@Fernando , At the moment I have PCI bus and PCI Express Root complex:
So, do you suggest for the Intel USB 3.0 modded driver, Step 3 âSwitch Driverâ, to update âPCI Express Root Complexâ and this will automatically also update âPCI busâ ?
Yes, that is what I recommend to do. By the way: You can read the exact procedure within the start post of this thread.
No. The device named "PCI Express Root Complex" will be renamed to "PCI Bus" after having installed the USB 3.0 Switch driver. The other device named "PCI Bus" will probably stay untouched. Donât try to update its driver.
@Fernando , Yes, the device named "PCI Express Root Complex" has been changed to "PCI Bus", and now I have 2 devices named "PCI Bus", one is the MS native item, the other one is the Intel modded driver (switch) item. Here are the 2 "PCI Bus" screenshoots: AFTER "PCI Express Root Complex" modded becomes special Intel "PCI Bus":
Hi Fernando I am having a strange problem, when I eject a USB drive it doesnât fully eject, the USB drive is still visible in explorer. I can still right click the drive and get options. Iâve tried installing the latest intel USB 3.0 drivers but he problem remains. Image below shows problem EjectImage
I doubt, that this issue has been caused by the in-use USB 3.0 driver. To find out, whether it is a special USB 3.0 problem, please connect the Corsair USB Flash Drive to any non-Intel USB port or to an Intel USB 2.0 port and repeat the procedure.
Thanks for replying, just tried plugging in the Corsair USB into the USB 2.0 ports and the ASmedia ports, same result. One thing I just realized is that on this fresh install, I installed the newer Intel Chipset Device Software v10.1.1.27 instead of the 10.1.1.13. Could the newer version configured my chipsets incorrectly?
Just noticed this in event viewer( The driver detected a controller error on \Device\Harddisk3\DR3) I just checked and its my other Adata USB drive that causes the error when plugged in. I also tried updating the chipset device software to 10.1.1.32 but made no difference.
Edit: Doesnât matter which USB drive I plug this error shows up in event viewer(The driver \Driver\WUDFRd failed to load for the device WpdBusEnumRoot\UMB\2&37c186b&0&STORAGE#VOLUME#_??_USBSTOR#DISK&VEN_CORSAIR&PROD_VOYAGER&REV_3000#AA04012700007823&0#).
Thank you so much for the modded Intel drivers for Windows 10! I have an Acer Aspire V5-591G and after installing Windows I encountered this strange issue. Everything worked except USB 3.0 devices plugged into USB 3.0 ports. Iâve been looking for a solution for a few days now and nothing has helped except for this. There was no such driver on Acerâs driver download site.
new: 32/64bit AMD USB 3.1 Drivers v1.0.2.0 WHQL dated 02/26/2016 Note: These drivers may be usable with all Windows Operating Systems from XP up to Win10. Supported are the AMD USB 3.1 Controllers DEV_43B9, DEV_43BA, DEV_43BB and DEV_43BC.
Good luck with these new AMD USB 3.1 drivers! Dieter (alias Fernando)
Hey Fernando sorry for the late update, Iâve given up on trying to run Windows 7 with this board. USB isnât the only issues I am having. So since Iâm upgrading to Windows 10 is there anything special I have to do to deal with the automatic driver updates. Do I just let windows update all my drivers and just install the latest drivers over them?
For Win10 users with a modern Intel chipset system it is easy and usually very safe to let the Windows Update take care about the drivers (only exception: storage drivers for AHCI/RAID/NVme/USB Controllers).
If you want an other driver than WU gives you, you can install it on-top of the other driver as long as you do it manually from within the Device Manager.
Hi Fernando , before DM want to say thank you, set your driver Asus G75VW Win 10 Home X 64 Intel (R) SATA AHCI Controller DEV_1E03 added by Fernando version 15.0.2.1044. Since I use a small computer , it was not possible to evaluate the performance , with the bugs undetected . The question is : Is it possible to adapt the Intel (R) USB 3.0 eXtensible Host Controller Driver for Win 10 x64? ID equipment PCI\VEN_8086&DEV_1E31&CC_0C03
Thank you, Fernando , everything turned on your instructions , and now the driver is called Extensible Intel host controller (R) USB 3.0, then one more question: how to update the Intel (R) 7 Series / C216 Chipset Family USB Enhanced Host Controller - 1E2D ID PCI \ VEN_8086 & DEV_1E2D & CC_0C03 and Intel (R) 7 Series / C216 Chipset Family USB Enhanced Host Controller - 1E26 ID PCI \ VEN_8086 & DEV_1E26 & CC_0C03?! I hope not too tired with questions )
