.
That’s the I/O windows does 58% of the time.
H’lo. Can anyone post USB drivers for DEV_43F7, DEV_15B8, DEV_5B7, DEV_15B6? I am want mod driver. Thank you.
@miirie
Since I have stopped the support of this thread, you cannot expect any modded USB driver from my side.
By the way - you forgot to mention the manufcturer of the USB devices and the target OS. Additionally you have mentioned a not existing DeviceID (DEV_5B7).
@all
Users, who want to get a specific driver, should give at least the following information:
1. VendorID (VEN_XXXX) and DeviceID (DEV_XXXX) of the related device (here: USB Controller)
2. target Windows OS incl. its architecture (32/64bit)
Absolutely. My folly. I am not sure how I mistype that.
You look here:
PCI/Ven_1022&Dev_15B8
PCI/Ven_1022&Dev_15B6
PCI/Ven_1022&Dev_15B7
PCI/Ven_1022&Dev_43F7
Thank you much
Hello guys, im new here and im trying to understand how this works. These are my hIDS:
PCI\VEN_8086&DEV_A2AF&SUBSYS_7B481462&REV_00
PCI\VEN_8086&DEV_A2AF&CC_0C0330
im running a z370 a pro with a i5 9600k. Im not sure about what driver would work but I guess this one (pure" 64bit Intel USB 3.0/3.1 Drivers v5.0.4.43 re-mod with DPInst option) would work?
@cai0ba Welcome to the Win-Raid Forum!
Only the user of your specific system knows the answer. Why don’t you try it yourself?
Good luck!
Dieter (alias Fernando)
Hey @Fernando
tnx for all the great threads :]
can you help? im trying to find drivers for VEN_1022&DEV_15E5 its usb3 from AMD, its not on this thread. also couldn’t find it anywhere.
its for laptop with ryzen 3 3000 series (raven2 i think)
looks like there is only internal ms drivers (AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft).
il be happy if anyone can find - original & mod. amazing forum here
@Driftix
Although I cannot help you, I would like to know why do you want to replace the in-use generic MS USB3 driver. Do you have any problems with it? If yes, which ones?
yes i suspect they ports are unstable, mainly usb wifi adapter. so im searching what to can improve it. so there isnt any drivers for it at all?
amdusb4cm [email protected]_09.06
amdusb4pcifilter [email protected]_06.16
amdusbhubfilter [email protected]_05.16
DEV_15C4/15C5/162E/162F/1668/1669
amd_usb4.rar (184.3 KB)
ASMedia USB 3.0-3.1 drivers v1.16.61.1 WHQL
The driver version is the same as here. Executing file with digital signature dated 07/02/2021
amdusb4cm [email protected]_12.22
amdusb4pcifilter [email protected]_12.22
amdusbhubfilter [email protected]_12.22
amd_usb4.rar (185.3 KB)
Does anyone have the usb driver for dev_06ed ?
@scriwy
Which is the vendor/manufacturer (VEN_XXXX) of the related USB Controller and for which OS do you need this USB driver?
Good luck!
PCI\VEN_8086&DEV_06ED&SUBSYS_7C751462&REV_00
USB\ROOT_HUB30&VID8086&PID06ED&REV0000
and windows 10 1803 64bit, thanks!
@scriwy
Why do you want to replace the rather new generic MS USB drivers of your in-use Windows OS by modded old Intel USB 3.1 drivers v5.0.4.43 dated 05/11/2017, which may not even work properly with your modern Intel chipset system?
