Hey Fernando I decided to try again after 10 days and finally is working the 3.1 i did it Manually and read the instructions, everything is good now, thanks.
PS: Do you have more interesting things apart the usb drivers and ahci drivers? anything like NVIDIA drivers or audio, ethernet drivers, monitor maybe?ty.
@x58haze :
Thanks for having retried the installation of the AMD USB 3.1 drivers and for your feedback. It is fine, that the installation worked and that you are satisfied with the result.
No, I have enough to do with my current tasks, which already take too much time. I should rather reduce than expand my work for the Forum resp. for its members and visitors.
Hey Fernando, by the way there is an interesting tool that you may want to do some research, regardless to INTEL Patch reducing performance over AMD CPU? the tool it is called: Intel Compiler Patch, it will search for files over our HDD and SSD by modifying or replacing the GENUINE INTEL Code that may affects others CPU, do you know anything about that topic?
The thread or topic started in reddit: https://www.reddit.com/r/AdvancedMicroDeā¦_and_the_intel/
No, until now I havenāt heard or read anything about this tool.
are there any modded Win7 USB3.0 drivers which include UASP support?
@bgr02 :
My modification just concerns the text (*.INF) files and not the drivers themselves (= *.SYS files).
Dear Fernando, dear 100Pier, dear all,
Ok, I find new information but no solutions here:
ASRock X99 and USB 3.0/2.0 and the EHCI/xHCI host controllers
I tried the program from Alexx999 to switch every port to EHCI. When itās done my device manager start to blink (like refresh) every 3-5 seconds. Itās the same behaviour I have in the device manager when I Disabled the Intel USB3.0 Mode in the BIOS. Itās like I have a problem with the EHCI controller.
Anyway, it didnāt make my USB2.0 devices working.
I am really tired of this problem.
Jean
Hello
When I try to install these drivers by the Device Manager (.inf), I have the Windows message that the last (or better) drivers are already installed (Microsoft drivers)
With Windows 10, it is necessary to use the MS drivers for the ASMedia controllers (as for Intel) ?
I ask because I have speed problems with USB ports (ASMedia)
Thanks
You should not trust such messages. The OS Device Management doesnāt know, which one of the compatible drivers is the best.
No, the original ASMedia USB 3.0/3.1 drivers do fully support Win10 (contrary to the Intel USB 3.0/3.1 drivers).
I guess Windows acts according to the rank of drivers
https://docs.microsoft.com/en-us/windowsā¦vista-and-later-
@Grundraisin
I have done a test set of USB 3.0 / USB 2.0 configuration on my X99 ASUS (W10 RS3 64bit) machine using up to 10 different model USB keys plugged on different USB ports.
I have no USB 3.1 key.
The ASUS Manual does recommend to plug USB 3.0 devices on USB 3.0 ports and USB 3.1 devices on USB 3.1 ports for faster and better performance.
It is also specified "due to the design of the Intel 9 series chipset, all USB devices connected to the USB 2.0 and USB 3.0 ports are controlled by the xHCI controller. some ālegacyā USB devices must update their firmware for better compatibility"
On the rear I/O connection there are only 2 USB 3.1 ports handled by Asmedia Controller. And also 4 USB 3.0 ports and 4 USB 2.0 ports , they are all handled by Intel xHCI controller.
Looking at the details on the different screenshots you should observe that any ports are working.
You should observe little performance difference when using a USB 3.0 device on one Intel port or one Asmedia port.
As I have no USB 3.1 key I cant compare USB 3.0 vs USB 3.1 key performances.
You should observe with Format FAT32 / Format NTFS does produce very different performances.
And you should be careful about USB 3.0 key devices quality as you can see on the last screen. Some USB 3.0 keys on the market have the ālabelā USB 3.0 but they do offer a USB 2.0 key performance.
Hope this help you.
Eh, I spent over 3h tonight on these pure drivers trying to install them - this pure driver was telling me all the time that it is corrupted - but rar crc was ok, so I thought Iām doing something wrong.
In the end, it seems your pure pack doesnāt work on my Windows 7 as you included only Windows 10 version insideā¦ After 3h I downloaded full package and noticed there are two directoriesā¦ 3h wasted.
EDIT by Fernando: Formatting code of the quoted text corrected (for better readability)
@Lex :
Thank you very much for your report about the obviously wrongly described OS compatibility of the āpureā ASMedia USB 3.0/3.1 drivers v1.16.41.3. It is not easy to understand, that you are the first user, who realized this, because I have offered this driver within the start post since February 2017. I am sorry about the lost time until you found out the reason for your issue.
@ all:
Update of the Start Post
Changelog:
- new: āpureā 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.41.3 WHQL for Win7-8 dated 10/07/2016
renamed: āpureā 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.50.1 WHQL for Win10 incl DPInst dated 10/11/2017
"Pure" Win7-8 drivers and a complete Drivers & Software Set v1.16.50.1 are not yet available.
Thanks to Lex for his report about the OS compatibility of the āpureā ASMedia USB drivers!
Good luck with these ASMedia USB 3.0/3.1 drivers!
Dieter (alias Fernando)
@ all:
Changelog:
- new: āpureā 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.50.1 WHQL for Win8 dated 10/11/2017
- new: āpureā 32/64bit ASMedia USB 3.0/3.1 Drivers v1.16.50.1 WHQL for Win7 dated 10/11/2017
- new: ASMedia USB 3.0+3.1 Drivers & Software Set v1.16.50.1 WHQL for Win7-10 dated 12/26/2017
Thanks to Pacman resp. Station-Drivers for the source package.
It has now to be tested, whether the old ASMedia USB 3.0/3.1 drivers v1.16.41.3 are still better than the newest v1.16.50.1 drivers. If not, I will remove the old drivers from the start post.
Please give me your feedback!
Good luck with these new ASMedia USB 3.0/3.1 drivers!
I have a question about āpure 64bit Intel USB 3.0/3.1 Drivers v5.0.4.43 WHQL for Win7ā drivers.
There are three folders in package:
- Controller Driver - as first
- Hub Driver - as second
- Switch Driver - only if applicable
I do not use DPInst.
1. Iām pointing ā/!</b> Universal Serial Bus (USB) Controllerā device to āController Driverā folder and it installs correctly.
2. New ā/!</b> Unknown Deviceā appears.
3. Iām pointing this new ā/!</b> Unknown Deviceā to āHub Driverā folder and it installs correctly.
At this moment I do not have any more ā/!</b>ā devices connected to this driver, but I have one āknownā device at System Devices named PCI Bus which Hardware IDs is the same as Switch Driverās one: *PNP0A08
What does āonly if applicableā mean in this case?
Does it mean that I should still upgrade this āalready knownā device with that Switch Driver (because that device exist in my system)?
Or I no longer need to apply that Switch Driver (because device is āalready knownā and has no yellow warning sign)?
@Lex :
The addendum āonly if applicableā means: Only if there is a device named āPCI Express Root Complexā listed within the āSystem devicesā section of the Device Manager, you have to install the Intel USB Switch Driver.
@Fernando : Ah, ok. Does this "PCI Express Root Complex" device have the same name in every Windows OS or can it be "a little different" sometimes?
@Lex :
I havenāt yet seen another name for that Intel USB Switch device (as long as the Intel Switch driver hasnāt been installed).
OK, so if I see "known" "PCI Express Root Complex" device under "System devices" I will point this device to Switch Driver folder and upgrade its driver.
Thanks for explanation.
