[PROBLEM] How to open/modify/flash an Intel mainboard BIOS?
        0
             0  1  2                           2  1 ▼
            ▲ J55EV                J54EV 
▲12 J55EV  ▼21 J54EV  [X5]
▲01 J55EV ▼10 J54EV [i7] ( could be also nothing )
The board could rattle or make strange noises with the pin on the wrong position, also the blue light would be not signal anything.
Just don't damage something with the soldering iron, take practice, or don't do it yourself. I'm not taking any responsibility.
Here a better view without the jumper in position
Cool I’ll try it first by shorting some metal. Will update you once it’s a success after I find the materials.
@eivrah
YEa, but don’t short them all together lol
Be careful it’s dangerous stuff.
Life hazard or almost there perhaps, so, remove the ATX power cord when mangling the jumper once you get the header installed.
Before soldering the pin, or making disaster, check if it work by using a conductive ( nickel/silver/graphite ink ) pen by tracing the dot of ▲12 J55EV  and ▼21 J54EV like in the figure (X5)
@noInk here’s a progress so far I just shorted them using the soldering lead and it displayed XD
Question what RAM does it support? I’m planning to buy ECC RAM’s for this board.
@eivrah
Yea, it wasn’t that hard, could you think about? Just remember in that way it’s not possible to boot the i7.
To boot the i7 series ( maybe not all ) you need to remove those junction or use the default 01 J55EV ▼10 J54EV ( or nothing at all it depend ).
Anything with the spec of 1.50 volt DDR3 1600+ would work but don’t change any setting from auto, or do and let me know how much BCLK you can achieve, eventually on the third failed attempt you’ll be forced to recovery.
I’m just assessing the X5670 capability mounted in mine which it’s on pair with a modern notebook @ 135. These 1366 CPU need at least 166 MHZ to be lag free -.-
@noInk are you referring to Host Clock Frequency Multiplier?
@eivrah
Yes, the base clock on intel user menu is named Host Clock Frequency Multiplier.
Mine can’t reach 142 no matter what ( just tried an i920 pretty much the same )
The PLL cannot be manually set ( it’s defaulted @ 1.5 ) also, the memory setting on the x5670 goes all over the place and doesn’t get read correctly by the bios if the user save a know to be working value (this doesn’t happen with the i920).
Forgot to tell you, the bios you got doesn’t provide i920 support.
@noInk I’m on 150 Right now haven’t touch yet 160 barrier since my other cooler is on my other PC.
@eivrah
Might be just this x5670 then or the board revision.
I’ll try one x5675 next week.
@noInk I’ll send you update later when I get home. I have doubt if this board will support ECC PC3-10600R RAM. It will be good if it will. I have known someone who have the same processor as your x5670.
Update: I asked him again and said his processor could not boot past 3.2Ghz
@eivrah
Yea, I have no idea.
With this board revision nothing boot if I change just by a little the host clock frequency.
Could be the i920 and x5670 too high voltage requirement incompatibility later fixed in the i950 and x5675, dunno.
Gotta try when the x5675 arrive, I ordered one.
@noInk could be the processor or the board, my i7-950 could boot past 160 multiplier not sure with the xeon though.
It’s the board revision somehow it doesn’t allow any “Host Clock Frequency” changes.
The X5675 has the same issue as the x5670 and i7920.
I’m stuck with default 133-135MHZ.
@noInk Here’s mine.
Maybe it’s on your board or RAM perhaps? I can do 160 but my RAM is not too overclockable. It’s only 1333Mhz I’ll try to play with overclocking it later on.
I’ve also thought about but it’s happening with all of these (know to work on other system) memory kit’s:
HyperX HX318C10FWK2
HyperX HX316C10FWK2
Crucial BLE8G3D21BCE1
Corsair CMZ12GX3M3A1600C9
I’ve also tried some proliant dismissed HP ECC memory, no avail.
I’m just using the 8PIN CPU and full 24 ATX cable are you using anything else like the optional PCI-EX molex-or-sata cable? does your board has those?
What happen if you set manually the memory multiplier to 10 and the uncore to 20? does it boot?
and what if you set the memory multiplier to “auto” and the uncore multiplier to 20 and then select the “Manual - User Defined” and hit enter? does the uncore move to 9?
I think mine board is ignoring the applied settings and the MEM/QPI ratio fix implemented by intel goes somewhow out of bound because the user menu variable doesn’t allow the uncore to move to 9…
The user variable
1
2
3
0x2F6F Numeric: Uncore Multiplier (30-12), Variable: 0x238[1] {07 14 38 02 01 FE 00 C0 04 10 00 00 0C 00 1E 00 01 00 14 00}
Anyway, with the x5675 I leave just as that for a while cause I have no clue.
@noInk I have my memory multiplier is set to 10 by default and I have no 9 in the multiplier only 8. Also my RAM timings are a bit different. Are you using 1600 mhz RAM’s?
Yea, these are 1600|1800|2133 memory I’m testing.
@noInk I only have 1333mhz RAM’s here though I’m planning to buy 1600 maybe next month, but I think the board limits to 1333 so need to overclock.
Tried to leave the memory untouched by rewriting by hand some user menu entry.
Moved the QPI setting from the Memory Configuration form to the QPI Configuration, Bus Overrides entry and it’s the same.
Can’t change the Host Clock Frequency Multiplier without making the board unbootable.
@noInk can you upload your modded BIOS? I’ll try it with mine.
