I’m having some trouble with my PC. It freezes randomly and there is artifact. I know it isn’t a hardware problem and that, somehow, LAN Controller and Intel ME are related to this issue.
I don’t know how could LAN cause this PC freezing, but using HWInfo, at SMBIOS tab, I’ve seen there is a vPro capabilities section, which is related with VT-d (memory management) and Intel AMT, and one entry says that my BIOS supports “VA extensions”. A couple of websites on the internet mention that VA extensions is an ACPI Op region, and that could be a place to introduce a memory bug which could cause my issue.
However, there isn’t much more info about this. I only know that VA extensions is related to an ACPI Op region and that it is vPro related. I don’t even know what VA means or how could I disable this feature inside BIOS.
Any info about this? Any way to disable VA Extensions with a BIOS mod? What is the function of VA Extensions?
BIOS: 360H4W0X.zip
Specs:
-Motherboard: B360H4-EM (Medion)
-Processor: intel i7-9700K
-RAM: 8 GB of Samsung RAM (M378A1K43CB2-CRC)
-Storage: 1 TB SSD +1 TB HDD.
I have a 300-series chipset (B360, as the motherboard namer says) and these chipsets use CSME version 12
Edit by Fernando: Both help request threads about the same topic merged and thread title customized
