[Problem] Biostar H61MLV2 with GeForce GT 730 GPU Support
Hello everyone,
I am facing a No-POST compatibility issue when trying to use an ASUS TUF GTX 1650 (Turing architecture) on an old Biostar H61MLV2 motherboard because it lacks native UEFI/GOP support.
​Could someone help me modify or inject the correct GOP driver into my motherboard’s BIOS backup so I can get it to boot properly?
I also have a gt 730 gpu and it works fine but my gtx 1650 doesnt work in my motherboard and i just get a no signal but everything work fine in the background and i have try it in other pc and it worked fine
https://www.biostar.com.tw/app/en/eol/introduction.php?S_ID=591&data-type=DOWNLOAD
This is my bios update link
Edit by Fernando: Thread moved into the “BIOS Modding Problems” Category and title customized
Assuming both boot modes fails, CSM or UEFI…
The motherboard current GOP modules are for Intel iGPU graphics, nothing related to the external NVidia GPU that has it’s own GOP driver.
The issue usually is related to the motherboard “poor” UEFI dGPU compatibility from Biostar.
Report it to Biostar support and ask a possible bios update or contact Asus.
or
Check Asus for updated vBios for the TUF correct model
or
At your own risk, may try to flash vBios from TechPowerUp database
or
using available forum tools to manually update the GOP driver:
GOP Update and Extraction Tool (Turing) - BIOS/UEFI Modding / BIOS Modding/Flashing Tools - Win-Raid Forum
AMD and Nvidia GOP update (No requests, DIY) - BIOS/UEFI Modding / BIOS Modding Guides and Problems - Win-Raid Forum
In practice, there is an alternative solution: remove the UEFI GOP module of the 1650 and keep only the VBIOS module. This will enable support in most cases.
