PRIME A320M-C R2.0 Unlocking problem
:skull:
What did you change to unlock the Chipset then? It’s the same module where changes are made to manage tabs visibility.
edited the amitse, same way. But the monitor menu is still visible
Don’t know why so. You can try with this one amitse PE as-is.zip.
thanks, i will try it. Btw which method is that :skull:
right one ise mine left is yours
There should not be this much of difference. I took the file from your archive.
Is this outdated or incorrect?
yes
‘Download AMITSE~2.zip from Sendspace.com - send big files the easy way’
not worked
Ok. Its unlikely that I will be able to figure out why it didn’t work. I’d rather give up. A failure is really not that big of a deal for me.
Initially, I responded because you pinged me in this thread, but it seems I’m not the right person to help you.
i see, thanks.
Can i unlock dram voltage? max is 1.35v
You can change dram voltage from the stock bios?
yes i can but max value is 1.350
Which menu has this setting?
AI Tweaker i can send my current dump file
First of all I would like to see a picture of bios with the setting.
Please send.
I have no idea how limits are set even with the pictures provided. It’s not IFR tables min and max fields or float values hard-coded into some module.
Perhaps I can find a connection between the current value from NVRAM and the place where limits are set.
i sent, check your PMs
